Software Archive
Read-only legacy content
17060 Discussions
Intel XDK error loading plugin?
Campuzano_Serna__Jua
XDK version 3641
Hi, I'm not sure if this is the right category for the message but there are so many categories that I'm not sure which one is the right one.
The thing is that XDK never finishes loading when I add this plugin:
Source: https://www.appodeal.com/sdk/documentation?framework=13&full=1&platform=1
The project is a test for android of the appodeal plugin, and exported with Cordova using Construct 2 and the new format of intel XDK, all correct, is failure is when adding that plugin.
Can this be solved?
Any information you can provide to help, please let me know.
Thanks and sorry for my english.
Shahab_L_Intel
Do you get an error message or XDK just hangs showing "Fetching Your Plugin" ?
I tried to add this plugin and it took some time, but finally loaded.
Hi, it was because the plugin occupies about 250 megs and my connection is not very fast, I thought maybe XDK was getting blocked, I already solved it with a less heavy plugin and it works fine.
Please excuse the inconvenience, thanks for the help !.
PaulF_IntelCorp
It appears to be a very large plugin, which is going to cause troubles during build. It took a very long time to install that plugin in a test app, net size was 609MB, our build system only handles about a 400MB build package, so just adding that plugin may cause troubles when it comes time to build.
Rather than pulling the plugin in via the git repo, try pulling it in via the registry. The registry name of that plugin is com.appodeal.plugin. However, as far as I can tell, that version only contains code for Android, it appears to be missing the iOS parts.
