Software Archive
Read-only legacy content
17061 ディスカッション
How do I remove the Intel XDK Product development
charles_o_
ビギナー
506件の閲覧回数
How do I remove this from appearing anytime my app comes up during testing.
0 件の賞賛
2 返答(返信)
Swati_S_Intel1
従業員
506件の閲覧回数
You can put your custom splash screen through Projects > Launch Icons and Splash Screens
Anusha_M_Intel1
従業員
506件の閲覧回数
If you are testing on the emulator, open the "Device and Network Settings" section on the right side panel in emulator tab, there is an option to uncheck "simulate splash screen".
To remove splash screen in the app build, you have add this and call it in device ready:
app.hideSplashScreen = function() {
    "use strict" ;
    // see https://github.com/01org/appframework/blob/master/documentation/detail/%24.ui.launch.md
    // Do the following if you disabled App Framework autolaunch (in index.html, for example)
    // $.ui.launch() ;
    if( navigator.splashscreen && navigator.splashscreen.hide ) {   // Cordova API detected
        navigator.splashscreen.hide() ;
    if( window.intel && intel.xdk && intel.xdk.device ) {           // Intel XDK device API detected, but...
        if( intel.xdk.device.hideSplashScreen )                     // ...hideSplashScreen() is inside the base plugin
            intel.xdk.device.hideSplashScreen() ;
返信
