Software Archive
Read-only legacy content
17060 Discussions
.HTML to .APK, run on device stuck at Device Ready
James_F_2
I took a single .HTML file and exported it to a .APK.  Its on the device but all i get is a message saying "Apache Cordova Device is Ready.
This was a .HTML from Twine, a text based game maker.  About that, can any text based game maker (Quest, Twine, ADRIFT) have their files exported by Intel XDX into an .APK ?
PaulF_IntelCorp
Can you provide an example of the HTML file that is produced?
Amrita_C_Intel
I think you're not editing the right index.html file. If you are building for android then there is a index.html file located in assets/www folder. This is the file you should be editing to create the first screen of your android app.
Note: The www folder will be hidden by default, to make it visible goto Project -> Properties -> Resource -> Resource Filters in Eclipse and remove the exclusion filters.
For more information check this: http://codezag.com/apache-cordova-android-stuck-device-ready-screen/
Anusha_M_Intel1
If it is just html, it should work if imported into the XDK and exported into an APK.
What were the steps in adding this html file? Did you use a template and then just replaced the html file?
