Software Archive
Read-only legacy content
17060 Discussions
Intel Parallel Studio XE Cluster Edition 2016 Installation problem
Venkat_Praveen_G_
Hello there!
I have previously installed a copy of Intel Parallel Studio XE 2016 Cluster Edition for Windows 10 64 bit, and worked fine with Integration to Visual Studio 2013. But I had to re-install Windows. Lately, I am having a problem installing the same, and have tried various approaches to combat this. It seems to be the installation of Visual C++ libraries. Below is a snippet of the error message:
Intel(R) Parallel Studio XE 2016 Update 3 Cluster Edition for Windows* Setup Wizard ended prematurely because of an error(s).
  Windows Installer failed to configure product:
    Error message: An error occured during the installation of assembly component 844EFBA7-1C24-93B2-A01F-C8B3B9A1E18E. HRESULT: 0x80073715.
    Error code: 1603
    File name: msvcrt_x64.msi
Installer logs location: C:\Users\GVPRAV~1\AppData\Local\Temp\pset_tmp_PSXE2016_Praveen\2016.07.14_17.53.35_00001ffc\log\
I had used Parallel Studio XE previously, and had installed without any issues. Your help in this matter would be most grateful.
Thanking You,
Praveen
Devorah_H_Intel
Hello Praveen,
This is a known Microsoft issue: https://support.microsoft.com/en-us/kb/2643995.  Please contact the MS Customer Support services and get the hotfix to get this issue resolved accordingly.
Please let me know if the above helps.
Light_Intel
This issue has been addressed. If you have a similar question please start a new thread to ensure your issue is being addressed in a timely manner.
