I use an iframe in a page (intel xdk 3088, cli 5.4.1)
With android there is no problem.
With IOS, since 9.3.1, the iframe don't display anything.
Before ios 9.3.1, it works fine (ios 8 etc...)
It's ok in the emulator.
I don't found anything about this bug... and Apple reject the app because of this problem.
I have tried with http, https, // but nothing works.
- Tags:
- HTML5
- Intel® XDK
Thibaut -- this sounds like a whitelist issue. See the whitelist settings in the Build Settings section and follow the (i) links for more details.
What is the URL you are trying to bind into the iframe? Is it local to your app or remote?
What is the HTML of your iframe? Have you enabled any of the sandbox features?
The URL is remote :
For example :
<iframe src="https://www.youtube.com/..."></iframe>
what is it "sandbox features" ?
before ios 9.3.1, i have no problem with the iframe (youtube or other remote url)
Thank you Paul !
It comes from the whitelist indeed!
emulator works but of apps installed does not work !!
how you solved iframe with the youtube video on whitelist you added what?
iframe: * ??
thank you
you can explain to me thanks
Giuseppe -- iframes are difficult to work with in this environment, I recommend you use the InAppBrowser plugin, instead. If you are using an iframe, you'll need to whitelist the addresses the iframe accesses, not the iframe itself.
In the white list, you must have :
http://*/*
and/or
https://*/*
And after that, you have those lines in intelxdk.config.ios.xml :
<allow-navigation href="http://*/*"/>
<allow-navigation href="https://*/*"/>
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
