Software Archive
Read-only legacy content
17060 Discussions
How to compile a program with Intrinsic on MIC
Feng_L_
I tried to compile a program with intrinsic such as "_mm512_load_ps(...)" on MIC using icc compiler.  But i meet a problem with the code below.
#pragma offload_attribute (push,target(mic))
#include "immintrin.h"
#pragma offload_attribute (pop)
_d_wt=_mm512_load_ps (&Random_matrix);
_Xk=_mm512_add_ps(_mm512_set_1to16_ps(X),_d_wt);
When i tryed to compile the code, i got the information:
ThetaScheme.o: In function `current_solution':
ThetaScheme.c:(.text+0xd86): undefined reference to `_mm512_load_ps'
ThetaScheme.c:(.text+0xda1): undefined reference to `_mm512_set1_ps'
Should i link some special library or do some extra work to compile this kind of program ?
Thank you !
Kevin_D_Intel
The undefined references occur when linking for the host-side since those do not exist for the host. You would conditionalize the use in the offload code with:
#ifdef __MIC__
<Phi intrinsic code here>
#else
<Host side equivalent code here>
#endif
If you have not already, look at the C sample under:
/opt/intel/composer_xe_2013/Samples/en_US/C++/mic_samples/intro_sampleC/sampleC006.c
Feng_L_
#ifdef __MIC__
#else
#endif
Thank you a lot!  It compiled the program successfully.
Feng_L_
  Thanks for the reply above,but i have a new problem. When i use "__mm512_store_ps(...)" (or other functons like this) to store data to an array ,i got an error when i run the program.
      offload error: process on the device 0 was terminated by signal 11
      And the code:
      void function(...)
      static float __attribute__((target(mic),aligned(64))) d_wt[BLOCKSIZE*THREADSNUM] ;
      #pragma omp parallel for  private(... ,start,_d_wt,...) schedule(dynamic,1)
      _d_wt=_mm512_loadunpacklo_ps (_d_wt, (void*)(&Random_matrix)  );
      _d_wt=_mm512_loadunpackhi_ps (_d_wt, (void*)(&Random_matrix)  );
      //_d_wt=_mm512_load_ps (&Random_matrix);
      _mm512_packstorelo_ps((void*)(&d_wt[start])   , _d_wt );
      _mm512_packstorehi_ps((void*)(&d_wt[start+16]), _d_wt );
      // ------>   start= 16 * omp_get_thread_num();
      //_mm512_store_ps(d_wt,_d_wt);
      I wonder why this happened.Thanks.~
Kevin_D_Intel
Many times this indicates accessing outside available memory; could be due to insufficient allocation for variables used in the offloaded code. Inspect the variables used in the offloaded code to ensure sufficient memory is allocated and they are decorated accordingly for access in offloaded code. Because it is not obvious from the code snippet, check that Random_matrix it is declared accordingly for access within offloaded code.
Feng_L_
Thank you . I have checked the Random_matrix . It seems ok . I write a new program to show the problem. There are two cases. In case two,i use an usual method to calculate,and there is no error . In case one,i use "_mm512_store_ps" to store data to array. But i got the same error "offload error: process on the device 0 was terminated by signal 11" I also try to use "_mm512_store_ps((void*)(&B),_C);" instead of "_mm512_store_ps((void*)(&X),_C);" to store data to array B. But i still got the same error.I pasted all code below .
#include <stdlib.h>
#include <stdio.h>
#define SIZE 1024
#define CASE1
//#define CASE2
void calculate(float* A,float* B)
        static float __attribute__((target(mic),aligned(64))) X[SIZE] ;
         int k,i;
        __m512 _A;
        __m512 _B;
        __m512 _C;
      #ifdef __MIC__
        for(k=0;k<SIZE;k+=16)
                _A=_mm512_load_ps((void*)(&A));
                _B=_mm512_load_ps((void*)(&B));
                _C=_mm512_add_ps(_A,_B);
                #ifdef CASE1
                #endif
                for(i=k;i<k+16;i++)
                        #ifdef CASE2
                        X=A+B;
                        #endif
                        printf("%2.f ",X);
                printf("\n");
        #endif
int  main()
        int i;
        float *A;
        float *B;
        A=(float*)malloc(sizeof(float)*SIZE);
        B=(float*)malloc(sizeof(float)*SIZE);
        for(i=0;i<SIZE;i++)
                A=i;
                B=i;
        #pragma offload_transfer target(mic:0)\
        in(A:length(SIZE) alloc_if(1) free_if(0))\
        in(B:length(SIZE) alloc_if(1) free_if(0))\
        #pragma offload target(mic:0) \
        in(A:length(0) alloc_if(0) free_if(0))\
        in(B:length(0) alloc_if(0) free_if(0))
        calculate(A,B);
        return 1;
Kevin_D_Intel
Appears A and B are not 64-byte aligned. Try _mm_malloc:
A=(float*)_mm_malloc(sizeof(float)*SIZE,64);
B=(float*)_mm_malloc(sizeof(float)*SIZE,64);
Feng_L_
Thank you very much!
Problem was solved with your advice!
