Software Archive
Read-only legacy content
Installation Error
Sajeesh_N_
I am trying to update my Intel XDK ( I am using minux ) and while installation its asking me root / sudo pasword. I gave the correct pasword but it still says authontication error. Please check your password.
Swati_S_Intel1
We do not support minux. Has it worked for you before? Officially XDK is supported on Windows, Mac and Ubuntu Linux.
Swati
PaulF_IntelCorp
Try starting the install script as root or using sudo. Might work better.
Gabriel_E_
Hi, I try upgrade to 1826 in my Linux Mint 16/64bits (i work with v1816) and i can do that: the installation  asking me root / sudo pasword. I gave the correct pasword but it still says authentication error.
PaulF_IntelCorp
First login as root, then start the install script. See if that works better.
