Hey there,
since XDK 1878 there seems to be a new Issue (in private Chats other Intel XDK users have confirmed). I use Cordova and Intel XDK Plugins. Intel XDK "Device" Plugin will often not be included in the build. The Checkbox in "Projects" Tab is checked, but in the "intelxdk.config.ios.XML" it is not entered.
Then I have to open up the Project tab, unmark the Device-Plugin, mark it again, and re-build, after that procedure the Plugin is entered in the XML config.
After some Hours / some Builds it is removed again and I have to re-do.
Today I had to to it four times (in 3 hour development)...
- Tags:
- HTML5
- Intel® XDK
When will this be fixed, what is the work around, none of the XDK plugins appear to be copied to the plugins folder or update the (os).json file except the security one App Security API. This is stopping progress on app deployment.
Thanks, we are aware of the bug and are working to release a fix for it ASAP.
Confirm. Problem is solved now :)
Thanks a lot.
