Software Archive
Read-only legacy content
17060 Discussions
iOS compile error with plugin com.hutchind.cordova.plugins.launcher
Gianluca_I_
Plugin: com.hutchind.cordova.plugins.launcher
version: 0.22
XDK works fine compiling for android but with iOS compiler it doesn't work.
https://github.com/nchutchind/App-Launcher-Cordova-Plugin
They wrote: iOS: Copy Launcher.h and Launcher.m to platforms/ios/<ProjectName>/Plugins
Maybe this is the problem?
I can't do anything by my side?
Gianluca
Rakshith_K_Intel
Can you attach the log generated from iOS build?
Gianluca_I_
Attached there is the log.
Thanks a lot for your help!
Gianluca
Rakshith_K_Intel
It's a compatibility issue with the plugin.
There is an open issue about the same compile error:
Try contacting the plugin developer
