Software Archive
Read-only legacy content
17061 Discussions
Intel XDK 2673 directory view
Mitchell_Franklin
Hi All,
Just downloaded the update 2673, not sure if this is just how it is now or bug but if you open an existing project or create a new project the directory overview is hidden from view on the left had side by the web services panel.
As an FYI you can get this if you select web services button and click on the agree warning this then allows the web services section to be placed down the bottom again and you can again see your files in the directory view.
Mitch
PPang2
Do you have a link to site where I can download v2673?
Hans_W_Intel
@Mitch. The Intel XDK remembers the last location of the Web Services panel when you exit.   So if the file list was obscured when you exited (due to the Web Services Panel being dragged to expand), it will be obscured when you restart the Intel XDK next time.  You can drag the Panel down to again view the file list.  Next time you start Intel XDK it should be visible as well.
@Pih Lung P.   You can download the Intel XDK at xdk.intel.com
