Software Archive
Read-only legacy content
17060 Discussions
How to get wide screen 1366x720 resolution out of my external VGA port of my Intel 945 notebook graphic card.
test86
I have a Toshiba M115-S3094 laptop and it has an Intel 945 GPU.
My laptop's monitor's resoution is 1280x800 and its working perfectly.
The problem is where I'm using VGA cable to use with my 32" Samsung LA32R71 TV, where I can just get 4:3 resolutions and that results in stretched images.
I tried t driver called win2k_xp14324bb.exe that was for a similar problem, but I still can't choose a 16:9 resolution for my extended monitor.
I read online and they say things about EDID, I was curious to know if my external display gives proper EDID to my GPU but I have no idea how to test it.
Aaron_B_Intel
If your EDID is available,it will be in a Diagnostics Report. Do the following and post it here:
Open the Intel Graphics Tray. Click on the Information button. Click "Save To File".
test86
here it is:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 04/03/2009
Report Time[hr:mm:ss]: 22:34:25
Driver Version: 6.14.10.4926
Operating System: Windows XP* Professional, Service Pack 3 (5.1.2600)
Default Language: English
DirectX* Version: 9.0
Physical Memory: 1013 MB
Minimum Graphics Memory: 8 MB
Maximum Graphics Memory: 128 MB
Graphics Memory in Use: 13 MB
Processor: x86 family 6 Model 14 Stepping 8
Processor Speed: 1595 MHZ
Vendor ID: 8086
Device ID: 27A2
Device Revision: 03
* Accelerator Information *
Accelerator in Use: Mobile Intel 945 Express Chipset Family
Video BIOS: 1398
Current Graphics Mode: 1280 by 800 True Color (60 Hz)
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
Non Active Televisions: 1
* Television *
Monitor Name: Generic Television
Display Type: Analog
Gamma Value: 1.0
DDC2 Protocol: Supported
Maximum Image Size: Horizontal: Not Available
Vertical: Not Available
Monitor Supported Modes:
640 by 480 (60 Hz)
720 by 480 (60 Hz)
720 by 576 (60 Hz)
800 by 600 (60 Hz)
1024 by 768 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
* Notebook *
Monitor Name:
Display Type: Digital
Gamma Value: 2.20
1280 by 800 (60 Hz)
Raw EDID:
00 ff ff ff ff ff ff 00 32 0c 00 c0 00 00 00 00
00 10 01 03 80 1e 13 78 0a c4 40 95 58 56 8a 28
25 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 bc 1b 00 a0 50 20 17 30 30 20
36 00 30 be 10 00 00 18 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 fe 00 4c
47 50 68 69 6c 69 70 73 4c 43 44 0a 00 00 00 fe
00 4c 50 31 34 31 57 58 31 2d 54 4c 42 34 00 8b
* Other names and brands are the property of their respective owners.
I tried PowerStrip to add 1360x768 resolution with info I got from my TV's manual but that resolution is not available in my display properties of second monitor.
Aaron_B_Intel
Yeah, that's not much help. :(
I'd try the DTD trick listed elsewhere here (in the sticky thread at the top of this forum) with the following settings (found these in a Linux modeline for a model which is not identical to your but is similar):
84 21 50 B0 51 00 1B 30 50 70 36 00 00 00 00 00 00 1E
test86
I love you!
YESSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS
FINALLY
yessssssssssssssssssss, those magical numbers with that magical DTD software solved my problem!
I LOVE YOU!
WOW
Now I can watch pix with my TV without that stupid stretching! YAAAAAAAAAAAY!
The settings you gave me seem perfect and have no flick or whatnot, but I'm going to use my manual's settings to see if its different:
resolution 1360x768
Vertical freq. 60.015
Horizontal freq. 47.712
Pixel Clock Freq. 85.800
Polarity +/+
I was going to build a string like that you gave me (is it DTD? or EDID? I donno) but it seemed that it needs more data.
one last thing, is it possible to have a .reg file to fix this instead of using the DTD software everytime I change windows?
p.s. I love you!
Aaron_B_Intel
The EDID is the information passed from your monitor to the graphics driver on request (which in this case was not coming over for whatever reason). A DTD is a "detailed timing descriptor" which is optionally included in the EDID. As you've noticed, it includes a lot more information than just the vertical and horizontal refresh rates, syncs, and pixel clock. Pixel clock is in most ways the crucial parameter, so since I couldn't find a copy of your EDID on the Web I looked for a Linux modeline for your monitor or a slightly similar one with the same pixel clock.
The Ubuntu forums had one with 85.8 MHz for a different Samsung model, and I figured it was close enough-- apparently I was right. I typed the Modeline data into DTDCalc and it computed the DTD.
You can construct a .reg instead of using DTDCalc each time, but different versions of Windows sometimes locate the TotalDTDCalc and DTD_1 entries in different places in the registry, so just be aware it may not work as well.
chsum
Quoting - test86
I love you!
FINALLY
I LOVE YOU!
WOW
resolution 1360x768
Polarity +/+
p.s. I love you!
First off congradulations on your solution. I have the same problem to my tv. I can't seem to find that magical DTD software on this thread. Could you tell me where I can find it? Thank you very much
chsum
Hi there. I have a Samsung PN42B450. IT's a 42" 720P and I have the same 1024x768 widescreen stretched problem. Could you tell me where I can go about modifying the DTD? Thank you.
