Software Archive
Read-only legacy content
IOS App Preview
Alexander_F_
I very confused with this App for IOS Devices, before I noticed that intel doesn't work because I am getting every time the message intel is not defined and now I can test my app in IOS App Preview because said that can not download the app from the cloud and the app is already uploaded to the cloud.
Alexander_F_
I forgot this screen
Swati_S_Intel1
Try to uninstall XDK completely and re-install from xdk.intel.com.
Also make sure you have latest version of App Preview from App Store, try re-starting the App Preview. Sometimes it takes long to load the app from the App Center.
Alexander_F_
Ok I go to do that and I let you know
Thank You
Alexander_F_
Ok i reinstalled Intel XDK and update my App Preview from the App Store and nothing, the same issue, can't not download my app from the cloud, but in Android I can, let me tell you that I have an IPhone 6+ with the latest version of IOS.
Now what is the next step
Thank you
Swati_S_Intel1
Hi Alexander,
Looks like you are facing couple of issues. I saw your post from other other thread: https://software.intel.com/en-us/comment/1819953#comment-1819953. I tried your app with App Preview on iPhone 5S with iOS 8 and it works perfectly fine. So, your app is fine.
Now,  You mentioned and from the screenshot you are getting "missing application" error (you are not able pull the app in App Preview), but at the same time you also mentioned you get "Intel is not defined" in your app.
Can you clarify, are you still having trouble loading your app in App Preview? Or is that resolved and you are able to go past that and then getting "Intel not defined" error.
There is an bug with plugin selection - when you use emulator see the thread here : https://software.intel.com/en-us/forums/topic/545106
If you had used emulator before launching the app in App Preview then it might be possible your plugin is not included. So uncheck and check the plugins one more time and try App Preview without using emulator.
Swati
Alexander_F_
Ok, the problem with the App Preview is fixed, but I still getting intel is not defined in Cordova Android Build and In App Preview on Iphone 6+ I am getting undefined is not an object (evaluating intel.xdk.device.scanBarcode... please can you post here your html to compare with mine.. thank you.
Swati_S_Intel1
I'm using the same html and js files that you sent. The problem might be in the .xdk file. Please send your .xdk file to me. Also, do you have iOS 8.2? And for Android which version?
Swati
Alexander_F_
can send an email to alex240505@gmail.com and I send you the complete XDK project and you can see where is the problem
thank you.
Alexander_F_
Android 4.1.1
Iphone 6+ IOS 8.2
Alexander_F_
May be this is important but if everything works fine in your side and in my side I do it the same, what is the problem then could be the Intel XDK for OSX or I don't know if you are using Intel XDK for OSX too?
http://prntscr.com/6p5bgm
and the other point is that I can not run my app by USB because need an Android Device and when I connect my Iphone by USB to my computer and try to run my app said that is not device connected seems that this feature is only with Android Device, then I have to test my App in the phone with the App Preview App from Apple Store.
Thank you again
Alexander_F_
Any update with this
thank you
Alexander_F_
Please any update, I am waiting if you tested my xdk project and found the problem
Alexander_F_
Hey some body can help me with this issue,
SWATI S. (Intel) where are you, please help me.. I have to finish this project and the only problem that I have is this one
Thank You
Alexander_F_
Ok thank you to every body... I go to start develop in another tool because with Intel XDK nothing works only HTML and Jscript but nothing referent to intel.xdk or cordova... now I try to use cordova.inAppBrowser plugin.. I checked on project settings and when I try to invoke get the same cordova is not defined.. and when I try to invoke intel is the same intel is not defined... then my conclusion is that Intel XDK for OSX do not work and I spent a lot of time building this app thinking that the problem is mine.
Please when you fix all the issues for Intel XDK for OSX let me know and I go to develop in this tool again.
