Software Archive
Read-only legacy content
17061 Discussions
Get Plataform
Leandro_M_1
Hello ,
I'm using the intel.xdk.device.platform method to check the version of the device
In debug it is working perfectly, but when compiling to machine the method does not.
John_H_Intel2
What device are you testing on? Did you build the app or testing with app preview? Did you select the intel.xdk.device plugin?
Leandro_M_1
Hi, I'm testing with app preview, and i have selected the plugin.
I'm testing in Android and IOS Device.
John_H_Intel2
Can you post a simplified version of your index.html file that is having the issue?
Leandro_M_1
Attached my index.html page.
Thank's.
Jure_C_
If you want to get device model and OS version you can also use Cordova plugin and just use:
device.model
device.version
John_H_Intel2
This works for me.
'Device Platform: '  + intel.xdk.device.platform ;
Try removing your .toLowerCase() and see if that helps.
Also, make sure you have enable the Intel XDK Device plugin in your settings.
