Software Archive
Read-only legacy content
17061 토론
HAXM install fails on Windows 7 - "Failed to configure driver: unknown error. Failed to open driver"
Daniel_C_1
초급자
24,395 조회수
I'm running into an unknown error when trying to install HAXM on my machine(Windows 7, Intel Core i7-2600, Asus P8Z68-M motherboard).  I've checked my BIOS settings to ensure that virutalization is enabled, and my BIOS and drivers appear to be up to date.  We also have two other developers here with the same hardware setup who are able to install HAXM, so it seems like something that should work for me.
I found the haxm_install_log.txt file and have included it as an attachment.  I looked through the log and the Event Viewer, but haven't been able to figure out what else needs to be done.  Has anyone else run into this issue?
Dan
0 포인트
72 응답
Clinton_C_
초급자
4,498 조회수
I am having the same error, anyone still around that can help?
0 포인트
JLuna5
새로운 기여자 I
4,498 조회수
Hi, how can I solution this?
0 포인트
Clinton_C_
초급자
4,498 조회수
finally got it to work only after disabling hyper threading and using the install intelhxm.inf method as seen on this thread http://software.intel.com/en-us/blogs/2013/04/25/workaround-patch-for-haxm-installation-error-failed-to-configure-driver-unknown  It would have been nice for this link to have been posted in this thread earlier as that would haev saved me two days worth of work....
0 포인트
jizhou_j_
초급자
4,499 조회수
Hi, I tried multiple solutions online. Nothing works.
Can someone help me on this issue:"Failed to configure driver: unknown error. Failed to open driver"
I have attached log
0 포인트
Ionel_M_Intel
직원
4,499 조회수
@jizhou j. From your log I saw you are running Windows 7 with SP1 - build 7601. Right?
You can try this:
  1. Connect your computer to internet
  2. From command line run "certmgr.msc", go to “Trusted Root Certification Authorities” -> “Certificates”, ensure following certificate is there. If not existing, just wait for a while with computer connecting to internet, and it will be installed automatically
AddTrust External CA Root              AddTrust External CA Root             5/30/2020           Server Authenticati...          USERTrust
  1. After the above certificate is there, then run the HAXM installer.
0 포인트
Arnab_C_
초급자
4,499 조회수
Facing the same problem just my problem is a little above my head.
 In android studio first I installed intel haxm my OS is Windows 7.Everything was fine it was running correctly no installation errors. A few days later I formatted my Laptop (C Drive only) then again installed android studio now it is showing intel haxm is not installed. I tried to install it manually then it shows the error "Failed to configure driver: unknown error. Failed to open driver". I thought maybe my Intel Virtualization is disabled I checked the BIOS it was disabled then I enabled it but after that when I tried to install intel haxm the same error. Help me. Here is my install log file.
0 포인트
Bava_K_
초급자
4,499 조회수
plz help me..............
0 포인트
Ionel_M_Intel
직원
4,499 조회수
@Bava K. It will be helpful if you give more details: HAXM version, system configuration (CPU, OS version, RAM)
0 포인트
Bava_K_
초급자
4,499 조회수
help me..
give a link for me plz
0 포인트
Ionel_M_Intel
직원
4,499 조회수
Check you CPU on http://ark.intel.com/. VT-x is mandatory in order to install HAXM.
0 포인트
응답
