Software Archive
Read-only legacy content
17060 Discussions
I cant get the older version that I require Intel Fortran Compiler version 11.1 or 10.1
masithulela__fulufhe
I have bought Intel Cluster and Paprell Studios 2013. All I need is Intel Fortran Compiler version 11.1 or 10.1 but the problem is that this does not appear on the list of an OLDER version. I can only see both 2013 and 2011 version. Could you please help me? How do I go about this?
Thank you
FM
Milind_Kulkarni__Int
New Contributor II
when you login into the registration center. which products do you see in the 1st page. In the column "Product Subscription Information", yoiu will see "Intel® Visual Fortran Composer XE for Windows* (or Linux*)" . somewhere under Parallel Studio XE 2013 , I suppose. Click on the corresponding "Download latest update" column. It will take you to page. where you are presented with page listing Version, Update, Build date, etc.. I think in the Version: , you are not scrolling down to find the earlier versions, and the default one show 2013, 2011. Scroll down, and the older versions appear. Then, you can download. Hoping that wasd the problem in the first place.
Hello, I only see Version 2013 and 2011. See the attached file. Even if I sroll down there are no other versions listed. Please help. Regards FM
Hello, Forgot to upload the file...see the uploaded file. I only see Version 2013 and 2011. See the attached file. Even if I sroll down there are no other versions listed. Please help. Regards FM
New Contributor II
Still not got the file, as you did not upload. I see you have 2-products in registrationcenter. eval and stud versions. Did you purchase any COM license. also, if you purchased smething recently, did you register the product in the registrationcenter, so it knows about it. If not, do it and then try.
Hello, I Did not purchase any COM license? What is this for? Can I give you my serial number so that you can check if I am eligible to download old version like Intel Fortran Compiler 10.1 or 11.1?? Please help. Regards FM
New Contributor II
check "send author a message" and send the serial number, so i only able to view it.
