Software Archive
Read-only legacy content
17060 Discussions
Help with database
Jasmine_Jeyakani_I_
     Is it possible to connect to Sql server using javascript??
    If not so, then what is the solution to connect to sql server??
Hamilton_Tenório_da_
Valued Contributor I
Where is the SQL server? Probably you will need a web service hosted on the net to answer your requests.
Amrita_C_Intel
You can use one of the following methods for using database:
1- Using HTML5 client side databases. HTML5 provides four different types of Storage of data on a local client's machine. They are
Local Storage. Web SQL Storage. Session Storage Indexed DB
It depends on your demands you can use one of them. If you need a persistent database for saving values less than 5 Mb, I recommend you LocalStorage as implementation of that is very easy. The data you saved in HTML5 localstorage will not be deleted even in case of phone shut down or reset. The data will be deleted only when you remove it by localStorage.removeItem(); Client side database is not recommended if you have huge amount of data or you need a central database which you should show to everybody who use this app in the world. in these cases its better, you use server side database
You can read a very nice article about how to use html5 local databases in XDK website:https://software.intel.com/en-us/articles/html5-local-storage
2- You can use server database like MySQL or SQL server. however you need to connect your html codes to a PHP or asp.net script in a server by AJAX. You may use JSON for transfer data from PHP in server side to JS in the client side.
3- You can use cloud databases like Parse.com however there are some limitation depends of pricing plan you choose.
