Software Archive
Read-only legacy content
17061 Discussions
How to use ASP (Activer Server Pages) inside Intel XDK ?
Marcondes__Marcos
Where to put the files.asp ?
ISS works ?
thanks in advance
Marcos
www.conteudoanimal.com.br
John_H_Intel2
Your ASP pages need to be located on an external server, that your app can then communicate with. They can not reside in your app.
Marcondes__Marcos
Ok ....
My idea is to connect to mysql server .... how can I do it without ASP ?
John_H_Intel2
You will need to search for a sql cordova plugin. This one looks promising, but I have not tried it.
http://plugreg.com/plugin/MSOpenTech/cordova-plugin-websql
Marcondes__Marcos
How can I install the plugin on intel xdk ??
Michael_O_2
You can also use sqlite for this purpose.
Sample code:
var db = openDatabase("EduDB", "1.0", "Students", 200000);  // Open SQLite Database
function initDatabase()  // Function Call When Page is ready.
    try {
  if (!window.openDatabase)  // Check browser is supported SQLite or not.
            alert('Databases are not supported in this browser.');
        else {
       console.log("DB supoted");
            createTable();  // If supported then call Function for create table in SQLite
    catch (e) {
        if (e == 2) {
            // Version number mismatch.
            console.log("Invalid database version.");
        } else {
            console.log("Unknown error " + e + ".");
        return;
function createTable()  // Function for Create Table in SQLite.
    db.transaction(function (tx) { tx.executeSql(createStatement, [], showRecords, onError); });
