Software Archive
Read-only legacy content
Footer in App Framework doesn't go away
bharat_b_
I tried to added Footer in App Framework but now there is no way to delete it. In WYSIWYG footer cannot be selected.
Please help for how to delete it.
Chris_P_Intel
If you do delete the footer from the DOM Tree or Code view, then be sure to visit the page definition in the code view and make sure that the data-footer attribute is set to none.  (eg  data-footer="none" ) otherwise App Framework will continue to provide a default footer.
In fact, I bet that is what has happened(*), because the App Framework provided footer isn't known about by the Design View and thus is not selectable/deletable.  But the fix is simple. Just set the data-footer attribute on the page.
(*) don't _remove_ the data-footer attribute either, because then App Framework will provide the default footer.
Adebayo_A_
You can delete it from the DOM Tree View.
Chris_P_Intel
bharat_b_
Hi Adebayo A,
Below are the screens from Intel XDK there is no footer available in DOM TREE view to delete.
bharat_b_
Hi CHRIS P,
That worked like a charm .
Thank you so much.
