Software Archive
Read-only legacy content
How to find a situation that became an error on cordova.js
Hamilton_Tenório_da_
Valued Contributor I
I am receveing an error on line 729 of cordova.js. I am trying to debug to understand the reason, but I can´t find the problem.
I inserted some messages on log to understand where is occuring, but I am not luck. It seems that the error is out of the init.js file.
See the image with the messages:
Does someone knows what is it?
Amrita_C_Intel
Can you provide the code via .zip file?
Pamela_H_Intel
It sounds like you call a function that requires a function as its first argument. If you are using any new plugins, check their APIs to see if you have your argument lists specified correctly.
@Amrita> I sent the link in private
@Pamela> I continue searching, thank you for this suggestion.
Amrita_C_Intel
I cant see any link. Can you please resend me?
OK, I send it again to you in private
