Software Archive
Read-only legacy content
17060 Discussions
How to add to the AndroidManifest.xml file - Plugin installation
Daniel_B_9
I am trying to install the following plugin. https://github.com/mrwutong/cordova-qdc-baidu-push
In order for it to work, I must add
android:name="com.baidu.frontia.FrontiaApplication"
to the application tag of the AndroidManifest.xml file. Is this possible?
Thank you for your time.
Brandon_K_Intel
Have you tried adding your third party plugin through the build settings in the project tab? This would be my first suggestion.
Daniel_B_9
Sorry for not specifying.
I've added the plugin successfully, and it compiles to android without a problem (after I modified one of the .java files of the plugin).
The problem is that the app crashes frequently. Every few minutes, I get a dialog on my phone saying "Unfortunately ____ has stopped working". However, the app window stays open and responsive. So I'm assuming that this the Baidu push plugin crashing in the background.
Anyway, as part of the plugin installation, I'm supposed to modify the AndroidManifest xml. How do I do this in xdk?
Anusha_M_Intel1
Hi Daniel,
Check out Question 14 on our FAQs page. It answers your question.
https://software.intel.com/en-us/xdk/faqs/general
Q14: Is it possible to modify Android* Manifest through Intel XDK?
