Software Archive
Read-only legacy content
17061 Discussions
Intel Registration Center unavailable
Andrea_P_2
Hi to all,since yesterdaythe addresshttps://registrationcenter.intel.com/RegCenter/NComForm.aspx?ProductID=1540
is not reachable.
The erroris as follows.
Server Error in '/RegCenter' Application.
Runtime Error Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="Off"/> </system.web> </configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File --> <configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web> </configuration>
Does anybody knowwhen itwill be restored?
Hubert_H_Intel
There was a temporary outage over the weekend. Pls. try again. The Intel(R) Registration Center should work correctly now. You may need to restart your computer to make the configuration settings to access the IRC working again.
Regards, Hubert
QIAOMIN_Q_
I can open this website with no problem ,it should be ok for you now.
Thank you. -- QIAOMIN.Q
Intel Developer Support
