Software Archive
Read-only legacy content
17060 Discussions
offload error: cannot release buffer memory on device 0 (error code 14)
TaeHyeok_J_
I need your help.
I tried to run K-means algorithm on Xeon Phi by using offload mode.
But when i tried to get into offload region with the clause '#pragma offload ~~ (as attached pic 1) ' ,
i got an erorr 'offload error: cannot release buffer memory on device 0 (error code 14)' .
I have no idea to solve this problem, and i even cannot find any previous example similar to my problem on google.
I saw offload report by using 'export OFFLOAD_REPORT=3', but i couldn't get any hints.
plz help me !
regards
TaeHyeok, Jang
Ravi_N_Intel
Move the allocation of clusters before  the #pragma offload target.  clusters is not allocated on the host to bring back the values computed on the card.
clusters = (float*)malloc(numclusters*numdim*sizeof(float));
        assert(clusters != NULL);
#pragma offload target .......
Kevin_D_Intel
I cannot see the entire offload construct in your code and am unable to re-create the error in my mockup of what portion I can see. Can you attach the complete program that is failing so we can investigate using that?
Also, please let us know what version of the C++ compiler and MPSS you are using. Thank you.
Kevin_D_Intel
My suspicion is the error relates to clusters and its use in out() but without any host-side allocation.
TaeHyeok_J_
/* jth_off_kmeans.c */
#include <stdio.h>
#include <stdlib.h>
#include <math.h>
#include <omp.h>
#include "kmeans_1d.h"
#include "offload.h"
#define ALLOC alloc_if(1) free_if(0)
#define FREE alloc_if(0) free_if(1)
#define REUSE alloc_if(0) free_if(0)
#ifndef MIC_DEV
#define MIC_DEV 1
#endif
__declspec(target(mic))
__inline static // O(n)
float* compute_dist(int numdim, int numobjs,
                        float *objects, // objs [numdim][numobjs]
                        float *clusters, // centroid [numclusters][numdim]
                        float *dist_new,
                        int cluster_num
        int i, j;
        int jth_temp = 0;
        #pragma omp parallel for\
                private(j)\
                shared(dist_new)
        for(j=0;j<numobjs;j++)
                dist_new = 0;
        // dist calculation
        for(i=0;i<numdim;i++)
                        private(j)\
                        shared(dist_new, objects, clusters)
                        dist_new+=(objects[i*numobjs+j]-clusters[cluster_num*numdim+i])*(objects[i*numobjs+j]-clusters[cluster_num*numdim+i]);
       // sqrt operation
                private(i)\
                shared(dist_new)
        for(i=0;i<numobjs;i++)
                dist_new = sqrt(dist_new);
        return dist_new;
float* jth_off_kmeans(float *objects,// [numobjs][numdim],
                  int numdim,
                  int numobjs,
                  int numclusters,
                  float threshold,
                  int *membership, // [numobjs]
                  int *loop_iterations,
                  int xeon_threads)
        /* var declartion */
        int i, j;
        int num_of_iterations = 0;
        int xeon_threads_num = xeon_threads;
        char signal_1;
        char signal_2;
        char signal_3;
        char signal_4;
        float *clusters;
        float *dist_new;
        float *dist_old;
        float *dist_tmp;
        float *new_clusters;
        int *clusters_size;
        int *membership_xeon_phi;
        printf("test 01\n");
        printf("test 02\n");
#pragma offload target(mic:MIC_DEV) \
        signal(&signal_3) \
        in(objects : length(numobjs*numdim) alloc_if(1) free_if(0))\
        nocopy(dist_new, dist_old, dist_tmp, new_clusters, clusters_size, membership_xeon_phi : alloc_if(0) free_if(0))\
        out(clusters : length(numclusters*numdim))
{ /* start of Xeon Phi section */
        printf("test 02.4\n");
        /* set the number of xeon phi threads */
        omp_set_num_threads(xeon_threads_num);
        membership_xeon_phi = (int*)malloc(numobjs*sizeof(int));
                membership_xeon_phi = 0;
        /* var declaration */
        float delta;
        printf("test 02.5\n");
        /* memory allocation */
        new_clusters = (float*)malloc(numclusters*numdim*sizeof(float));
        assert(new_clusters != NULL);
        clusters_size = (int*)malloc(numclusters*sizeof(int));
        assert(clusters_size != NULL);
        dist_new = (float*)malloc(numobjs*sizeof(float));
        assert(dist_new != NULL);
        dist_old = (float*)malloc(numobjs*sizeof(float));
        assert(dist_old != NULL);
        dist_tmp = (float*)malloc(numobjs*sizeof(float));
        assert(dist_tmp != NULL);
      printf("test 03\n");
        /* initialization of clusters_size[], new_clusters[] */
        for(i=0;i<numclusters;i++)
                clusters_size = 0;
                for(j=0;j<numdim;j++)
                        new_clusters[i*numdim+j] = 0;
        /* initialization of centroids as random objects */
                for(j=0;j<numclusters;j++)
                        clusters[numdim*j+i] = objects[i*numobjs+j];
 //     for(j=0;j<numdim;j++)
 //             clusters_phi = clusters[0*numclusters+j];
        /* initialization of dist_new with centroid[0] */
        dist_new = compute_dist(numdim, numobjs, objects, clusters, dist_new, 0);
        /* initialization of dist_old as a dist_max */
        float dist_max = dist_new[0];
                if(dist_max<dist_new)
                        dist_max = dist_new;
                dist_old = dist_max;
        delta = threshold+1; // temp initialization for enterting while loop
        int temp = 0 ;
        printf("test 04\n");
       while(num_of_iterations++<5)
                delta = 0.0; // var checking for proportion of changed objs
                for(i=1;i<numclusters;i++)
                        int cluster_num;
                        cluster_num = i;
                        /* swap dist_tmp and dist_new */
                                dist_tmp = dist_new;
                        dist_new = compute_dist(numdim, numobjs, objects, clusters, dist_new, cluster_num);
                                private(j)\
                                shared(membership_xeon_phi, dist_old)\
                                reduction(+:delta)
                                if(dist_tmp<dist_old)
                                        membership_xeon_phi = i; // i means cluster index
                                        dist_old = dist_tmp;
                                        delta++;
                /* determine clusters_size */
                        clusters_size[membership_xeon_phi]++;
               /* centroids recalculation */
                                new_clusters[membership_xeon_phi*numdim+i] += objects[i*numobjs+j];
                                clusters[i*numdim+j] = new_clusters[i*numdim+j]/clusters_size;
                                new_clusters[i*numdim+j] = 0; // set back to 0
                delta = (delta)/(numobjs*numclusters);
                        clusters_size = 0;
        free(clusters_size);
        free(new_clusters);
        free(dist_new);
        free(dist_old);
        free(dist_tmp);
} /* end of Xeon Phi section */
        #pragma offload_wait target(mic:MIC_DEV) wait(&signal_3)
        printf("\n");
        *loop_iterations = num_of_iterations;
        return clusters;
TaeHyeok_J_
/* jth_off_main.c */
#include <stdio.h>
#include <stdlib.h>
#include <string.h>     /* strtok() */
#include <sys/types.h>  /* open() */
#include <sys/stat.h>
#include <fcntl.h>
#include <unistd.h>     /* getopt() */
#include <omp.h>
int      _debug;
/*---< usage() >------------------------------------------------------------*/
static void usage(char *argv0, float threshold) {
    char *help =
        "Usage: %s [switches] -i filename -n num_clusters\n"
        "       -i filename    : file containing data to be clustered\n"
        "       -b             : input file is in binary format (default no)\n"
        "       -n num_clusters: number of clusters (K must > 1)\n"
        "       -t threshold   : threshold value (default %.4f)\n"
        "               -p nproc           : number of threads (default system allocated)\n"
        "               -a                         : perform atomic OpenMP pragma (default no)\n"
        "       -o             : output timing results (default no)\n"
        "       -d             : enable debug mode\n";
    fprintf(stderr, help, argv0, threshold);
    exit(-1);
/*---< main() >-------------------------------------------------------------*/
int main(int argc, char **argv) {
           int     opt;
    extern char   *optarg;
    extern int     optind;
           int     i, j, nthreads;
           int     isBinaryFile, is_perform_atomic, is_output_timing;
           int     loop_iterations;
           int     xeon_threads;
           int     numClusters, numCoords, numObjs;
           int    *membership;    /* [numObjs] */
           char   *filename;
           float  *objects;       /* [numObjs][numCoords] data objects */
           float  *clusters;      /* [numClusters][numCoords] cluster center */
           float   threshold;
           double  timing, io_timing, clustering_timing;
    /* some default values */
    _debug           = 0;
        nthreads                 = 0;
    threshold        = 0.001;
    numClusters      = 0;
    isBinaryFile     = 0;
    is_output_timing = 0;
        is_perform_atomic = 0;
    filename         = NULL;
        xeon_threads = 0;
    while ( (opt=getopt(argc,argv,"p:x:i:n:t:abdo"))!= EOF) {
        switch (opt) {
            case 'i': filename=optarg;
                      break;
            case 'b': isBinaryFile = 1;
                      break;
            case 't': threshold=atof(optarg);
                      break;
            case 'n': numClusters = atoi(optarg);
                      break;
            case 'p': nthreads = atoi(optarg);
                  break;
            case 'a': is_perform_atomic = 1;
                  break;
            case 'o': is_output_timing = 1;
                      break;
            case 'd': _debug = 1;
                      break;
            case '?': usage(argv[0], threshold);
                      break;
            case 'x': xeon_threads = atoi(optarg);
                      break;
            default: usage(argv[0], threshold);
                      break;
    if (filename == 0 || numClusters <= 1) usage(argv[0], threshold);
    if (nthreads > 0)
        omp_set_num_threads(nthreads);
    if (is_output_timing) io_timing = omp_get_wtime();
   /* read data points from file ------------------------------------------*/
    objects = file_read(isBinaryFile, filename, &numObjs, &numCoords);
    if (objects == NULL) exit(1);
    if (is_output_timing) {
        io_timing         = timing - io_timing;
/* objects adjusted */
    float *temp_objects;
    temp_objects = (float*)malloc(numObjs * numCoords * sizeof(float));
    for(i=0;i<numObjs;i++)
        for(j=0;j<numCoords;j++)
                temp_objects[j*numObjs+i] = objects[i*numCoords+j];
    objects = temp_objects;
        clustering_timing = timing;
//      printf("omp get max threads num in main: %d\n", omp_get_max_threads());
//      printf("omp get num threads num in main: %d\n", omp_get_num_threads());
    /* start the timer for the core computation -----------------------------*/
    /* membership: the cluster id for each data object */
    membership = (int*) malloc(numObjs * sizeof(int));
    assert(membership != NULL);
                membership=0;
    clusters = jth_off_kmeans(objects, numCoords, numObjs, numClusters, threshold, membership, &loop_iterations, xeon_threads);
    free(objects);
        clustering_timing = timing - clustering_timing;
    /* output: the coordinates of the cluster centres ----------------------*/
    file_write(filename, numClusters, numObjs, numCoords, clusters,
               membership);
    free(membership);
    free(clusters);
    //wefwefwef
    /*---- output performance numbers ---------------------------------------*/
        io_timing += omp_get_wtime() - timing;
//        printf("\n **** jth off kmeans  ****\n");
/*              if (is_perform_atomic)
                        printf(" using atomic pragma ******\n");
                else
                        printf(" using array reduction ******\n");  */
        printf("Number of threads = %d\n", omp_get_max_threads());
        printf("Number of xeon threads = %d\n", xeon_threads);
        printf("Input file    : %s\n", filename);
//        printf("numObjs       : %d\n", numObjs);
//        printf("numCoords     : %d\n", numCoords);
        printf("numClusters   : %d\n", numClusters);
//        printf("threshold     : %.4f\n", threshold);
//      printf("loop iterations : %d\n", loop_iterations);
//        printf("I/O time           = %10.4f sec\n", io_timing);
//        printf("Computation timing = %10.4f sec\n", clustering_timing);
        printf("Computation timing per iteration = %10.4f sec\n", clustering_timing/loop_iterations);
    return(0);
TaeHyeok_J_
yeah, i found that there is an error on out() statement, but still don't know why. :(
compiler version gcc 4.4.7 .
mpss version 3.1.4.
thank you for your help in advance !
regards
TaeHyeok, Jang
Ravi_N_Intel
