Software Archive
Read-only legacy content
17061 Discussions
How to use "mkl_mic_free_memory"?
Zoltan_P_
Dear all,
I would like to use AO and CAO. I could enable/disable AO and set max. memory, but mkl_mic_free_memory is not working.
Here is an example:
      dim = 1024*8
      allocate (A(dim*dim))
      allocate (B(dim*dim))
      allocate (C(dim*dim))
      write(*,*) mkl_mic_enable()
      write(*,*) mkl_mic_set_max_memory( MKL_TARGET_MIC, 0, 1024*1024*6 )
      CALL DGEMM('N','N',dim,dim,dim,1.0d0,
     &            A,dim,B,dim,1.0d0,C,dim)
      write(*,*) mkl_mic_free_memory(MKL_TARGET_MIC, 0)
      write(*,*) mkl_mic_disable()
!DEC$ OFFLOAD_TRANSFER TARGET( MIC:0 )
     & IN(dim)
     & IN(A,B,C: LENGTH(dim*dim))
My card has 8GB memory. If AO reservs 6GB memory, there is not enough memory for offload transfer, and it generates offload error (9/13/16). All mkl_mic_... function return with 0 err code. When max. mem. only 4GB, it's working.
Is there any mistake?
(composer_xe_2013_sp1.2.144, composer_xe_2013_sp1.2.144, composer_xe_2015.0.024)
Zhang_Z_
Please try set the env-variable OFFLOAD_ENABLE_ORSL=1. This tells automatic offload and compiler-assisted offload to synchronize their access to the coprocessor.
If this doesn't help then please submit a bug report.
Zoltan_P_
Thanks for the quick answer.
I try, but it's not working. I also try "AO-after-CAO", and it's also not working. It goes into an infinite loop.
Zhang_Z_Intel
Hello, I tried your test code. It actually worked fine. The problem is in the compile and link line. You didn't compile and link the code properly for CAO execution. See my modified script below.
#!/bin/bash
export OFFLOAD_ENABLE_ORSL=1
export OFFLOAD_REPORT=3
touch test1.f
ifort -i8 test1.f -c -I$MKLROOT/include -offload-attribute-target=mic -offload-option,mic,compiler," -L$MKLROOT/lib/mic -lmkl_intel_ilp64 -lmkl_core -lmkl_sequential"
ifort test1.o -L$MKLROOT/lib/intel64 -lmkl_intel_ilp64 -lmkl_core -lmkl_sequential -lpthread -lm -o test1
chmod +x test1
./test1
Zoltan_P_
What version of compiler did you use? Because your compiler line is incompatible with mine. "-extend_source" (long line) and "-I$MKLROOT/include/intel64/lp64/" ("use mkl_service") is necessary. And program goes into infinite loop at the AO stage AO is not working (CPU does the work) if I link "mkl_sequential". When I used  "mkl_intel_thread", so:
ifort -i8 -extend_source test1.f -c -I$MKLROOT/include -I$MKLROOT/include/intel64/lp64/ -offload-attribute-target=mic -offload-option,mic,compiler," -L$MKLROOT/lib/mic -lmkl_intel_ilp64 -lmkl_core -lmkl_intel_thread"
ifort test1.o -L$MKLROOT/lib/intel64 -lmkl_intel_ilp64 -lmkl_core -lmkl_intel_thread -lpthread -lm -o test1
I got the same error as previously with all three versions of compiler.
But, I use Debian, which is not supported OS, if I know it well. Maybe that's the problem, if you couldn't reproduce the error. I didn't mention it because I used AO and CAO separately without any problem.
