Software Archive
Read-only legacy content
17060 Discussions
Fortran PARAMETERs shown twice in debugger
mecej4
When a Fortran program containing PARAMETER declarations is compiled with the /Zi /debug-parameters:used options, the parameters are displayed twice in the Locals window. Here is example code:
! test viewing PARAMETER values in debugger
program tst
implicit none
integer, parameter :: N=10,M=20,L=M+N
integer :: iv(M-N),i
do i=1,size(iv)
   iv(i)=N+i
end do
write(*,*)iv
end program
I have attached a screenshot of the duplicated display of the parameters in the debugger.
Georg_Z_Intel
thank you for telling us. I was able to get the same result and filed a ticket (DPD200564644) against the debugger extension (even though I think it might be a debug information issue with the compiler).
I'll let you know about the progress.
Georg Zitzlsberger
mecej4
Here are some details to help reproduce the problem. The compiler used was the 32-bit IFort compiler, version 15.0.2.179, on Windows 8.1 X64, on an Ultrabook with an i5-4200U CPU, Visual Studio 2013.
Georg_Z_Intel
Georg Zitzlsberger
mecej4
Georg: Thanks, and you are correct about the error being in the debug information. Let me know whether I should report the problem in the compiler forum. Or, you could move this thread to the Visual Fortran forum.
Using the hint that you gave, I built and ran the utility dia2dump (provided as an example in the DIA SDK subdirectory under Visual Studio) on the .PDB file, and this section of the dump confirms what you suspected (please scroll to the right edge of lines 13-16) :
CompilandEnv   : cwd = "S:\lang"
CompilandEnv   : cmd = "-MD -traceback -Zi -debug-parameters:used"
CompilandEnv   : src = "tpar.f90"
CompilandEnv   : pdb = "vc120.pdb"
Function       : static, [00001000][0001:00000000], len = 000000A6, TST
                 Function attribute:
                 Function info:
FuncDebugStart :   static, [0000101E][0001:0000001E]
FuncDebugEnd   :   static, [000010A4][0001:000000A4]
Data           :   VFrame Relative, [FFFFFFD4], Local, Type: long, I
Data           :   static, [00006100][0004:00000100], Static Local, Type: long[0xA], IV
Data           :   static, [00004164][0003:00000164], Static Local, Type: long, M
Data           :   static, [00004168][0003:00000168], Static Local, Type: long, N
Georg_Z_Intel
it has been identified as a debug information issue. This will be fixed with the future 16.0 Fortran compiler. You should be able to see the fix already with the next 16.0 BETA Update 1 release around beginning of May.
Georg Zitzlsberger
