Software Archive
Read-only legacy content
17060 Discussions
Help! i cant find the intel realsense consumer version?
Malfer_S_
No puedo encontrar la version del consumidor de la camara realsense... puedo comprar una version creador?
Do i can buy an SDK?
MartyG
The camera is only available on its own as a developer kit.  The consumer version is built into devices such as laptops, tablets and smartphones.  So you can only get the consumer version if you buy a device that it is built into.
Both the F200 and R200 cameras are out of stock in the Intel store right now and unavailable to buy.  A new next generation version of the F200 called the SR300 is coming in the first few months of 2016 though.
Spanish
La cámara sólo está disponible por sí misma como un kit de desarrollador. La versión de los consumidores está integrada en los dispositivos tales como laptops, tablets y smartphones. Así que sólo se puede obtener la versión de los consumidores si usted compra un dispositivo que se construye en.
Tanto el F200 y cámaras R200 están fuera de stock en la tienda Intel en este momento y no está disponible para comprar. Una nueva versión de la próxima generación de la F200 llama el SR300 está llegando en los primeros meses de 2016, aunque.
Malfer_S_
Thank you! anothers question!
Can i buy the SDK? what happens if i buy it? Is the SR300 for consumers?
MartyG
The SDK is is the software that runs the camera.  That part is free and can be downloaded from the Intel website.
https://software.intel.com/en-us/intel-realsense-sdk/download
The part that costs money is the camera (the hardware).is just called the Developer Kit (no software in the name).  If you buy the Developer Kit camera hardware when it is in stock then it will be delivered to your address.  Both the F200 and R200 can be shipped to Spain, according to the store listings.  For the F200 it says Spain specifically, and for the R200 it says "EU".  And Spain is in the EU.  :)
The SR300 is also a Developer Kit.  The consumer version will be put by manufacturers in devices such as laptops.
Malfer_S_
what you meant with that sdk that this part is free and that witth the SDK is just the software that run the camera... you meant it can be use it without work for intels company or without contract with intels company?
MartyG
The RealSense Developer Kit cameras can be used by any person or company, yes.  You do not need a licence from Intel.  You can also use the camera for commercial projects and this is encouraged by Intel.
I do not know what the arrangement is for integrating the bare circuit board version of the cameras into devices that a company you work for might manufacture.  I guess you would have to talk to Intel about that.  Here is an image of the circuit board version of the R200 camera.
http://notebookitalia.it/images/stories/intel_realsense_3d_camera_2014/intel_realsense_3d_camera.jpg
There are two versions in the picture, a large and small one, because the large one has recently been replaced by a smaller version that can fit inside a smartphone casing.
But if you want to use the Developer Kit versions of the cameras in your projects, you do not need a licence arrangement with Intel for that.  :)
Malfer_S_
Thank you
