Software Archive
Read-only legacy content
I get lots of errors in MSVS2013 since the last software update
davidlofstrand
Hello Intel, I'm not sure I've posted in the right subforum here but I didn't find any subforum for Intel Parallel Studio XE Professional. I have a license for "Intel Parallel Studio XE Professional Edition for C++ Windows". I downloaded an upgrade from Intel Software Downloader and installed the updates available roughly a week ago. From that time on I get this error every single time I open a solution in MSVS2013: The 'IntelPackage' package did not load correctly *** check blabla\ActivityLog.xml Additionally every single time I right click a project in the solution I get this error: The 'IntelCppOptPkg' package did not load correctly *** check blabla\ActivityLog.xml I'm attaching the ActivityLog.xml here if you should need it. I don't know what to do to fix this issue. Do you have any suggestions? Best Regards, David
davidlofstrand
Hello again, Short update of what I've done to try to fix this issue. 1) Delete all content under: %LOCALAPPDATA%\Microsoft\VisualStudio\12.0\ComponentModelCache 2) Start Developer Command Prompt for VS2013 as admininstrator and: devenv /resetuserdata devenv /setup I still get the errors after executing these steps. Best Regards, David
Gilad_D_Intel
Did you figure out the problem ?
