Software Archive
Read-only legacy content
How to export whole conversation of closed issues from Intel Premier Support
jerryleo
Just wondering how to export whole conversation of closed issues from Intel Premier Support instead using ctrl+c & ctrl+v?
Thanks for your time
Jerry
Devorah_H_Intel
In the Issue window there is a button 'email as PDF' in the upper left and lower left corner. When clicking this button an email is sent to you with the ticket, including communication log, as PDF attachment.
Devorah H.
Intel®Developer Support
jerryleo
Thanks for your reply.
Failed to find the 'email as PDF'  button.
Here are what I did
Log into businessportal.intel.com
Intel premier support home - recently closed issues
click an issue title
pop-up an 'View Issue' window
Only two buttons are avaiable "cancel" and "Re-Open this Issue".
Already tried with Firefox, IE and Chrome. checked everywhere on the web page.  Failed to find any button which could be used to export the conversation.
Did I still miss something ?
James_T_Intel
Hi Jerry,
Please send me a private message with the email address you use on Intel® Premier Support.  The export ability is only enabled for certain accounts.  I can check yours to see if it is enabled and if I can enable it.
