Software Archive
Read-only legacy content
17061 Diskussionen
Forum software has wrong font style for <pre>
levicki
Geschätzter Beitragender I
2.358Aufrufe
Here in this forum writing
 used to give Courier New (aka fixed width) font. That is usefull for code snippets and now it gives regular proportional font at least for me. If someone changed that please change it back, thanks.
23 Antworten
Intel_Software_Netw1
2.055Aufrufe
Escalating this...
Lexi S.
IntelSoftware NetworkSupport
http://www.intel.com/software
Contact us
levicki
2.055Aufrufe
Thank you Lexi!
Oh by the way, could you tell them to fix this signature separating line as well? It is way too long, and the top and bottom margins are too small. Someone seems to be playing smart there in web design team trying to "prettyfy" things which are not to be touched. In my opinion it would be better to use "--" as the signature separator than the hr tag.
2.055Aufrufe
Done.
levicki
2.055Aufrufe
Sooo... any chance to get a fix any time soon? It is rather annoying to have to look at the code snippets in proportional font. Come on web admins, how hard is to fire up the Notepad and edit that CSS back to what it used to be?
levicki
2.055Aufrufe
Lexi, this forum software has bugs! Editing the post kills the attachment and it has to be reuploaded.
2.055Aufrufe
Confirmed -- submitting now...
(conversion of < > to html in title on edit also noted)
levicki
2.055Aufrufe
It is really beyond me why they changed
 style. Haven't they heard of "If it ain't broke don't fix it"?
levicki
2.055Aufrufe
Lexi what are those people in web administration doing?!? Now the edit button is gone! Can't Intel hire someone capable of administering simple forum instead of those amaters?
2.055Aufrufe
We're chasing it down... this one is likely a config issue rather than a design issue (since we admins can still edit), and itshould be quick and simple to fix if that's the case.
2.055Aufrufe
Hi Igor,
The EDIT button will only appear on your own posts while you are logged in. If you are logged in and do not see this button on your own posts, please empty all browser cookies and temporary files, close all browsers, and return to http://www.intel.com/software/forums and log in.
Warm regards,
Gina B.
Intel Software Network Support
email: ISN.support@intel.com
levicki
2.055Aufrufe
Now it is back again and I didn't have to delete cookies (thanks God for that). I sincerely hope it won't get any worse than this.
2.055Aufrufe
Do let us know if this works. I posted witha non-admin test account and was able to edit posts generated by that account.
-Lexi
levicki
2.055Aufrufe
Lexi, see my response above your post.
By the way (now that I have your attention) what is going on with
 font style? Why it is taking so long to fix?
Anonymous
Nicht anwendbar
2.055Aufrufe
Looks fine to me and there have been no updates to Forums or Forum code in some time.Letme peek around a bit..[
This is a test
 one space
   three spaces
Anonymous
Nicht anwendbar
2.055Aufrufe
With this post I have changed over my Profile Preferences:Site Options to use a different content editor.. In this case I am using the TemplatedFTB Templated Free Text Box editor This gives me a new button that I can use to paste code..
public class CategoryList : System.Web.UI.Page
protected System.Web.UI.WebControls.Literal head;
protected System.Web.UI.WebControls.Literal header;
protected System.Web.UI.HtmlControls.HtmlForm Form1;
protected System.Web.UI.WebControls.DataGrid data_gridCategories;
protected System.Web.UI.WebControls.DataGrid data_gridVideoList;
protected System.Web.UI.WebControls.Literal footer;
When I pasted this code it appears to have lost my tabs but lets see what it looks like when I click "Post"
Anonymous
Nicht anwendbar
2.055Aufrufe
Well in my last test with templatedFTB it appears that the paste button did lose some formatting when I took it from VS.Net directly and used the past C++ button on the menu bar.. Let me try two more options...
Here is code pasted from notepad that contains the tab characters and using the C++ code paste button.
[public class CategoryList : System.Web.UI.Page
Above looks pretty good when taken from Notepad and pasted into the RTF editor (we will have to see how it looks after the "post" though.
And here below I will manually put in the pre tags using the HTML editor
Let me post this and see the end result..
Anonymous
Nicht anwendbar
2.055Aufrufe
Ok I see the problem now.. The new Intel Headers use a style sheet called style.css which overriders the default style for the entire page.. I will continue to see how we can get the style.css file line 1 for the declaration of * {font-family:verdana,sans-serif;} disabled within the pages body content.. Give me a bit..
Anonymous
Nicht anwendbar
2.055Aufrufe
Isn't it up to the end user to add their own signature or not?
Anonymous
Nicht anwendbar
2.055Aufrufe
This is not a bug... HTML is strictly not allowed in the Subject and it can lead to XSS violations. We will not be making that change.
Anonymous
Nicht anwendbar
1.952Aufrufe
The pre and signatures are back to being close to normal. As we adjust the Intel.com headers and footers this kind of issue can easily crop up again but we will do our best to resolve and close on these items as fast as possible.
Cheers
Antworten
