Software Archive
Read-only legacy content
17060 Discussions
How to protect code from triggering MIC build on non-MIC nodes
tjahns
we have two clusters in-house, one with MIC cards and another without. When we build code with OpenMP 4.x pragmas or functions for devices, we get a compilation error on the cluster without MIC cards:
icc: warning #10362: Environment configuration problem encountered.
Please check for proper MPSS installation and environment setup.
testomp.c(1): catastrophic error: *MIC* cannot open source file "stdio.h"
   #include <stdio.h>
This happens with Intel icc 14.0.3 and 15.0.2. The problem with stdio.h is just an example of missing headers, other compilations fail for different reasons because the MPSS is not installed on the non-MIC cluster. Both clusters use Linux, RHEL6 in the non-MIC, CentOS 6 in the MIC case.
What #ifdefs need to be in place to build the same code on the non-MIC cluster as well as the MIC cluster?
Perhaps I should add: the code portions triggering the error are already protected by
#if _OPENMP >= 201307
#endif
Regards, Thomas
Kevin_D_Intel
This may not require any special #ifdef's. Can you try compiling on the cluster without Xeon Phi cards using: -qno-openmp-offload
This disables the OpenMP 4.x offload compilation; there is more information here in the C++ UG. This option was first introduced in 15.0 with initial support for OpenMP 4.x offloading. It would not be available in 14.x but then neither is the OpenMP 4.x offloading support.
When using the Intel Language Extensions for Offload, there is a similar variant available of: -qno-offload  described in the UG here.
Kevin_D_Intel
I stand corrected. This option was available in 14.x so perhaps if it delivers the functionality you need then it would be usable with 14.x also. Sorry for the confusion.
tjahns
Unfortunately, no-offload doesn't seem to make a difference:
$ icc -O2 -qno-offload -fopenmp testomp.c
icc: warning #10362: Environment configuration problem encountered.  Please check for proper MPSS installation and environment setup.
  #include <stdio.h>
compilation aborted for testomp.c (code 4)
I'd like to post the code here, but even when it's trivial I'll need to get permission from the author first, who is going to be around again on Monday.
Regards, Thomas
Kevin_D_Intel
The -no-offload (-qno-offload in 15.x and later) option will only apply when using Intel's offload language extensions. If you are using the OpenMP 4.x TARGET device constructs then use the OpenMP specific form of the option: -qno-openmp-offload
It should work from what I'm seeing.
$ icc -V
Intel(R) C Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 14.0.5.212 Build 20150212
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
$ icc -c t2.c -fopenmp -openmp-offload
$ icc -c t2.c -fopenmp -no-openmp-offload
t2.c(8): warning #3180: unrecognized OpenMP #pragma
  #pragma omp target
Note the 14.x compiler had not adopted the leading "q" in the option. That came in 15.x and later.
tjahns
That still doesn't work for the test program I have here:
  #include <stdio.h>
The program is simple, please see the uploaded attachment. omp_get_num_devices() seems to have a different effect on the compiler than having a target construct.
Ravi_N_Intel
The problem is omp_get_num_devices().  Using this triggers compilation for the target.  We have a bug failed against this which we will address so when -qno-openmp-offload  is used and have omp_get_num_devices() in the code we will not trigger target compilation.
For now try this
#ifdef NOCARD
#define OMP_GET_NUM_DEVICES   0
#else
#define OMP_GET_NUM_DEVICES omp_get_num_devices()
#endif
and in your code
fprintf(stderr, "  max_threads = %d\n", OMP_GET_NUM_DEVICES);
when compiling in environment where MPSS is not installed -DNOCARD -qno-openmp-offload -qopenmp
Ravi
Kevin_D_Intel
Thank you for the example. This looks like a compiler defect. omp_get_num_devices() is a host-side routine so I would not expect it to trigger the target compilation which it what happens and leads to the error.
This was reported earlier to Development (see internal tracking id below).
(Internal tracking id: DPD200364738)
<Updated> As Ravi noted, this was reported earlier and we will have this fixed in a future release.
