Software Archive
Read-only legacy content
17061 Discussions
Intel XDK improvements
Arnau_C_
I think that this product is awesome! It save a lot of time to HTML5 apps developers, allowing focus on the code and not in the a lot of useless settings for web app.
But, exist some settings that I miss:
Set the languages of app, I made multi language apps but the Windows build only display the English. You just need include the languages in the resources tag in AppxManifest.xml file of windows build.
In offline standard HTML5 apps ( that no use Cordova framework) allow disable the communication permissions for can make apps with no permissions requirements.  You just need no include any android permission.
If you implement this very easy features, Intel XDK will give a step to perfection for me.
Amir_K_2
Thank you for the suggestions ! It will make this a perfect one , because i also need that language improvement .
Best Regards
PaulF_IntelCorp
Thank you for the feedback. We are aware of the multi-language issue for Windows builds, and are working to resolve this.
The network permission is required even for HTML5 apps that do not use Cordova plugins because the Cordova system requires that permission in order to facilitate packaging the app as an installable app. This is a limitation in the Cordova framework that we do not control.
