Software Archive
Read-only legacy content
17060 Discussions
Google Maps Widget
Andrejs_V_
Hi, All!
Is any tutorials for correct marker adding/modifying in Google Map widget?
I create 2 buttons in test projects
1 button for geolocation (I set up geolocation plug-in & and he is work ok)
2. set up new location
it's also ok
But when I try add marker(s) nothing happenns :(
google maps API key is and work ok
that's is my code for button1 & button2
 var longit=40.000;
 var latit=-100.000;
     /* button  My Location */
    $(document).on("click", ".uib_w_11", function(evt)
        /* your code goes here */
           navigator.geolocation.getCurrentPosition(function(position){
                longit=position.coords.latitude;
                latit=position.coords.longitude;
                alert('Latitude: '          + position.coords.latitude          + '\n' +
                      'Longitude: '         + position.coords.longitude
         return false;
        /* button  Button */
    $(document).on("click", ".uib_w_12", function(evt)
         var myLatlng = new google.maps.LatLng(longit,latit);
         var mapOptions = {
                        zoom: 4,
                        center: myLatlng
         var marker = new google.maps.Marker({
                position: myLatlng,
                title:"Hello World!"
         var mymap = googleMaps.getObjectBySelector('#gmap');
        /* Working code */
         mymap.setCenter(new google.maps.LatLng(longit, latit));
        /* Not working code */
         mymap.createMarker(marker);
         marker.setMap(mymap);
         return false;
Or, maybe  , any can to see how to use functions
createMarker
createMarkers
from google_maps.js ?
Thanks for answers
Pamela_H_Intel
Andrejs,
Take a look at the Geolocation sample app in XDK (PROJECTS: Samples and Demos --> General --> Geolocation Demonstration)
Pamela
Andrejs_V_
Thanks for answer!
I took a look at this sample. And I can manage map throought Googla MAPS JavaScript API.
But it is not so "visual" with "hand-make" <div for map> in App Designer enviroment.
May be any can put some samples for standart operation with widgets?
Create marker(s), Calculate distance , geocoding &etc. ?
Some simple samples ?
PaulF_IntelCorp
Andrejs -- our support is limited to helping you with the mechanics of debugging and building Cordova apps with the XDK. We are not staffed to provide samples and support for general HTML5 questions. For that we recommend you use StackOverflow, W3 Schools, HTML5 Rocks, etc.
