Software Archive
Read-only legacy content
17061 Discussions
Get Event Face Recognition
Septiadi_R_
How to find an event when a person's face is detected in the database? (C#)
Example
if(?????????){
Messagebox....
Bryan_B_Intel1
Does this help?
                            // Retrieve the recognition data instance
                            recognitionData = face.QueryRecognition();
                            if (recognitionData.IsRegistered())
                                userId = Convert.ToString(recognitionData.QueryUserID());
-Bryan
Septiadi_R_
Bryan Brown (Intel) wrote:
Does this help?
-Bryan
Thank you Bryan Brown..
how if I want to change userId from 1. because by default userId starting from 100?
PKusm
There is no such method to change the user ID, however there always workaround solutions to that matter:
1. You can make your own database which map the Intel RealSense user ID (100-based number) to your customized user ID in your application. By using this approach, you can change the user ID into any characthers (num/alpha).
2. If you the first approach is overkill for you, then you can just put 1 more line before displaying user ID in the UI of your apps: myUserID = realSenseUserID - 99; So that, the displayed user ID will always start from 1.
Hope it helps,
Cheers
gaston_b_
My question is that whenever I register a user it will always saves the user with userID = 100!
Even when I am using the sample software it will always identify as userID = 100.
What am I missing?
Lucas_M_2
I think it may have something to do with the Buffer.
Have you saved the buffer on your database as a Byte array and retrieved it?
