Software Archive
Read-only legacy content
17061 토론
IOS Build failed XDK1878
Wesley_S_1
새로운 기여자 I
7,592 조회수
Whem i'm trying to build an ios app (on windows) the build failed. With the same code i have succesfully build a android app and windows phone app.
At the end of the log i get this:
2015-04-03 05:14:18.596 xcodebuild[97026:100b] CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 90. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
2015-04-03 05:14:18.598 xcodebuild[97026:100b] CFPropertyListCreateFromXMLData(): Old-style plist parser: missing semicolon in dictionary on line 90. Parsing will be abandoned. Break on _CFPropertyListMissingSemicolon to debug.
2015-04-03 05:14:18.599 xcodebuild[97026:100b] Unexpected character / at line 1
xcodebuild: error: Unable to read project '[APP NAME].xcodeproj'.
    Reason: Project .../App/platforms/ios/[APP NAME].xcodeproj cannot be opened because the project file cannot be parsed.
Command finished with error code 74: .../App/platforms/ios/cordova/build --release,--device
Error: .../App/platforms/ios/cordova/build: Command failed with exit code 74
    at ChildProcess.whenDone (/Developer/cordova/3.5.0-0.2.7/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
    at ChildProcess.EventEmitter.emit (events.js:98:17)
    at maybeClose (child_process.js:753:16)
    at Process.ChildProcess._handle.onexit (child_process.js:820:5)
0 포인트
1 솔루션
Heikki_E_
초보자
7,593 조회수
JOHN H. (Intel) wrote:
This means one of a couple things.
* your distribution cert is expired
* your distribution cert does not match your provisioning profile
* the appID you gave the XDK does not match what you created for your appID on Apples developer portal.
Thanks, I figured it out finally. Nothing wrong with provisioning profiles etc. I didn't realize that there's need to upload .cer file in build screen even everything is marked as OK on that screen. Then the build was successful.
원본 게시물의 솔루션 보기
0 포인트
39 응답
Wesley_S_1
새로운 기여자 I
4,374 조회수
The build failed for me, when i added all the launch icons and splash screens.
For that the build succeeded.
No when i'm trying to build an ios app( even a new blank one), it fails.
BTW, i missed the option to remove de lauch icons / splash screens.
Update: Tried to reproduce it, but now the build is a success..
0 포인트
John_H_Intel2
직원
4,374 조회수
@ David O
Please attach you build log.
@Wesley
Glad you got it working!
0 포인트
David_O_3
초급자
4,374 조회수
@ John
Here's my build log.
0 포인트
Erhard_S_
초급자
4,374 조회수
I have the same issue. I have an iOS build on the app store and even try to rebuild the source for that release and also get an issue. My build log is attached.
0 포인트
John_H_Intel2
직원
4,374 조회수
@David ~
Your build log looks odd. Can you try creating a new app, new provisioning profile and build just simple hello world app? Let me know if that works.
@Erhard ~
Yours is pretty simple. The provisioning profile does not match the cert. You will see this at the bottom of the log.
Check dependencies
Code Sign error: Provisioning profile does not match bundle identifier: The provisioning profile specified in your build settings (“AllRugby3Adhoc”) has an AppID of “co.za.allsportsa.rugby” which does not match your bundle identifier “co.za.ernic.AllRugbySA”.
CodeSign error: code signing is required for product type 'Application' in SDK 'iOS 8.0'
** BUILD FAILED **
0 포인트
David_O_3
초급자
4,374 조회수
@John
After building a new project, it builds just fine.
0 포인트
David_O_3
초급자
4,374 조회수
@John
To clarify, if I build a new project with no functions, it builds fine. If I build the application that I'm working on, I get the same build error as posted previously.
0 포인트
John_H_Intel2
직원
4,374 조회수
Why dont you copy your files from your original project to your new project then?
0 포인트
David_O_3
초급자
4,374 조회수
@John
I've tried that, however, I get the same error when I attempt to build the app.
0 포인트
John_H_Intel2
직원
4,374 조회수
Zip up your entire project file and send me a private message with a dropbox (or other) link so I can look at them.
You probably have files names with funky chars or something.
0 포인트
Carlos_L_
초급자
4,374 조회수
Hi I have this error in Log but I don't know how solved it! :
** BUILD FAILED **
The following build commands failed:
	CompileC build/Guest.build/Release-iphoneos/Guest.build/Objects-normal/armv7/CDVSound.o Guest/Plugins/org.apache.cordova.media/CDVSound.m normal armv7 objective-c com.apple.compilers.llvm.clang.1_0.compiler
(1 failure)
Command finished with error code 65: .../Guest/platforms/ios/cordova/build --release,--device
Error: .../Guest/platforms/ios/cordova/build: Command failed with exit code 65
    at ChildProcess.whenDone (/Developer/cordova/4.1.2/node_modules/cordova/node_modules/cordova-lib/src/cordova/superspawn.js:135:23)
thanks to help me!
0 포인트
PaulF_IntelCorp
4,374 조회수
@Carlos -- usually you have to look a little further back in the build error log to figure out what is actually causing the failure. The summary at the end of the error log generally reflects something else that happened earlier in the build. Start from the bottom and go backwards and you'll probably find what is really causing the problem.
0 포인트
John_H_Intel2
직원
4,374 조회수
I see you have several successful builds, so I assume you have it figured out?
0 포인트
Heikki_E_
초보자
4,374 조회수
My build failed to error:
	CodeSign build/device/Mixed\ Gravity.app
(1 failure)
Command finished with error code 65: .../MixedGravityIos/platforms/ios/cordova/build --release,--device
Error: .../MixedGravityIos/platforms/ios/cordova/build: Command failed with exit code 65
Any advices?
0 포인트
John_H_Intel2
직원
4,374 조회수
Attach the entire build log please.
0 포인트
Heikki_E_
초보자
4,374 조회수
I can't attach file here, I'm getting "You are not authorized to access this page." message.
Please download it from my dropbox: https://www.dropbox.com/s/v20z8vhondppqmz/intel_xdk_ios_build_error.txt?dl=0
0 포인트
John_H_Intel2
직원
4,374 조회수
Look towards the bottom of the log and you will see this:
    /usr/bin/codesign --force --sign DC579FE63BB328DEF7ACED29704618D876F454A6 --resource-rules=.../MixedGravityIos/platforms/ios/build/device/Mixed\ Gravity.app/ResourceRules.plist --entitlements .../MixedGravityIos/platforms/ios/build/Mixed\ Gravity.build/Release-iphoneos/Mixed\ Gravity.build/Mixed\ Gravity.app.xcent .../MixedGravityIos/platforms/ios/build/device/Mixed\ Gravity.app
DC579FE63BB328DEF7ACED29704618D876F454A6: no identity found
Command /usr/bin/codesign failed with exit code 1
** BUILD FAILED **
0 포인트
Heikki_E_
초보자
7,594 조회수
0 포인트
Ganesh_R_Intel
4,374 조회수
This thread is closed but available as a readable historical reference.
Please start a new thread if you have further questions.
0 포인트
응답
