Software Archive
Read-only legacy content
17061 Обсуждение
Framework7 Properties tab shows nothing, subpages not loading
Ashwin_P_
Начинающий
946Просмотр.
Before I start, I know framework7 has been deprecated, but I still chose to go with it because of it's iOS like UI which can be brought to the android platform. I won't make this mistake again.
Now, for the problem. I was creating a password management app for the purposes of learning and sharing. I was almost through with the project, except for a small bit. I created a new subpage, added input fields and buttons, gave them function calls, then when I came back to my designer, the UI looked a lot worse, and the properties of the elements were no where to be found in the properties tab. (Properties was empty)
I tried testing the app out on my device using the AppPreview, and the subpages wouldnt open. The same pages which were working fine a few minutes prior to this, weren't opening.
I tried running the index.html in chrome, and same. The url changed each time I clicked a button which was supposed to change the page, but the actual page itself never loaded. All I could see was the main page.
I really dont understand what has gone wrong, because the project was working super fine before I created the last subpage.
By the way, Not all properties are gone. The ones in the main page exist, but other page elements, don't.
I've included a list of screenshots which attest to my problem.
(PS: Nothing was wrong with my JS or HTML or CSS, everything was working fine till this happened. I can enclose my html/jss file if required)
532343
Thank You
0 баллов
4 Ответы
PaulF_IntelCorp
Сотрудник
946Просмотр.
I've asked a colleague to take a closer look.
Chris_P_Intel
Сотрудник
946Просмотр.
Can you .zip up the project ?  It's impossible to advise from screenshots.
Have you edited the HTML directly? Maybe something was done to make it unbalanced or invalid?  You can paste the code into http://validator.w3c.org to make sure it is well-formed.
Ashwin_P_
Начинающий
946Просмотр.
Here, Im enclosing the zip file for the complete project. I'll look into the link you've suggested too.
Thank you.
532474
Ashwin_P_
Начинающий
946Просмотр.
I used the w3c validator,
It seems that after creating the last subpage, everything within double quotes has been appended with a whitespace character.
Im sure I didn't do this manually. Is this a probable bug in the Designer? Thank you for your help anyway!
Ответить
