Software Archive
Read-only legacy content
Intel XKD doesnt run in Windows 10
francogs
I tried installing the Intel XDK 2893 on WIN10, but when I run the opening image does not close and the App does not work!
And so, I have to finish the process, then the crashs window opens with the log:
xdk:client:[2016-03-16T22:07:33.633Z]: (1458166053634): memlim: 767557632
xdk:client:[2016-03-16T22:07:33.637Z]: (1458166053637): Setting NW crash dump to: C:\Users\Franco\AppData\Local\XDK
xdk:client:[2016-03-16T22:07:33.816Z]: (1458166053816): Intel XDK: 2893
xdk:client:[2016-03-16T22:07:33.817Z]: (1458166053817): Platform: win32-ia32 (6.3.9600)
xdk:client:[2016-03-16T22:07:33.817Z]: (1458166053817): System Info:  CPU: 4 X Intel(R) Core(TM) i7-5500U CPU @ 2.40GHz Physical Memory: 8501149696
xdk:client:[2016-03-16T22:07:33.817Z]: (1458166053817): NW: 0.11.7-rc9
xdk:client:[2016-03-16T22:07:33.865Z]: (1458166053865): Created new theme: base
xdk:client:[2016-03-16T22:07:33.866Z]: (1458166053866): Registered new theme: base
xdk:client:[2016-03-16T22:07:33.867Z]: (1458166053867): Current theme is now: base
xdk:client:[2016-03-16T22:07:33.867Z]: (1458166053867): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-03-16T22:07:33.868Z]: (1458166053868): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-03-16T22:07:33.963Z]: (1458166053963): Starting client process initialization
xdk:client:[2016-03-16T22:07:34.178Z]: (1458166054178): File xdk-version.txt to clear NW cache not found.
xdk:client:[2016-03-16T22:07:34.213Z]: (1458166054213): File xdk-version.txt generated sucessfully.
xdk:server:[2016-03-16T22:07:34.969Z]: (1458166054970): memlim: 767557632
xdk:server:[2016-03-16T22:07:34.973Z]: (1458166054973): Setting NW crash dump to: C:\Users\Franco\AppData\Local\XDK
xdk:server:[2016-03-16T22:07:35.199Z]: (1458166055199): Starting server process initialization
xdk:server:[2016-03-16T22:07:35.327Z]: (1458166055327): Http server started on the standard port 58889
xdk:server:[2016-03-16T22:07:36.299Z]: (1458166056299): NW Cache is up-to-date.
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:assert" starting import
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:assert" finished initialization
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:component-error" starting import
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:component-error" finished initialization
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:command-line-options" starting import
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:command-line-options" finished initialization
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:service-error" starting import
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:service-error" finished initialization
xdk:server:[2016-03-16T22:07:36.342Z]: (1458166056342): Component "core:buffer" starting import
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:buffer" finished initialization
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:signaler" starting import
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:signaler" finished initialization
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:signaler-group" starting import
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:signaler-group" finished initialization
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:logger" starting import
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:logger" finished initialization
xdk:server:[2016-03-16T22:07:36.357Z]: (1458166056357): Component "core:http-request" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:http-request" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:database" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:database" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:version" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:version" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:userfs-name-converter" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:crash-handler" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:crash-handler" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:i18n-support" starting import
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:i18n-support" finished initialization
xdk:server:[2016-03-16T22:07:36.373Z]: (1458166056373): Component "core:theme" starting import
xdk:server:[2016-03-16T22:07:36.439Z]: (1458166056439): Component "core:theme" finished initialization
xdk:server:[2016-03-16T22:07:36.440Z]: (1458166056440): Component "server:userfs" starting import
xdk:server:[2016-03-16T22:07:36.448Z]: (1458166056448): Component "server:userfs" calling init()
xdk:server:[2016-03-16T22:07:36.488Z]: (1458166056488): Component "server:userfs" finished initialization
xdk:server:[2016-03-16T22:07:36.488Z]: (1458166056488): Component "server:user-profile" starting import
xdk:server:[2016-03-16T22:07:36.492Z]: (1458166056492): Component "server:user-profile" calling init()
xdk:server:[2016-03-16T22:07:36.493Z]: (1458166056493): Component "server:user-profile" finished initialization
xdk:server:[2016-03-16T22:07:36.493Z]: (1458166056493): Component "server:ui-builder" starting import
xdk:server:[2016-03-16T22:07:36.553Z]: (1458166056553): Component "server:ui-builder" calling init()
xdk:server:[2016-03-16T22:07:36.555Z]: (1458166056555): Component "server:ui-builder" finished initialization
xdk:server:[2016-03-16T22:07:36.555Z]: (1458166056555): Component "server:emulator-notification" starting import
xdk:server:[2016-03-16T22:07:36.558Z]: (1458166056558): Component "server:emulator-notification" calling init()
xdk:server:[2016-03-16T22:07:36.559Z]: (1458166056559): Component "server:emulator-notification" finished initialization
xdk:server:[2016-03-16T22:07:36.559Z]: (1458166056559): Component "server:emulator-webserver" starting import
xdk:server:[2016-03-16T22:07:36.560Z]: (1458166056560): Component "server:emulator-webserver" calling init()
xdk:server:[2016-03-16T22:07:36.561Z]: (1458166056561): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-03-16T22:07:36.561Z]: (1458166056561): Component "server:new-project-creator" starting import
xdk:server:[2016-03-16T22:07:36.569Z]: (1458166056569): Component "server:new-project-creator" calling init()
xdk:server:[2016-03-16T22:07:36.569Z]: (1458166056569): Component "server:new-project-creator" finished initialization
xdk:server:[2016-03-16T22:07:36.569Z]: (1458166056569): Component "server:zip-util" starting import
xdk:server:[2016-03-16T22:07:36.572Z]: (1458166056572): Component "server:zip-util" calling init()
xdk:server:[2016-03-16T22:07:36.572Z]: (1458166056572): Component "server:zip-util" finished initialization
xdk:server:[2016-03-16T22:07:36.572Z]: (1458166056572): Component "server:uuid-server" starting import
xdk:server:[2016-03-16T22:07:36.574Z]: (1458166056574): Component "server:uuid-server" calling init()
xdk:server:[2016-03-16T22:07:36.574Z]: (1458166056574): Component "server:uuid-server" finished initialization
xdk:server:[2016-03-16T22:07:36.574Z]: (1458166056574): Component "server:app-starter" starting import
xdk:server:[2016-03-16T22:07:36.580Z]: (1458166056580): Component "server:app-starter" calling init()
xdk:server:[2016-03-16T22:07:36.582Z]: (1458166056582): Component "server:app-starter" finished initialization
xdk:server:[2016-03-16T22:07:36.582Z]: (1458166056582): Component "server:force-download" starting import
xdk:server:[2016-03-16T22:07:36.584Z]: (1458166056584): Component "server:force-download" calling init()
xdk:server:[2016-03-16T22:07:36.584Z]: (1458166056584): Component "server:force-download" finished initialization
xdk:server:[2016-03-16T22:07:36.584Z]: (1458166056584): Component "server:updater" starting import
xdk:server:[2016-03-16T22:07:36.590Z]: (1458166056590): Component "server:updater" calling init()
server:updater:[2016-03-16T22:07:36.591Z]: (1458166056591): config.base-auto
server:updater:[2016-03-16T22:07:36.591Z]: (1458166056591): url=auto
xdk:server:[2016-03-16T22:07:36.592Z]: (1458166056592): Component "server:updater" finished initialization
xdk:server:[2016-03-16T22:07:36.592Z]: (1458166056592): Component "server:editor-node" starting import
xdk:server:[2016-03-16T22:07:36.621Z]: (1458166056621): Component "server:editor-node" calling init()
xdk:server:[2016-03-16T22:07:36.624Z]: (1458166056624): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-03-16T22:07:36.624Z]: (1458166056624): Component "server:cordova-lib" starting import
xdk:server:[2016-03-16T22:07:36.938Z]: (1458166056938): Component "server:cordova-lib" calling init()
xdk:server:[2016-03-16T22:07:37.070Z]: (1458166057070): Component "server:cordova-lib" finished initialization
xdk:server:[2016-03-16T22:07:37.070Z]: (1458166057070): Component "server:api-explorer" starting import
xdk:server:[2016-03-16T22:07:37.079Z]: (1458166057079): Component "server:api-explorer" calling init()
xdk:server:[2016-03-16T22:07:37.126Z]: (1458166057126): Component "server:api-explorer" finished initialization
xdk:server:[2016-03-16T22:07:37.126Z]: (1458166057126): Component "server:plugin-listener" starting import
xdk:server:[2016-03-16T22:07:37.129Z]: (1458166057129): Component "server:plugin-listener" calling init()
xdk:server:[2016-03-16T22:07:37.129Z]: (1458166057129): Component "server:plugin-listener" finished initialization
xdk:server:[2016-03-16T22:07:37.129Z]: (1458166057129): Component "server:git-runner" starting import
xdk:server:[2016-03-16T22:07:37.132Z]: (1458166057132): Component "server:git-runner" calling init()
xdk:server:[2016-03-16T22:07:37.132Z]: (1458166057132): Component "server:git-runner" finished initialization
server:editor-node:[2016-03-16T22:07:37.290Z]: (1458166057290): Starting Brackets node process C:\Users\Franco\AppData\Local\Intel\XDK\bin\node.exe C:\Users\Franco\AppData\Local\Intel\XDK\bin\node-core
server:editor-node:[2016-03-16T22:07:37.606Z]: (1458166057606): Brackets node is running on port 50158
xdk:server:[2016-03-16T22:07:37.606Z]: (1458166057606): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-03-16T22:07:37.606Z]: (1458166057606): Component "server:ui-builder" calling start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Component "server:ui-builder" finished start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Component "server:emulator-webserver" calling start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Component "server:emulator-webserver" finished start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Component "server:editor-node" calling start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Component "server:editor-node" finished start()
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Intel XDK is initialized now
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Writing to the server data file
xdk:server:[2016-03-16T22:07:37.621Z]: (1458166057621): Wrote server data to "C:\Users\Franco\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-03-16T22:07:37.742Z]: (1458166057742): Successfully read server data file
xdk:client:[2016-03-16T22:07:37.894Z]: (1458166057894): Component "core:assert" starting import
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:assert" finished initialization
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:component-error" starting import
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:component-error" finished initialization
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:command-line-options" starting import
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:command-line-options" finished initialization
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:service-error" starting import
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:service-error" finished initialization
xdk:client:[2016-03-16T22:07:37.895Z]: (1458166057895): Component "core:buffer" starting import
xdk:client:[2016-03-16T22:07:37.896Z]: (1458166057896): Component "core:buffer" finished initialization
xdk:client:[2016-03-16T22:07:37.896Z]: (1458166057896): Component "core:signaler" starting import
xdk:client:[2016-03-16T22:07:37.896Z]: (1458166057896): Component "core:signaler" finished initialization
xdk:client:[2016-03-16T22:07:37.896Z]: (1458166057896): Component "core:signaler-group" starting import
xdk:client:[2016-03-16T22:07:37.898Z]: (1458166057898): Component "core:signaler-group" finished initialization
xdk:client:[2016-03-16T22:07:37.898Z]: (1458166057898): Component "core:logger" starting import
xdk:client:[2016-03-16T22:07:37.899Z]: (1458166057899): Component "core:logger" finished initialization
xdk:client:[2016-03-16T22:07:37.899Z]: (1458166057899): Component "core:http-request" starting import
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:http-request" finished initialization
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:version" starting import
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:version" finished initialization
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:exit-notifier" starting import
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:exit-notifier" finished initialization
xdk:client:[2016-03-16T22:07:37.900Z]: (1458166057900): Component "core:userfs-name-converter" starting import
xdk:client:[2016-03-16T22:07:37.901Z]: (1458166057901): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-03-16T22:07:37.901Z]: (1458166057901): Component "core:crash-handler" starting import
xdk:client:[2016-03-16T22:07:37.902Z]: (1458166057902): Component "core:crash-handler" finished initialization
xdk:client:[2016-03-16T22:07:37.902Z]: (1458166057902): Component "core:analytics" starting import
xdk:client:[2016-03-16T22:07:37.902Z]: (1458166057902): Component "core:analytics" finished initialization
xdk:client:[2016-03-16T22:07:37.902Z]: (1458166057902): Component "core:i18n-support" starting import
xdk:client:[2016-03-16T22:07:37.902Z]: (1458166057902): Component "core:i18n-support" finished initialization
xdk:client:[2016-03-16T22:07:37.903Z]: (1458166057903): Component "core:theme" starting import
xdk:client:[2016-03-16T22:07:37.903Z]: (1458166057903): Component "core:theme" finished initialization
xdk:client:[2016-03-16T22:07:37.912Z]: (1458166057912): Analytics ID: 53542a08-8179-4d94-9156-6ed3ca213922
xdk:client:[2016-03-16T22:07:37.912Z]: (1458166057912): onExit listener 0:
    at Object.exports.onExit (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\Franco\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:app" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:help-helper" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:nativefs" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:document-manager" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:project-manager" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:aa-controller" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:projects-renderers" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-03-16T22:07:37.935Z]: (1458166057935): Component "client:active-sync" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:apk-installer" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:appcenter-options" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-manager" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-cocos2d" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-phaser" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-pixi" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-easeljs" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-plain" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-render-frame" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:resource-util" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:bower-package-manager" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:services-tab" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:editor" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:live-preview" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:backend-services" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:backend-feeds" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:merged-feed" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:backend-services-ext" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:backend-service-utils" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:app-starter" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:ui-builder-client" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:project-meta" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:contenttype-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:editor-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:platform-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:projecttype-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:library-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:cordova-registry" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:service-method" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:settings-db" starting import
xdk:client:[2016-03-16T22:07:37.936Z]: (1458166057936): Component "client:adb" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:iosdb" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:device" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:device-discovery" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:dialog-box" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:test-local-server" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:quick-tour" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:hot-keys" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:persistance" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:tabs" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:hash-utils" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:file-watcher" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:tool-tip" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:cordova" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:settings-ui" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:external-links" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:external-editors-runner" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:project-list-load" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:upload-manager" starting import
xdk:client:[2016-03-16T22:07:37.937Z]: (1458166057937): Component "client:git-manager" starting import
xdk:client:[2016-03-16T22:07:37.985Z]: (1458166057985): Component "client:help-helper" finished initialization
xdk:client:[2016-03-16T22:07:37.986Z]: (1458166057986): Component "client:nativefs" finished initialization
xdk:client:[2016-03-16T22:07:38.007Z]: (1458166058007): Component "client:active-sync" calling init()
xdk:client:[2016-03-16T22:07:38.007Z]: (1458166058007): Component "client:active-sync" finished initialization
xdk:client:[2016-03-16T22:07:38.009Z]: (1458166058009): Component "client:apk-installer" calling init()
xdk:client:[2016-03-16T22:07:38.009Z]: (1458166058009): Component "client:apk-installer" finished initialization
xdk:client:[2016-03-16T22:07:38.036Z]: (1458166058036): Component "client:resource-render-frame" calling init()
xdk:client:[2016-03-16T22:07:38.036Z]: (1458166058036): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.037Z]: (1458166058037): Component "client:resource-util" calling init()
xdk:client:[2016-03-16T22:07:38.037Z]: (1458166058037): Component "client:resource-util" finished initialization
xdk:client:[2016-03-16T22:07:38.051Z]: (1458166058051): Component "client:backend-services" calling init()
xdk:client:[2016-03-16T22:07:38.051Z]: (1458166058051): Component "client:backend-services" finished initialization
xdk:client:[2016-03-16T22:07:38.052Z]: (1458166058052): Component "client:backend-feeds" calling init()
xdk:client:[2016-03-16T22:07:38.052Z]: (1458166058052): Component "client:backend-feeds" finished initialization
xdk:client:[2016-03-16T22:07:38.053Z]: (1458166058053): Component "client:merged-feed" finished initialization
xdk:client:[2016-03-16T22:07:38.054Z]: (1458166058054): Component "client:backend-services-ext" calling init()
xdk:client:[2016-03-16T22:07:38.054Z]: (1458166058054): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-03-16T22:07:38.055Z]: (1458166058055): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-03-16T22:07:38.059Z]: (1458166058059): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.077Z]: (1458166058077): Component "client:project-meta" calling init()
xdk:client:[2016-03-16T22:07:38.078Z]: (1458166058078): Component "client:project-meta" finished initialization
xdk:client:[2016-03-16T22:07:38.085Z]: (1458166058085): Component "client:service-method" finished initialization
xdk:client:[2016-03-16T22:07:38.087Z]: (1458166058087): Component "client:settings-db" calling init()
xdk:client:[2016-03-16T22:07:38.087Z]: (1458166058087): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.088Z]: (1458166058088): Component "client:adb" calling init()
xdk:client:[2016-03-16T22:07:38.096Z]: (1458166058096): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.097Z]: (1458166058097): Component "client:iosdb" calling init()
xdk:client:[2016-03-16T22:07:38.097Z]: (1458166058097): Component "client:iosdb" finished initialization
xdk:client:[2016-03-16T22:07:38.104Z]: (1458166058104): Component "client:persistance" calling init()
xdk:client:[2016-03-16T22:07:38.105Z]: (1458166058105): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.107Z]: (1458166058107): Component "client:file-watcher" calling init()
xdk:client:[2016-03-16T22:07:38.107Z]: (1458166058107): Component "client:file-watcher" finished initialization
xdk:client:[2016-03-16T22:07:38.113Z]: (1458166058113): Component "client:external-links" finished initialization
xdk:client:[2016-03-16T22:07:38.114Z]: (1458166058114): Component "client:external-editors-runner" calling init()
xdk:client:[2016-03-16T22:07:38.114Z]: (1458166058114): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-03-16T22:07:38.115Z]: (1458166058115): Component "client:project-list-load" calling init()
xdk:client:[2016-03-16T22:07:38.115Z]: (1458166058115): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.117Z]: (1458166058117): Component "client:upload-manager" calling init()
xdk:client:[2016-03-16T22:07:38.117Z]: (1458166058117): Component "client:upload-manager" finished initialization
xdk:client:[2016-03-16T22:07:38.118Z]: (1458166058118): Component "client:git-manager" calling init()
client:git-manager:[2016-03-16T22:07:38.118Z]: (1458166058118): git path =  C:\Users\Franco\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-03-16T22:07:38.118Z]: (1458166058118): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.122Z]: (1458166058122): Component "client:app-starter" finished initialization
xdk:client:[2016-03-16T22:07:38.124Z]: (1458166058124): Component "client:hot-keys" calling init()
xdk:client:[2016-03-16T22:07:38.124Z]: (1458166058124): Component "client:hot-keys" finished initialization
xdk:client:[2016-03-16T22:07:38.126Z]: (1458166058126): Component "client:document-manager" calling init()
xdk:client:[2016-03-16T22:07:38.127Z]: (1458166058127): Component "client:document-manager" finished initialization
xdk:client:[2016-03-16T22:07:38.139Z]: (1458166058139): Component "client:aa-controller" calling init()
xdk:client:[2016-03-16T22:07:38.139Z]: (1458166058139): Component "client:aa-controller" finished initialization
xdk:client:[2016-03-16T22:07:38.196Z]: (1458166058196): Component "client:ui-builder-client" calling init()
xdk:client:[2016-03-16T22:07:38.196Z]: (1458166058196): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-03-16T22:07:38.199Z]: (1458166058199): Component "client:dialog-box" finished initialization
xdk:client:[2016-03-16T22:07:38.201Z]: (1458166058202): Component "client:tool-tip" finished initialization
xdk:client:[2016-03-16T22:07:38.203Z]: (1458166058203): Component "client:settings-ui" finished initialization
xdk:client:[2016-03-16T22:07:38.212Z]: (1458166058212): Component "client:resource-manager" calling init()
xdk:client:[2016-03-16T22:07:38.212Z]: (1458166058212): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-phaser" calling init()
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-phaser" finished initialization
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-pixi" calling init()
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-pixi" finished initialization
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-easeljs" calling init()
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-plain" calling init()
xdk:client:[2016-03-16T22:07:38.228Z]: (1458166058228): Component "client:resource-plain" finished initialization
xdk:client:[2016-03-16T22:07:38.244Z]: (1458166058244): Component "client:appcenter-options" calling init()
xdk:client:[2016-03-16T22:07:38.244Z]: (1458166058244): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.244Z]: (1458166058244): Component "client:services-tab" calling init()
xdk:client:[2016-03-16T22:07:38.244Z]: (1458166058244): Component "client:services-tab" finished initialization
xdk:client:[2016-03-16T22:07:38.244Z]: (1458166058244): Component "client:test-local-server" calling init()
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:test-local-server" finished initialization
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:tabs" finished initialization
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:app" calling init()
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:app" finished initialization
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:contenttype-registry" calling init()
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-03-16T22:07:38.276Z]: (1458166058276): Component "client:editor-registry" finished initialization
xdk:client:[2016-03-16T22:07:38.291Z]: (1458166058291): Component "client:library-registry" calling init()
xdk:client:[2016-03-16T22:07:38.291Z]: (1458166058291): Component "client:library-registry" finished initialization
xdk:client:[2016-03-16T22:07:38.291Z]: (1458166058291): Component "client:device-discovery" calling init()
xdk:client:[2016-03-16T22:07:38.291Z]: (1458166058291): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.291Z]: (1458166058291): Component "client:hash-utils" finished initialization
xdk:client:[2016-03-16T22:07:38.322Z]: (1458166058322): Component "client:cordova" calling init()
xdk:client:[2016-03-16T22:07:38.322Z]: (1458166058322): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:project-manager" calling init()
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:projects-renderers" calling init()
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-03-16T22:07:38.345Z]: (1458166058345): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-03-16T22:07:38.360Z]: (1458166058360): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-03-16T22:07:38.360Z]: (1458166058360): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:navbar" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:tweets" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:projects-tab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:test-tab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:profilingTab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:emulator" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:remote-tab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:build-tab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:bower-client" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:editor-tab" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:account" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:project-selector" starting import
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:settings-db" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:cordova-registry" calling init()
xdk:client:[2016-03-16T22:07:38.376Z]: (1458166058376): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.392Z]: (1458166058392): Component "client:bower-package-manager" calling init()
xdk:client:[2016-03-16T22:07:38.392Z]: (1458166058392): Component "client:bower-package-manager" finished initialization
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:quick-tour" calling init()
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:quick-tour" finished initialization
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:platform-registry" calling init()
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:platform-registry" finished initialization
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:projecttype-registry" calling init()
xdk:client:[2016-03-16T22:07:38.407Z]: (1458166058407): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-03-16T22:07:38.423Z]: (1458166058423): Component "client:device" calling init()
xdk:client:[2016-03-16T22:07:38.476Z]: (1458166058476): Component "client:device" finished initialization
xdk:client:[2016-03-16T22:07:38.492Z]: (1458166058492): Component "client:device-discovery" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.492Z]: (1458166058492): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.507Z]: (1458166058507): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-03-16T22:07:38.507Z]: (1458166058507): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-03-16T22:07:38.523Z]: (1458166058523): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-03-16T22:07:38.523Z]: (1458166058523): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-03-16T22:07:38.545Z]: (1458166058545): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:editor" calling init()
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:editor" finished initialization
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:live-preview" calling init()
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:live-preview" finished initialization
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:editor-tab" getting UI region for "develop"
xdk:client:[2016-03-16T22:07:38.560Z]: (1458166058560): Component "client:editor-tab" calling init()
xdk:client:[2016-03-16T22:07:38.581Z]: (1458166058581): Component "client:editor-tab" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.587Z]: (1458166058587): Component "client:cordova" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.621Z]: (1458166058621): Component "client:account" getting UI region for "account"
xdk:client:[2016-03-16T22:07:38.621Z]: (1458166058621): Component "client:account" calling init()
xdk:client:[2016-03-16T22:07:38.627Z]: (1458166058627): Component "client:account" finished initialization
xdk:client:[2016-03-16T22:07:38.630Z]: (1458166058630): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-03-16T22:07:38.631Z]: (1458166058631): Component "client:project-selector" calling init()
xdk:client:[2016-03-16T22:07:38.631Z]: (1458166058631): Component "client:project-selector" finished initialization
xdk:client:[2016-03-16T22:07:38.632Z]: (1458166058632): Component "client:tweets" finished initialization
xdk:client:[2016-03-16T22:07:38.636Z]: (1458166058636): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-03-16T22:07:38.636Z]: (1458166058636): Component "client:projects-tab" calling init()
xdk:client:[2016-03-16T22:07:38.638Z]: (1458166058638): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.640Z]: (1458166058640): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-03-16T22:07:38.641Z]: (1458166058641): Component "client:test-tab" calling init()
xdk:client:[2016-03-16T22:07:38.641Z]: (1458166058641): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.660Z]: (1458166058661): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-03-16T22:07:38.661Z]: (1458166058661): Component "client:emulator" calling init()
xdk:client:[2016-03-16T22:07:38.663Z]: (1458166058663): Component "client:emulator" finished initialization
xdk:client:[2016-03-16T22:07:38.672Z]: (1458166058672): Component "client:remote-tab" getting UI region for "debug"
xdk:client:[2016-03-16T22:07:38.672Z]: (1458166058672): Component "client:remote-tab" calling init()
xdk:client:[2016-03-16T22:07:38.775Z]: (1458166058775): Component "client:remote-tab" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.777Z]: (1458166058777): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-03-16T22:07:38.777Z]: (1458166058777): Component "client:build-tab" calling init()
xdk:client:[2016-03-16T22:07:38.780Z]: (1458166058780): Component "client:remote-tab" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.781Z]: (1458166058781): Component "client:build-tab" finished initialization
xdk:client:[2016-03-16T22:07:38.798Z]: (1458166058798): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-03-16T22:07:38.798Z]: (1458166058798): Component "client:navbar" calling init()
client:navbar:[2016-03-16T22:07:38.799Z]: (1458166058799): navbar options: {"common":{"servicesVersion":"release-2015-ww51"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-03-16T22:07:38.799Z]: (1458166058799): Component "client:navbar" finished initialization
xdk:client:[2016-03-16T22:07:38.802Z]: (1458166058802): memmrk: 28388676 42403456
xdk:client:[2016-03-16T22:07:38.846Z]: (1458166058846): Component "client:bower-client" getting UI region for "deps-manager"
xdk:client:[2016-03-16T22:07:38.846Z]: (1458166058846): Component "client:bower-client" calling init()
xdk:client:[2016-03-16T22:07:38.846Z]: (1458166058846): Component "client:bower-client" waiting for delayed initialization
xdk:client:[2016-03-16T22:07:38.846Z]: (1458166058846): Component "client:bower-client" finished delayed initialization
xdk:client:[2016-03-16T22:07:38.900Z]: (1458166058900): Component "client:profilingTab" getting UI region for "profile"
xdk:client:[2016-03-16T22:07:38.900Z]: (1458166058900): Component "client:profilingTab" calling init()
xdk:client:[2016-03-16T22:07:38.901Z]: (1458166058901): Component "client:profilingTab" finished initialization
client:adb:[2016-03-16T22:07:38.992Z]: (1458166058992): Can't find adb process.
client:adb:[2016-03-16T22:07:38.992Z]: (1458166058992): Using default adb executable at "C:\Users\Franco\AppData\Local\Intel\XDK\bin\adb\adb"
xdk:server:[2016-03-16T22:07:39.976Z]: (1458166059976): memmrk: 26892240 45450496
xdk:client:[2016-03-16T22:07:40.108Z]: (1458166060108): Component "client:adb" finished delayed initialization
xdk:client:[2016-03-16T22:07:43.809Z]: (1458166063809): memmrk: 29765304 43419136
xdk:server:[2016-03-16T22:07:44.977Z]: (1458166064977): memmrk: 26908712 45450496
xdk:client:[2016-03-16T22:07:48.809Z]: (1458166068809): memmrk: 29768956 43419136
xdk:server:[2016-03-16T22:07:49.978Z]: (1458166069978): memmrk: 20738348 45450496
xdk:client:[2016-03-16T22:07:53.813Z]: (1458166073813): memmrk: 29771308 43419136
xdk:server:[2016-03-16T22:07:54.988Z]: (1458166074988): memmrk: 19131588 26674816
xdk:client:[2016-03-16T22:07:58.825Z]: (1458166078825): memmrk: 29773676 43419136
xdk:server:[2016-03-16T22:08:00.004Z]: (1458166080004): memmrk: 19142900 26674816
xdk:client:[2016-03-16T22:08:03.831Z]: (1458166083831): memmrk: 29776044 43419136
xdk:server:[2016-03-16T22:08:05.016Z]: (1458166085016): memmrk: 18515348 25671296
xdk:client:[2016-03-16T22:08:08.845Z]: (1458166088845): memmrk: 30006968 43419136
xdk:server:[2016-03-16T22:08:10.035Z]: (1458166090035): memmrk: 16625860 24667776
xdk:client:[2016-03-16T22:08:13.857Z]: (1458166093857): memmrk: 21927312 44434816
xdk:server:[2016-03-16T22:08:15.041Z]: (1458166095041): memmrk: 16642412 24667776
xdk:client:[2016-03-16T22:08:18.871Z]: (1458166098871): memmrk: 21934488 44434816
xdk:server:[2016-03-16T22:08:20.045Z]: (1458166100045): memmrk: 16545820 22660736
xdk:client:[2016-03-16T22:08:23.879Z]: (1458166103879): memmrk: 20166800 28706176
xdk:server:[2016-03-16T22:08:25.048Z]: (1458166105048): memmrk: 16650928 23709312
xdk:client:[2016-03-16T22:08:28.885Z]: (1458166108885): memmrk: 20169244 28706176
xdk:server:[2016-03-16T22:08:30.056Z]: (1458166110056): memmrk: 16249568 23709312
xdk:client:[2016-03-16T22:08:33.886Z]: (1458166113886): memmrk: 19349820 27702656
xdk:server:[2016-03-16T22:08:35.057Z]: (1458166115057): memmrk: 16258920 23709312
xdk:client:[2016-03-16T22:08:38.900Z]: (1458166118900): memmrk: 17130120 25683456
xdk:server:[2016-03-16T22:08:40.071Z]: (1458166120071): memmrk: 16266196 23709312
xdk:client:[2016-03-16T22:08:43.902Z]: (1458166123902): memmrk: 17132564 25683456
xdk:server:[2016-03-16T22:08:45.083Z]: (1458166125083): memmrk: 16279348 23709312
xdk:client:[2016-03-16T22:08:48.912Z]: (1458166128912): memmrk: 17123532 23676416
xdk:server:[2016-03-16T22:08:50.093Z]: (1458166130093): memmrk: 16286624 23709312
xdk:client:[2016-03-16T22:08:53.917Z]: (1458166133917): memmrk: 17250152 24724992
xdk:server:[2016-03-16T22:08:55.105Z]: (1458166135105): memmrk: 16293900 23709312
xdk:client:[2016-03-16T22:08:58.924Z]: (1458166138924): memmrk: 16762388 24724992
xdk:server:[2016-03-16T22:09:00.114Z]: (1458166140114): memmrk: 16301132 23709312
xdk:client:[2016-03-16T22:09:03.937Z]: (1458166143937): memmrk: 16764832 24724992
xdk:server:[2016-03-16T22:09:05.116Z]: (1458166145116): memmrk: 16309720 23709312
xdk:client:[2016-03-16T22:09:08.937Z]: (1458166148937): memmrk: 16767208 24724992
xdk:server:[2016-03-16T22:09:10.128Z]: (1458166150128): memmrk: 16316968 23709312
xdk:client:[2016-03-16T22:09:13.950Z]: (1458166153950): memmrk: 16769568 24724992
xdk:server:[2016-03-16T22:09:15.139Z]: (1458166155139): memmrk: 16324232 23709312
xdk:client:[2016-03-16T22:09:18.963Z]: (1458166158963): memmrk: 16771944 24724992
xdk:server:[2016-03-16T22:09:20.150Z]: (1458166160150): memmrk: 16339180 23709312
xdk:client:[2016-03-16T22:09:23.971Z]: (1458166163971): memmrk: 16774320 24724992
xdk:server:[2016-03-16T22:09:25.158Z]: (1458166165158): memmrk: 16347644 23709312
xdk:client:[2016-03-16T22:09:28.981Z]: (1458166168981): memmrk: 16776696 24724992
xdk:server:[2016-03-16T22:09:30.169Z]: (1458166170169): memmrk: 16356588 23709312
xdk:client:[2016-03-16T22:09:33.988Z]: (1458166173988): memmrk: 16779072 24724992
xdk:server:[2016-03-16T22:09:35.174Z]: (1458166175174): memmrk: 16364624 23709312
xdk:client:[2016-03-16T22:09:39.002Z]: (1458166179002): memmrk: 16781448 24724992
xdk:server:[2016-03-16T22:09:40.173Z]: (1458166180173): memmrk: 16376072 23709312
xdk:client:[2016-03-16T22:09:44.012Z]: (1458166184012): memmrk: 16783852 24724992
xdk:server:[2016-03-16T22:09:45.182Z]: (1458166185182): memmrk: 16383100 23709312
xdk:client:[2016-03-16T22:09:49.020Z]: (1458166189020): memmrk: 16786256 24724992
xdk:server:[2016-03-16T22:09:50.188Z]: (1458166190188): memmrk: 16390144 23709312
xdk:client:[2016-03-16T22:09:54.025Z]: (1458166194025): memmrk: 16788660 24724992
xdk:server:[2016-03-16T22:09:55.196Z]: (1458166195196): memmrk: 16399732 23709312
xdk:client:[2016-03-16T22:09:59.036Z]: (1458166199036): memmrk: 16791064 24724992
xdk:server:[2016-03-16T22:10:00.205Z]: (1458166200205): memmrk: 16411064 23709312
xdk:client:[2016-03-16T22:10:04.044Z]: (1458166204044): memmrk: 16793468 24724992
xdk:server:[2016-03-16T22:10:05.215Z]: (1458166205215): memmrk: 16421036 23709312
xdk:client:[2016-03-16T22:10:09.055Z]: (1458166209055): memmrk: 16795944 24724992
xdk:server:[2016-03-16T22:10:10.225Z]: (1458166210225): memmrk: 16431444 23709312
xdk:client:[2016-03-16T22:10:14.068Z]: (1458166214068): memmrk: 16798324 24724992
xdk:server:[2016-03-16T22:10:15.237Z]: (1458166215237): memmrk: 16438448 23709312
xdk:client:[2016-03-16T22:10:19.077Z]: (1458166219077): memmrk: 16800704 24724992
xdk:server:[2016-03-16T22:10:20.248Z]: (1458166220248): memmrk: 16456112 23709312
xdk:client:[2016-03-16T22:10:24.088Z]: (1458166224088): memmrk: 16803084 24724992
xdk:server:[2016-03-16T22:10:25.257Z]: (1458166225257): memmrk: 16469456 23709312
xdk:client:[2016-03-16T22:10:29.098Z]: (1458166229098): memmrk: 16805464 24724992
xdk:server:[2016-03-16T22:10:30.271Z]: (1458166230271): memmrk: 16477404 23709312
xdk:client:[2016-03-16T22:10:34.105Z]: (1458166234105): memmrk: 16807844 24724992
xdk:server:[2016-03-16T22:10:35.275Z]: (1458166235275): memmrk: 16496284 23709312
xdk:client:[2016-03-16T22:10:39.118Z]: (1458166239118): memmrk: 16810196 24724992
xdk:server:[2016-03-16T22:10:40.290Z]: (1458166240290): memmrk: 16503256 23709312
xdk:client:[2016-03-16T22:10:44.126Z]: (1458166244126): memmrk: 16812532 24724992
xdk:server:[2016-03-16T22:10:45.304Z]: (1458166245304): memmrk: 16510228 23709312
xdk:client:[2016-03-16T22:10:49.140Z]: (1458166249140): memmrk: 16814868 24724992
xdk:server:[2016-03-16T22:10:50.309Z]: (1458166250309): memmrk: 16517216 23709312
xdk:client:[2016-03-16T22:10:54.149Z]: (1458166254149): memmrk: 16817204 24724992
xdk:server:[2016-03-16T22:10:55.324Z]: (1458166255324): memmrk: 16524188 23709312
xdk:client:[2016-03-16T22:10:59.160Z]: (1458166259160): memmrk: 16819540 24724992
xdk:server:[2016-03-16T22:11:00.334Z]: (1458166260334): memmrk: 16531176 23709312
xdk:client:[2016-03-16T22:11:04.174Z]: (1458166264174): memmrk: 16821876 24724992
xdk:server:[2016-03-16T22:11:05.345Z]: (1458166265345): memmrk: 16538180 23709312
xdk:client:[2016-03-16T22:11:09.183Z]: (1458166269183): memmrk: 16824244 24724992
xdk:server:[2016-03-16T22:11:10.358Z]: (1458166270358): memmrk: 16545184 23709312
xdk:client:[2016-03-16T22:11:14.187Z]: (1458166274187): memmrk: 16826596 24724992
xdk:server:[2016-03-16T22:11:15.359Z]: (1458166275359): memmrk: 16552156 23709312
xdk:client:[2016-03-16T22:11:19.195Z]: (1458166279195): memmrk: 16829464 24724992
xdk:server:[2016-03-16T22:11:20.359Z]: (1458166280359): memmrk: 16559144 23709312
xdk:client:[2016-03-16T22:11:24.208Z]: (1458166284208): memmrk: 16831800 24724992
xdk:server:[2016-03-16T22:11:25.372Z]: (1458166285372): memmrk: 16566100 23709312
xdk:client:[2016-03-16T22:11:29.214Z]: (1458166289214): memmrk: 16834136 24724992
xdk:server:[2016-03-16T22:11:30.383Z]: (1458166290383): memmrk: 16573088 23709312
xdk:client:[2016-03-16T22:11:34.226Z]: (1458166294226): memmrk: 16836472 24724992
xdk:server:[2016-03-16T22:11:35.390Z]: (1458166295390): memmrk: 16580060 23709312
xdk:client:[2016-03-16T22:11:39.227Z]: (1458166299227): memmrk: 16838808 24724992
xdk:server:[2016-03-16T22:11:40.404Z]: (1458166300404): memmrk: 16586124 23709312
xdk:client:[2016-03-16T22:11:44.230Z]: (1458166304230): memmrk: 16841144 24724992
xdk:server:[2016-03-16T22:11:45.405Z]: (1458166305405): memmrk: 16593112 23709312
xdk:client:[2016-03-16T22:11:49.243Z]: (1458166309243): memmrk: 16843480 24724992
xdk:server:[2016-03-16T22:11:50.407Z]: (1458166310407): memmrk: 16600084 23709312
xdk:client:[2016-03-16T22:11:54.250Z]: (1458166314250): memmrk: 16845816 24724992
xdk:server:[2016-03-16T22:11:55.412Z]: (1458166315412): memmrk: 16607056 23709312
xdk:client:[2016-03-16T22:11:59.261Z]: (1458166319261): memmrk: 16848152 24724992
xdk:server:[2016-03-16T22:12:00.425Z]: (1458166320425): memmrk: 16614044 23709312
xdk:client:[2016-03-16T22:12:04.263Z]: (1458166324263): memmrk: 16850488 24724992
xdk:server:[2016-03-16T22:12:05.425Z]: (1458166325425): memmrk: 16621064 23709312
xdk:client:[2016-03-16T22:12:09.271Z]: (1458166329271): memmrk: 16852840 24724992
xdk:server:[2016-03-16T22:12:10.437Z]: (1458166330437): memmrk: 16628036 23709312
xdk:client:[2016-03-16T22:12:14.280Z]: (1458166334280): memmrk: 16855192 24724992
xdk:server:[2016-03-16T22:12:15.443Z]: (1458166335443): memmrk: 16635008 23709312
xdk:client:[2016-03-16T22:12:19.297Z]: (1458166339297): memmrk: 16870752 24724992
xdk:server:[2016-03-16T22:12:20.446Z]: (1458166340446): memmrk: 16641996 23709312
xdk:client:[2016-03-16T22:12:24.297Z]: (1458166344297): memmrk: 16876736 24724992
xdk:server:[2016-03-16T22:12:25.460Z]: (1458166345460): memmrk: 16648984 23709312
xdk:client:[2016-03-16T22:12:29.297Z]: (1458166349297): memmrk: 16879056 24724992
xdk:server:[2016-03-16T22:12:30.463Z]: (1458166350463): memmrk: 16655956 23709312
xdk:client:[2016-03-16T22:12:34.297Z]: (1458166354298): memmrk: 16881376 24724992
xdk:server:[2016-03-16T22:12:35.467Z]: (1458166355467): memmrk: 16662944 23709312
xdk:client:[2016-03-16T22:12:39.311Z]: (1458166359311): memmrk: 16883696 24724992
xdk:server:[2016-03-16T22:12:40.477Z]: (1458166360477): memmrk: 16669932 23709312
xdk:client:[2016-03-16T22:12:44.313Z]: (1458166364313): memmrk: 16886032 24724992
xdk:server:[2016-03-16T22:12:45.480Z]: (1458166365480): memmrk: 16681108 23709312
xdk:client:[2016-03-16T22:12:49.318Z]: (1458166369318): memmrk: 16888368 24724992
xdk:server:[2016-03-16T22:12:50.495Z]: (1458166370495): memmrk: 16734076 23709312
xdk:client:[2016-03-16T22:12:54.328Z]: (1458166374328): memmrk: 16890704 24724992
xdk:server:[2016-03-16T22:12:55.499Z]: (1458166375499): memmrk: 16741208 23709312
xdk:client:[2016-03-16T22:12:59.330Z]: (1458166379330): memmrk: 16893040 24724992
xdk:server:[2016-03-16T22:13:00.499Z]: (1458166380499): memmrk: 16776600 23709312
xdk:client:[2016-03-16T22:13:04.341Z]: (1458166384341): memmrk: 16895376 24724992
xdk:server:[2016-03-16T22:13:05.513Z]: (1458166385513): memmrk: 16783588 23709312
xdk:client:[2016-03-16T22:13:09.347Z]: (1458166389347): memmrk: 16897728 24724992
xdk:server:[2016-03-16T22:13:10.516Z]: (1458166390516): memmrk: 16790592 23709312
xdk:client:[2016-03-16T22:13:14.353Z]: (1458166394353): memmrk: 16900080 24724992
xdk:server:[2016-03-16T22:13:15.523Z]: (1458166395523): memmrk: 16797564 23709312
xdk:client:[2016-03-16T22:13:19.366Z]: (1458166399366): memmrk: 16902416 24724992
xdk:server:[2016-03-16T22:13:20.523Z]: (1458166400523): memmrk: 16804552 23709312
xdk:client:[2016-03-16T22:13:24.381Z]: (1458166404381): memmrk: 16904752 24724992
xdk:server:[2016-03-16T22:13:25.534Z]: (1458166405534): memmrk: 16811508 23709312
xdk:client:[2016-03-16T22:13:29.382Z]: (1458166409382): memmrk: 16907088 24724992
xdk:server:[2016-03-16T22:13:30.550Z]: (1458166410550): memmrk: 16818496 23709312
xdk:client:[2016-03-16T22:13:34.389Z]: (1458166414389): memmrk: 16909424 24724992
xdk:server:[2016-03-16T22:13:35.560Z]: (1458166415560): memmrk: 16825484 23709312
xdk:client:[2016-03-16T22:13:39.399Z]: (1458166419399): memmrk: 16911760 24724992
xdk:server:[2016-03-16T22:13:40.568Z]: (1458166420568): memmrk: 16832440 23709312
xdk:client:[2016-03-16T22:13:44.401Z]: (1458166424401): memmrk: 16914096 24724992
xdk:server:[2016-03-16T22:13:45.568Z]: (1458166425568): memmrk: 16839428 23709312
xdk:client:[2016-03-16T22:13:49.402Z]: (1458166429402): memmrk: 16916432 24724992
xdk:server:[2016-03-16T22:13:50.581Z]: (1458166430581): memmrk: 16846384 23709312
xdk:client:[2016-03-16T22:13:54.402Z]: (1458166434402): memmrk: 16918768 24724992
xdk:server:[2016-03-16T22:13:55.582Z]: (1458166435582): memmrk: 16853372 23709312
xdk:client:[2016-03-16T22:13:59.403Z]: (1458166439403): memmrk: 16921088 24724992
xdk:server:[2016-03-16T22:14:00.582Z]: (1458166440582): memmrk: 16864692 23709312
xdk:client:[2016-03-16T22:14:04.405Z]: (1458166444405): memmrk: 16923424 24724992
xdk:server:[2016-03-16T22:14:05.584Z]: (1458166445584): memmrk: 16875192 23709312
xdk:client:[2016-03-16T22:14:09.405Z]: (1458166449405): memmrk: 16925776 24724992
xdk:server:[2016-03-16T22:14:10.598Z]: (1458166450599): memmrk: 16882180 23709312
xdk:client:[2016-03-16T22:14:14.406Z]: (1458166454406): memmrk: 16928112 24724992
xdk:server:[2016-03-16T22:14:15.599Z]: (1458166455599): memmrk: 16913468 23709312
xdk:client:[2016-03-16T22:14:19.417Z]: (1458166459417): memmrk: 16930448 24724992
xdk:server:[2016-03-16T22:14:20.602Z]: (1458166460602): memmrk: 16920296 23709312
xdk:client:[2016-03-16T22:14:24.432Z]: (1458166464433): memmrk: 16932784 24724992
xdk:server:[2016-03-16T22:14:25.602Z]: (1458166465602): memmrk: 16927076 23709312
xdk:client:[2016-03-16T22:14:29.443Z]: (1458166469443): memmrk: 16935120 24724992
xdk:server:[2016-03-16T22:14:30.603Z]: (1458166470603): memmrk: 16933872 23709312
xdk:client:[2016-03-16T22:14:34.444Z]: (1458166474444): memmrk: 16937456 24724992
xdk:server:[2016-03-16T22:14:35.617Z]: (1458166475617): memmrk: 16940700 23709312
xdk:client:[2016-03-16T22:14:39.445Z]: (1458166479445): memmrk: 16939792 24724992
xdk:server:[2016-03-16T22:14:40.627Z]: (1458166480627): memmrk: 16949300 23709312
xdk:client:[2016-03-16T22:14:44.456Z]: (1458166484456): memmrk: 16942128 24724992
xdk:server:[2016-03-16T22:14:45.635Z]: (1458166485635): memmrk: 16956112 23709312
xdk:client:[2016-03-16T22:14:49.467Z]: (1458166489467): memmrk: 16944464 24724992
xdk:server:[2016-03-16T22:14:50.637Z]: (1458166490637): memmrk: 16962940 23709312
xdk:client:[2016-03-16T22:14:54.468Z]: (1458166494468): memmrk: 16946800 24724992
xdk:server:[2016-03-16T22:14:55.637Z]: (1458166495637): memmrk: 16969752 23709312
xdk:client:[2016-03-16T22:14:59.471Z]: (1458166499471): memmrk: 16949136 24724992
xdk:server:[2016-03-16T22:15:00.642Z]: (1458166500642): memmrk: 16978656 23709312
xdk:client:[2016-03-16T22:15:04.485Z]: (1458166504485): memmrk: 16951472 24724992
xdk:server:[2016-03-16T22:15:05.656Z]: (1458166505656): memmrk: 16985468 23709312
xdk:client:[2016-03-16T22:15:09.498Z]: (1458166509498): memmrk: 16953840 24724992
xdk:server:[2016-03-16T22:15:10.669Z]: (1458166510669): memmrk: 16992312 23709312
xdk:client:[2016-03-16T22:15:14.513Z]: (1458166514513): memmrk: 16956192 24724992
xdk:server:[2016-03-16T22:15:15.682Z]: (1458166515682): memmrk: 16999140 23709312
xdk:client:[2016-03-16T22:15:19.521Z]: (1458166519521): memmrk: 16958528 24724992
xdk:server:[2016-03-16T22:15:20.691Z]: (1458166520691): memmrk: 17005952 23709312
xdk:client:[2016-03-16T22:15:24.532Z]: (1458166524532): memmrk: 16960864 24724992
xdk:server:[2016-03-16T22:15:25.706Z]: (1458166525706): memmrk: 17012748 23709312
xdk:client:[2016-03-16T22:15:29.540Z]: (1458166529540): memmrk: 16963200 24724992
xdk:server:[2016-03-16T22:15:30.710Z]: (1458166530710): memmrk: 17019576 23709312
xdk:client:[2016-03-16T22:15:34.554Z]: (1458166534555): memmrk: 16965536 24724992
xdk:server:[2016-03-16T22:15:35.709Z]: (1458166535709): memmrk: 17026388 23709312
xdk:client:[2016-03-16T22:15:39.555Z]: (1458166539555): memmrk: 16967872 24724992
xdk:server:[2016-03-16T22:15:40.710Z]: (1458166540710): memmrk: 17033200 23709312
xdk:client:[2016-03-16T22:15:44.567Z]: (1458166544567): memmrk: 16970208 24724992
xdk:server:[2016-03-16T22:15:45.710Z]: (1458166545710): memmrk: 17040012 23709312
xdk:client:[2016-03-16T22:15:49.573Z]: (1458166549573): memmrk: 16974220 24724992
xdk:server:[2016-03-16T22:15:50.711Z]: (1458166550711): memmrk: 17046824 23709312
xdk:client:[2016-03-16T22:15:54.574Z]: (1458166554574): memmrk: 16976556 24724992
xdk:server:[2016-03-16T22:15:55.722Z]: (1458166555722): memmrk: 17053636 23709312
xdk:client:[2016-03-16T22:15:59.576Z]: (1458166559576): memmrk: 16978892 24724992
xdk:server:[2016-03-16T22:16:00.724Z]: (1458166560724): memmrk: 17060448 23709312
xdk:client:[2016-03-16T22:16:04.576Z]: (1458166564576): memmrk: 16981228 24724992
xdk:server:[2016-03-16T22:16:05.724Z]: (1458166565724): memmrk: 17067292 23709312
xdk:client:[2016-03-16T22:16:09.579Z]: (1458166569579): memmrk: 16983564 24724992
xdk:server:[2016-03-16T22:16:10.729Z]: (1458166570729): memmrk: 17074120 23709312
xdk:client:[2016-03-16T22:16:14.593Z]: (1458166574593): memmrk: 16985916 24724992
xdk:server:[2016-03-16T22:16:15.742Z]: (1458166575742): memmrk: 17080916 23709312
xdk:client:[2016-03-16T22:16:19.594Z]: (1458166579594): memmrk: 16988252 24724992
xdk:server:[2016-03-16T22:16:20.743Z]: (1458166580743): memmrk: 17087744 23709312
xdk:client:[2016-03-16T22:16:24.601Z]: (1458166584601): memmrk: 16990588 24724992
xdk:server:[2016-03-16T22:16:25.750Z]: (1458166585750): memmrk: 17094556 23709312
xdk:client:[2016-03-16T22:16:29.614Z]: (1458166589614): memmrk: 16992924 24724992
xdk:server:[2016-03-16T22:16:30.764Z]: (1458166590764): memmrk: 17101384 23709312
xdk:client:[2016-03-16T22:16:34.628Z]: (1458166594628): memmrk: 16995260 24724992
xdk:server:[2016-03-16T22:16:35.776Z]: (1458166595776): memmrk: 17108196 23709312
xdk:client:[2016-03-16T22:16:39.628Z]: (1458166599628): memmrk: 16997596 24724992
xdk:server:[2016-03-16T22:16:40.776Z]: (1458166600776): memmrk: 17115024 23709312
xdk:client:[2016-03-16T22:16:44.630Z]: (1458166604630): memmrk: 17001604 24724992
xdk:server:[2016-03-16T22:16:45.776Z]: (1458166605776): memmrk: 17121836 23709312
xdk:client:[2016-03-16T22:16:49.630Z]: (1458166609630): memmrk: 17003924 24724992
xdk:server:[2016-03-16T22:16:50.777Z]: (1458166610777): memmrk: 17128632 23709312
xdk:client:[2016-03-16T22:16:54.630Z]: (1458166614631): memmrk: 17006228 24724992
xdk:server:[2016-03-16T22:16:55.777Z]: (1458166615777): memmrk: 17135460 23709312
xdk:client:[2016-03-16T22:16:59.632Z]: (1458166619632): memmrk: 17011028 24724992
xdk:server:[2016-03-16T22:17:00.777Z]: (1458166620777): memmrk: 17142256 23709312
xdk:client:[2016-03-16T22:17:04.632Z]: (1458166624633): memmrk: 17013348 24724992
xdk:server:[2016-03-16T22:17:05.778Z]: (1458166625778): memmrk: 17149100 23709312
xdk:client:[2016-03-16T22:17:09.633Z]: (1458166629633): memmrk: 17015684 24724992
xdk:server:[2016-03-16T22:17:10.778Z]: (1458166630778): memmrk: 17155928 23709312
xdk:client:[2016-03-16T22:17:14.645Z]: (1458166634645): memmrk: 17018020 24724992
xdk:server:[2016-03-16T22:17:15.785Z]: (1458166635785): memmrk: 17181500 23709312
xdk:client:[2016-03-16T22:17:19.647Z]: (1458166639647): memmrk: 17020340 24724992
xdk:server:[2016-03-16T22:17:20.786Z]: (1458166640786): memmrk: 17188296 23709312
xdk:client:[2016-03-16T22:17:24.653Z]: (1458166644653): memmrk: 17022660 24724992
xdk:server:[2016-03-16T22:17:25.786Z]: (1458166645786): memmrk: 17195108 23709312
xdk:client:[2016-03-16T22:17:29.658Z]: (1458166649658): memmrk: 17024980 24724992
xdk:server:[2016-03-16T22:17:30.794Z]: (1458166650794): memmrk: 17201920 23709312
xdk:client:[2016-03-16T22:17:34.671Z]: (1458166654671): memmrk: 17027300 24724992
xdk:server:[2016-03-16T22:17:35.808Z]: (1458166655808): memmrk: 17208748 23709312
xdk:client:[2016-03-16T22:17:39.676Z]: (1458166659676): memmrk: 17029620 24724992
xdk:server:[2016-03-16T22:17:40.811Z]: (1458166660811): memmrk: 17215528 23709312
xdk:client:[2016-03-16T22:17:44.677Z]: (1458166664677): memmrk: 17031940 24724992
xdk:server:[2016-03-16T22:17:45.818Z]: (1458166665818): memmrk: 17222340 23709312
xdk:client:[2016-03-16T22:17:49.692Z]: (1458166669692): memmrk: 17034260 24724992
xdk:server:[2016-03-16T22:17:50.834Z]: (1458166670834): memmrk: 17229360 23709312
xdk:client:[2016-03-16T22:17:54.694Z]: (1458166674694): memmrk: 17036580 24724992
xdk:server:[2016-03-16T22:17:55.848Z]: (1458166675848): memmrk: 17238008 23709312
xdk:client:[2016-03-16T22:17:59.708Z]: (1458166679708): memmrk: 17038900 24724992
xdk:server:[2016-03-16T22:18:00.848Z]: (1458166680849): memmrk: 17244836 23709312
xdk:client:[2016-03-16T22:18:04.720Z]: (1458166684720): memmrk: 17041220 24724992
xdk:server:[2016-03-16T22:18:05.854Z]: (1458166685855): memmrk: 17268980 23709312
xdk:client:[2016-03-16T22:18:09.727Z]: (1458166689727): memmrk: 17044320 24724992
xdk:server:[2016-03-16T22:18:10.862Z]: (1458166690862): memmrk: 17275824 23709312
xdk:client:[2016-03-16T22:18:14.731Z]: (1458166694731): memmrk: 17046656 24724992
xdk:server:[2016-03-16T22:18:15.864Z]: (1458166695864): memmrk: 17282620 23709312
xdk:client:[2016-03-16T22:18:19.739Z]: (1458166699739): memmrk: 17048976 24724992
xdk:server:[2016-03-16T22:18:20.872Z]: (1458166700872): memmrk: 17289432 23709312
xdk:client:[2016-03-16T22:18:24.750Z]: (1458166704750): memmrk: 17051296 24724992
xdk:server:[2016-03-16T22:18:25.881Z]: (1458166705881): memmrk: 17308004 23709312
xdk:client:[2016-03-16T22:18:29.762Z]: (1458166709762): memmrk: 17053616 24724992
xdk:server:[2016-03-16T22:18:30.896Z]: (1458166710896): memmrk: 17314832 23709312
xdk:client:[2016-03-16T22:18:34.830Z]: (1458166714830): memmrk: 17058832 24724992
xdk:server:[2016-03-16T22:18:35.908Z]: (1458166715908): memmrk: 17321644 23709312
xdk:client:[2016-03-16T22:18:39.851Z]: (1458166719851): memmrk: 17061972 24724992
xdk:server:[2016-03-16T22:18:40.921Z]: (1458166720921): memmrk: 17328472 23709312
xdk:client:[2016-03-16T22:18:44.860Z]: (1458166724860): memmrk: 17065092 24724992
xdk:server:[2016-03-16T22:18:45.934Z]: (1458166725934): memmrk: 17335300 23709312
xdk:client:[2016-03-16T22:18:49.861Z]: (1458166729861): memmrk: 17067388 24724992
xdk:server:[2016-03-16T22:18:50.947Z]: (1458166730947): memmrk: 17342112 23709312
xdk:client:[2016-03-16T22:18:54.861Z]: (1458166734861): memmrk: 17069684 24724992
xdk:server:[2016-03-16T22:18:55.956Z]: (1458166735956): memmrk: 17348940 23709312
xdk:client:[2016-03-16T22:18:59.862Z]: (1458166739862): memmrk: 17071964 24724992
xdk:server:[2016-03-16T22:19:00.963Z]: (1458166740963): memmrk: 17355752 23709312
xdk:client:[2016-03-16T22:19:04.870Z]: (1458166744870): memmrk: 17074452 24724992
xdk:server:[2016-03-16T22:19:05.979Z]: (1458166745979): memmrk: 17362612 23709312
xdk:client:[2016-03-16T22:19:09.870Z]: (1458166749870): memmrk: 17076764 24724992
xdk:server:[2016-03-16T22:19:10.990Z]: (1458166750990): memmrk: 17368548 23709312
xdk:client:[2016-03-16T22:19:14.871Z]: (1458166754871): memmrk: 17079060 24724992
xdk:server:[2016-03-16T22:19:16.003Z]: (1458166756003): memmrk: 17375376 23709312
xdk:client:[2016-03-16T22:19:19.878Z]: (1458166759878): memmrk: 17081356 24724992
xdk:server:[2016-03-16T22:19:21.011Z]: (1458166761011): memmrk: 17382232 23709312
xdk:client:[2016-03-16T22:19:24.889Z]: (1458166764889): memmrk: 17083652 24724992
xdk:server:[2016-03-16T22:19:26.012Z]: (1458166766012): memmrk: 17389072 23709312
xdk:client:[2016-03-16T22:19:29.890Z]: (1458166769890): memmrk: 17085948 24724992
xdk:server:[2016-03-16T22:19:31.027Z]: (1458166771027): memmrk: 17395880 23709312
xdk:client:[2016-03-16T22:19:34.901Z]: (1458166774901): memmrk: 17088244 24724992
xdk:server:[2016-03-16T22:19:36.035Z]: (1458166776035): memmrk: 17402752 23709312
xdk:client:[2016-03-16T22:19:39.902Z]: (1458166779902): memmrk: 17090540 24724992
xdk:server:[2016-03-16T22:19:41.035Z]: (1458166781035): memmrk: 17409608 23709312
xdk:client:[2016-03-16T22:19:44.910Z]: (1458166784910): memmrk: 17092836 24724992
xdk:server:[2016-03-16T22:19:46.036Z]: (1458166786036): memmrk: 17416432 23709312
xdk:client:[2016-03-16T22:19:49.924Z]: (1458166789924): memmrk: 17095132 24724992
xdk:server:[2016-03-16T22:19:51.048Z]: (1458166791048): memmrk: 17423272 23709312
xdk:client:[2016-03-16T22:19:54.930Z]: (1458166794930): memmrk: 17097412 24724992
xdk:server:[2016-03-16T22:19:56.051Z]: (1458166796051): memmrk: 17430128 23709312
xdk:client:[2016-03-16T22:19:59.941Z]: (1458166799941): memmrk: 17099708 24724992
xdk:server:[2016-03-16T22:20:01.058Z]: (1458166801058): memmrk: 17436968 23709312
xdk:client:[2016-03-16T22:20:04.946Z]: (1458166804946): memmrk: 17102004 24724992
xdk:server:[2016-03-16T22:20:06.069Z]: (1458166806069): memmrk: 17443792 23709312
xdk:client:[2016-03-16T22:20:09.951Z]: (1458166809951): memmrk: 17104316 24724992
xdk:server:[2016-03-16T22:20:11.070Z]: (1458166811070): memmrk: 16486016 23709312
xdk:client:[2016-03-16T22:20:14.960Z]: (1458166814960): memmrk: 17106628 24724992
xdk:server:[2016-03-16T22:20:16.080Z]: (1458166816080): memmrk: 16492856 23709312
xdk:client:[2016-03-16T22:20:19.961Z]: (1458166819961): memmrk: 17108924 24724992
xdk:server:[2016-03-16T22:20:21.086Z]: (1458166821086): memmrk: 16499696 23709312
xdk:client:[2016-03-16T22:20:24.962Z]: (1458166824962): memmrk: 17111220 24724992
xdk:server:[2016-03-16T22:20:26.100Z]: (1458166826100): memmrk: 16506520 23709312
xdk:client:[2016-03-16T22:20:29.975Z]: (1458166829975): memmrk: 17113516 24724992
xdk:server:[2016-03-16T22:20:31.107Z]: (1458166831107): memmrk: 16513332 23709312
xdk:client:[2016-03-16T22:20:34.990Z]: (1458166834990): memmrk: 17115812 24724992
xdk:server:[2016-03-16T22:20:36.107Z]: (1458166836107): memmrk: 16520128 23709312
xdk:client:[2016-03-16T22:20:39.992Z]: (1458166839992): memmrk: 17118108 24724992
xdk:server:[2016-03-16T22:20:41.109Z]: (1458166841109): memmrk: 16526908 23709312
xdk:client:[2016-03-16T22:20:45.000Z]: (1458166845000): memmrk: 17120404 24724992
xdk:server:[2016-03-16T22:20:46.119Z]: (1458166846119): memmrk: 16533688 23709312
xdk:client:[2016-03-16T22:20:50.000Z]: (1458166850000): memmrk: 17122744 24724992
xdk:server:[2016-03-16T22:20:51.124Z]: (1458166851124): memmrk: 16540500 23709312
xdk:client:[2016-03-16T22:20:55.004Z]: (1458166855004): memmrk: 17125084 24724992
xdk:server:[2016-03-16T22:20:56.124Z]: (1458166856124): memmrk: 16547296 23709312
xdk:client:[2016-03-16T22:21:00.011Z]: (1458166860011): memmrk: 17127792 24724992
xdk:server:[2016-03-16T22:21:01.129Z]: (1458166861129): memmrk: 16554108 23709312
xdk:client:[2016-03-16T22:21:05.022Z]: (1458166865022): memmrk: 16557188 24724992
xdk:server:[2016-03-16T22:21:06.140Z]: (1458166866140): memmrk: 16560936 23709312
xdk:client:[2016-03-16T22:21:10.029Z]: (1458166870029): memmrk: 16590652 24724992
xdk:server:[2016-03-16T22:21:11.152Z]: (1458166871152): memmrk: 16567732 23709312
xdk:client:[2016-03-16T22:21:15.036Z]: (1458166875036): memmrk: 16593324 24724992
xdk:server:[2016-03-16T22:21:16.168Z]: (1458166876168): memmrk: 16574544 23709312
xdk:client:[2016-03-16T22:21:20.046Z]: (1458166880046): memmrk: 16595664 24724992
xdk:server:[2016-03-16T22:21:21.170Z]: (1458166881170): memmrk: 16581340 23709312
xdk:client:[2016-03-16T22:21:25.051Z]: (1458166885051): memmrk: 16598004 24724992
xdk:server:[2016-03-16T22:21:26.170Z]: (1458166886170): memmrk: 16588152 23709312
xdk:client:[2016-03-16T22:21:30.064Z]: (1458166890064): memmrk: 16600344 24724992
xdk:server:[2016-03-16T22:21:31.186Z]: (1458166891186): memmrk: 16594964 23709312
xdk:client:[2016-03-16T22:21:35.070Z]: (1458166895070): memmrk: 17082992 24724992
xdk:server:[2016-03-16T22:21:36.194Z]: (1458166896194): memmrk: 16601760 23709312
xdk:client:[2016-03-16T22:21:40.079Z]: (1458166900079): memmrk: 16778912 24724992
xdk:server:[2016-03-16T22:21:41.195Z]: (1458166901195): memmrk: 16608572 23709312
xdk:client:[2016-03-16T22:21:45.080Z]: (1458166905080): memmrk: 16785024 24724992
xdk:server:[2016-03-16T22:21:46.206Z]: (1458166906206): memmrk: 16615384 23709312
xdk:client:[2016-03-16T22:21:50.086Z]: (1458166910086): memmrk: 16646720 23676416
xdk:server:[2016-03-16T22:21:51.207Z]: (1458166911207): memmrk: 16622180 23709312
xdk:client:[2016-03-16T22:21:55.091Z]: (1458166915091): memmrk: 16637020 23676416
xdk:server:[2016-03-16T22:21:56.208Z]: (1458166916208): memmrk: 16628976 23709312
xdk:client:[2016-03-16T22:22:00.091Z]: (1458166920091): memmrk: 16637084 23676416
xdk:server:[2016-03-16T22:22:01.215Z]: (1458166921215): memmrk: 16635788 23709312
xdk:client:[2016-03-16T22:22:05.100Z]: (1458166925100): memmrk: 16642028 23676416
xdk:server:[2016-03-16T22:22:06.216Z]: (1458166926216): memmrk: 16642584 23709312
xdk:client:[2016-03-16T22:22:10.111Z]: (1458166930111): memmrk: 16637216 23676416
xdk:server:[2016-03-16T22:22:11.221Z]: (1458166931221): memmrk: 16649412 23709312
xdk:client:[2016-03-16T22:22:15.125Z]: (1458166935125): memmrk: 16767600 24724992
xdk:server:[2016-03-16T22:22:16.234Z]: (1458166936234): memmrk: 16656208 23709312
xdk:client:[2016-03-16T22:22:20.130Z]: (1458166940130): memmrk: 16289284 24724992
xdk:server:[2016-03-16T22:22:21.237Z]: (1458166941237): memmrk: 16663004 23709312
xdk:client:[2016-03-16T22:22:25.133Z]: (1458166945133): memmrk: 16294200 24724992
xdk:server:[2016-03-16T22:22:26.242Z]: (1458166946242): memmrk: 16669816 23709312
xdk:client:[2016-03-16T22:22:30.140Z]: (1458166950140): memmrk: 16296844 24724992
xdk:server:[2016-03-16T22:22:31.257Z]: (1458166951257): memmrk: 16676628 23709312
xdk:client:[2016-03-16T22:22:35.152Z]: (1458166955152): memmrk: 16299156 24724992
xdk:server:[2016-03-16T22:22:36.258Z]: (1458166956258): memmrk: 16683424 23709312
xdk:client:[2016-03-16T22:22:40.160Z]: (1458166960160): memmrk: 16301468 24724992
xdk:server:[2016-03-16T22:22:41.267Z]: (1458166961267): memmrk: 16690236 23709312
xdk:client:[2016-03-16T22:22:45.165Z]: (1458166965165): memmrk: 16303780 24724992
xdk:server:[2016-03-16T22:22:46.277Z]: (1458166966277): memmrk: 16697048 23709312
xdk:client:[2016-03-16T22:22:50.166Z]: (1458166970166): memmrk: 16306092 24724992
xdk:server:[2016-03-16T22:22:51.291Z]: (1458166971291): memmrk: 16703844 23709312
xdk:client:[2016-03-16T22:22:55.175Z]: (1458166975175): memmrk: 16308404 24724992
xdk:server:[2016-03-16T22:22:56.294Z]: (1458166976294): memmrk: 16710656 23709312
xdk:client:[2016-03-16T22:23:00.189Z]: (1458166980189): memmrk: 16310716 24724992
xdk:server:[2016-03-16T22:23:01.308Z]: (1458166981308): memmrk: 16717452 23709312
xdk:client:[2016-03-16T22:23:05.197Z]: (1458166985197): memmrk: 16313044 24724992
xdk:server:[2016-03-16T22:23:06.319Z]: (1458166986319): memmrk: 16724296 23709312
xdk:client:[2016-03-16T22:23:10.201Z]: (1458166990201): memmrk: 16315356 24724992
xdk:server:[2016-03-16T22:23:11.321Z]: (1458166991321): memmrk: 16731124 23709312
xdk:client:[2016-03-16T22:23:15.209Z]: (1458166995209): memmrk: 16317668 24724992
xdk:server:[2016-03-16T22:23:16.325Z]: (1458166996325): memmrk: 16737920 23709312
xdk:client:[2016-03-16T22:23:20.214Z]: (1458167000214): memmrk: 16319980 24724992
xdk:server:[2016-03-16T22:23:21.326Z]: (1458167001326): memmrk: 16744732 23709312
xdk:client:[2016-03-16T22:23:25.226Z]: (1458167005226): memmrk: 16322276 24724992
xdk:server:[2016-03-16T22:23:26.340Z]: (1458167006340): memmrk: 16750652 23709312
xdk:client:[2016-03-16T22:23:30.240Z]: (1458167010240): memmrk: 16324572 24724992
xdk:server:[2016-03-16T22:23:31.345Z]: (1458167011345): memmrk: 16757448 23709312
xdk:client:[2016-03-16T22:23:35.253Z]: (1458167015253): memmrk: 16326868 24724992
xdk:server:[2016-03-16T22:23:36.355Z]: (1458167016355): memmrk: 16764260 23709312
xdk:client:[2016-03-16T22:23:40.253Z]: (1458167020253): memmrk: 16329164 24724992
xdk:server:[2016-03-16T22:23:41.355Z]: (1458167021355): memmrk: 16771056 23709312
xdk:client:[2016-03-16T22:23:45.263Z]: (1458167025263): memmrk: 16331444 24724992
xdk:server:[2016-03-16T22:23:46.364Z]: (1458167026364): memmrk: 16777852 23709312
xdk:client:[2016-03-16T22:23:50.272Z]: (1458167030272): memmrk: 16333740 24724992
xdk:server:[2016-03-16T22:23:51.363Z]: (1458167031363): memmrk: 16784664 23709312
xdk:client:[2016-03-16T22:23:55.279Z]: (1458167035279): memmrk: 16336036 24724992
xdk:server:[2016-03-16T22:23:56.369Z]: (1458167036369): memmrk: 16791476 23709312
xdk:client:[2016-03-16T22:24:00.286Z]: (1458167040286): memmrk: 16338332 24724992
xdk:server:[2016-03-16T22:24:01.373Z]: (1458167041373): memmrk: 16798272 23709312
xdk:client:[2016-03-16T22:24:05.297Z]: (1458167045297): memmrk: 16340660 24724992
xdk:server:[2016-03-16T22:24:06.387Z]: (1458167046387): memmrk: 16805116 23709312
xdk:client:[2016-03-16T22:24:10.304Z]: (1458167050304): memmrk: 16342972 24724992
xdk:server:[2016-03-16T22:24:11.397Z]: (1458167051397): memmrk: 16811928 23709312
xdk:client:[2016-03-16T22:24:15.306Z]: (1458167055306): memmrk: 16345268 24724992
xdk:server:[2016-03-16T22:24:16.410Z]: (1458167056410): memmrk: 16818740 23709312
xdk:client:[2016-03-16T22:24:20.318Z]: (1458167060318): memmrk: 16347564 24724992
xdk:server:[2016-03-16T22:24:21.423Z]: (1458167061423): memmrk: 16825564 23709312
xdk:client:[2016-03-16T22:24:25.332Z]: (1458167065332): memmrk: 16349860 24724992
xdk:server:[2016-03-16T22:24:26.425Z]: (1458167066425): memmrk: 16832436 23709312
xdk:client:[2016-03-16T22:24:30.343Z]: (1458167070343): memmrk: 16352156 24724992
xdk:server:[2016-03-16T22:24:31.430Z]: (1458167071430): memmrk: 16839308 23709312
xdk:client:[2016-03-16T22:24:35.351Z]: (1458167075351): memmrk: 16354452 24724992
xdk:server:[2016-03-16T22:24:36.437Z]: (1458167076437): memmrk: 16846180 23709312
xdk:client:[2016-03-16T22:24:40.353Z]: (1458167080353): memmrk: 16356748 24724992
xdk:server:[2016-03-16T22:24:41.448Z]: (1458167081448): memmrk: 16853052 23709312
client:appcenter-options:[2016-03-16T22:24:44.805Z]: (1458167084805): could not get options
client:appcenter-options:[2016-03-16T22:24:44.809Z]: (1458167084809): Something went wrong. Could not create appCenterBaseUrl (undefined) for appCenterOption key/value pair (crosswalk/apk) in default.json
client:appcenter-options:[2016-03-16T22:24:44.812Z]: (1458167084812): Something went wrong. Could not create appCenterBaseUrl (undefined) for appCenterOption key/value pair (crosswalk/apk) in default.json
client:appcenter-options:[2016-03-16T22:24:44.815Z]: (1458167084815): Fetch Status: 3, Message: Loaded appcenter-options info from default json because both cache and network are not available.
xdk:client:[2016-03-16T22:24:44.816Z]: (1458167084816): Component "client:appcenter-options" finished delayed initialization
xdk:client:[2016-03-16T22:24:44.826Z]: (1458167084826): Component "client:test-tab" finished delayed initialization
cordova-registry:[2016-03-16T22:24:44.831Z]: (1458167084831): Dynamic plugin feed unavailable; using local feed    error: Http request aborted
xdk:client:[2016-03-16T22:24:44.832Z]: (1458167084832): Component "client:cordova-registry" finished delayed initialization
xdk:client:[2016-03-16T22:24:45.353Z]: (1458167085353): memmrk: 17513412 24724992
xdk:server:[2016-03-16T22:25:25.721Z]: (1458167125721): memmrk: 16859924 23709312
xdk:client:[2016-03-16T22:25:25.760Z]: (1458167125760): memmrk: 17515764 24724992
xdk:server:[2016-03-16T22:25:30.772Z]: (1458167130772): memmrk: 16866796 23709312
xdk:client:[2016-03-16T22:25:30.783Z]: (1458167130783): memmrk: 17518132 24724992
xdk:server:[2016-03-16T22:25:35.784Z]: (1458167135784): memmrk: 16873668 23709312
xdk:client:[2016-03-16T22:25:35.784Z]: (1458167135784): memmrk: 17520500 24724992
xdk:server:[2016-03-16T22:45:35.838Z]: (1458168335838): memmrk: 16876924 23709312
xdk:client:[2016-03-16T22:45:35.849Z]: (1458168335849): memmrk: 17523400 24724992
xdk:server:[2016-03-16T22:45:40.841Z]: (1458168340841): memmrk: 16883796 23709312
xdk:client:[2016-03-16T22:45:40.863Z]: (1458168340863): memmrk: 17525768 24724992
xdk:server:[2016-03-16T22:45:45.846Z]: (1458168345846): memmrk: 16890668 23709312
xdk:client:[2016-03-16T22:45:45.878Z]: (1458168345878): memmrk: 17528120 24724992
xdk:server:[2016-03-16T22:45:50.855Z]: (1458168350855): memmrk: 16897540 23709312
xdk:client:[2016-03-16T22:45:50.887Z]: (1458168350887): memmrk: 17530488 24724992
xdk:server:[2016-03-16T22:45:55.855Z]: (1458168355855): memmrk: 16904412 23709312
xdk:client:[2016-03-16T22:45:55.888Z]: (1458168355888): memmrk: 17532856 24724992
xdk:server:[2016-03-16T22:46:00.862Z]: (1458168360862): memmrk: 16911284 23709312
xdk:client:[2016-03-16T22:46:00.899Z]: (1458168360899): memmrk: 17535224 24724992
xdk:server:[2016-03-16T22:46:05.870Z]: (1458168365870): memmrk: 16918172 23709312
xdk:client:[2016-03-16T22:46:05.902Z]: (1458168365902): memmrk: 17537624 24724992
xdk:server:[2016-03-16T22:46:10.876Z]: (1458168370876): memmrk: 16925092 23709312
xdk:client:[2016-03-16T22:46:10.908Z]: (1458168370908): memmrk: 17540008 24724992
xdk:server:[2016-03-16T22:46:15.887Z]: (1458168375887): memmrk: 16931964 23709312
xdk:client:[2016-03-16T22:46:15.918Z]: (1458168375918): memmrk: 17542376 24724992
xdk:server:[2016-03-16T22:46:20.888Z]: (1458168380888): memmrk: 16938836 23709312
xdk:client:[2016-03-16T22:46:20.920Z]: (1458168380920): memmrk: 17544744 24724992
xdk:server:[2016-03-16T22:46:25.894Z]: (1458168385894): memmrk: 16945708 23709312
xdk:client:[2016-03-16T22:46:25.926Z]: (1458168385926): memmrk: 17547112 24724992
xdk:server:[2016-03-16T22:46:30.894Z]: (1458168390894): memmrk: 16952580 23709312
xdk:client:[2016-03-16T22:46:30.926Z]: (1458168390926): memmrk: 17549480 24724992
xdk:server:[2016-03-16T22:46:35.908Z]: (1458168395908): memmrk: 16959452 23709312
xdk:client:[2016-03-16T22:46:35.926Z]: (1458168395926): memmrk: 17551832 24724992
xdk:server:[2016-03-16T22:46:40.913Z]: (1458168400913): memmrk: 16966324 23709312
xdk:client:[2016-03-16T22:46:40.929Z]: (1458168400929): memmrk: 17554184 24724992
xdk:server:[2016-03-16T22:46:45.920Z]: (1458168405920): memmrk: 16973196 23709312
xdk:client:[2016-03-16T22:46:45.936Z]: (1458168405936): memmrk: 17556552 24724992
xdk:server:[2016-03-16T22:46:50.920Z]: (1458168410920): memmrk: 16980068 23709312
xdk:client:[2016-03-16T22:46:50.936Z]: (1458168410936): memmrk: 17558920 24724992
xdk:server:[2016-03-16T22:46:55.932Z]: (1458168415932): memmrk: 16986940 23709312
xdk:client:[2016-03-16T22:46:55.948Z]: (1458168415948): memmrk: 17561272 24724992
xdk:server:[2016-03-16T22:47:00.937Z]: (1458168420937): memmrk: 16993812 23709312
xdk:client:[2016-03-16T22:47:00.953Z]: (1458168420953): memmrk: 17563640 24724992
xdk:server:[2016-03-16T22:47:05.950Z]: (1458168425950): memmrk: 17000716 23709312
xdk:client:[2016-03-16T22:47:05.954Z]: (1458168425954): memmrk: 17566040 24724992
xdk:server:[2016-03-16T22:47:10.959Z]: (1458168430959): memmrk: 17007604 23709312
xdk:client:[2016-03-16T22:47:10.959Z]: (1458168430959): memmrk: 17568424 24724992
xdk:client:[2016-03-16T22:47:15.960Z]: (1458168435960): memmrk: 17570792 24724992
xdk:server:[2016-03-16T22:47:15.960Z]: (1458168435960): memmrk: 17014476 23709312
xdk:server:[2016-03-16T22:47:20.964Z]: (1458168440964): memmrk: 17028472 23709312
xdk:client:[2016-03-16T22:47:20.964Z]: (1458168440964): memmrk: 17573160 24724992
xdk:server:[2016-03-16T22:47:25.978Z]: (1458168445978): memmrk: 17035344 23709312
xdk:client:[2016-03-16T22:47:25.978Z]: (1458168445978): memmrk: 17575528 24724992
xdk:server:[2016-03-16T22:47:30.987Z]: (1458168450987): memmrk: 17042216 23709312
xdk:client:[2016-03-16T22:47:30.987Z]: (1458168450987): memmrk: 17577896 24724992
xdk:server:[2016-03-16T22:47:35.989Z]: (1458168455989): memmrk: 17049088 23709312
xdk:client:[2016-03-16T22:47:35.989Z]: (1458168455989): memmrk: 17580264 24724992
xdk:server:[2016-03-16T22:47:40.991Z]: (1458168460991): memmrk: 17055960 23709312
xdk:client:[2016-03-16T22:47:40.991Z]: (1458168460991): memmrk: 17582632 24724992
xdk:server:[2016-03-16T22:47:45.992Z]: (1458168465992): memmrk: 17062832 23709312
xdk:client:[2016-03-16T22:47:45.991Z]: (1458168465991): memmrk: 17585000 24724992
xdk:server:[2016-03-16T22:47:50.993Z]: (1458168470993): memmrk: 17069704 23709312
xdk:client:[2016-03-16T22:47:50.992Z]: (1458168470992): memmrk: 17587352 24724992
xdk:server:[2016-03-16T22:47:56.006Z]: (1458168476006): memmrk: 17076576 23709312
xdk:client:[2016-03-16T22:47:56.005Z]: (1458168476005): memmrk: 17589720 24724992
xdk:server:[2016-03-16T22:48:01.020Z]: (1458168481020): memmrk: 17083492 23709312
xdk:client:[2016-03-16T22:48:01.020Z]: (1458168481020): memmrk: 17592132 24724992
xdk:server:[2016-03-16T22:48:06.035Z]: (1458168486035): memmrk: 17090408 23709312
xdk:client:[2016-03-16T22:48:06.034Z]: (1458168486034): memmrk: 17594544 24724992
xdk:server:[2016-03-16T22:48:11.049Z]: (1458168491049): memmrk: 17097324 23709312
xdk:client:[2016-03-16T22:48:11.049Z]: (1458168491049): memmrk: 17596956 24724992
xdk:server:[2016-03-16T22:48:16.062Z]: (1458168496062): memmrk: 17104224 23709312
xdk:client:[2016-03-16T22:48:16.062Z]: (1458168496062): memmrk: 17599352 24724992
xdk:server:[2016-03-16T22:48:21.072Z]: (1458168501072): memmrk: 17111124 23709312
xdk:client:[2016-03-16T22:48:21.071Z]: (1458168501071): memmrk: 17601748 24724992
xdk:server:[2016-03-16T22:48:26.077Z]: (1458168506077): memmrk: 17118024 23709312
xdk:client:[2016-03-16T22:48:26.076Z]: (1458168506076): memmrk: 17604160 24724992
xdk:server:[2016-03-16T22:48:31.085Z]: (1458168511085): memmrk: 17124924 23709312
xdk:client:[2016-03-16T22:48:31.085Z]: (1458168511085): memmrk: 17606572 24724992
xdk:server:[2016-03-16T22:48:36.090Z]: (1458168516090): memmrk: 17131824 23709312
xdk:client:[2016-03-16T22:48:36.090Z]: (1458168516090): memmrk: 17608984 24724992
xdk:server:[2016-03-16T22:48:41.094Z]: (1458168521094): memmrk: 17138724 23709312
xdk:client:[2016-03-16T22:48:41.094Z]: (1458168521094): memmrk: 17611396 24724992
xdk:server:[2016-03-16T22:48:46.097Z]: (1458168526097): memmrk: 17145624 23709312
xdk:client:[2016-03-16T22:48:46.097Z]: (1458168526097): memmrk: 17613808 24724992
xdk:server:[2016-03-16T22:48:51.104Z]: (1458168531104): memmrk: 17152524 23709312
xdk:client:[2016-03-16T22:48:51.104Z]: (1458168531104): memmrk: 17616204 24724992
xdk:server:[2016-03-16T22:48:56.115Z]: (1458168536115): memmrk: 17159396 23709312
xdk:client:[2016-03-16T22:48:56.115Z]: (1458168536115): memmrk: 17618588 24724992
xdk:server:[2016-03-16T22:49:01.115Z]: (1458168541115): memmrk: 17166268 23709312
xdk:client:[2016-03-16T22:49:01.116Z]: (1458168541116): memmrk: 17620956 24724992
xdk:server:[2016-03-16T22:49:06.129Z]: (1458168546129): memmrk: 17173156 23709312
xdk:client:[2016-03-16T22:49:06.130Z]: (1458168546130): memmrk: 17623340 24724992
xdk:server:[2016-03-16T22:49:11.130Z]: (1458168551130): memmrk: 17180044 23709312
xdk:client:[2016-03-16T22:49:11.131Z]: (1458168551131): memmrk: 17625708 24724992
xdk:server:[2016-03-16T22:49:16.139Z]: (1458168556139): memmrk: 17186916 23709312
xdk:client:[2016-03-16T22:49:16.139Z]: (1458168556140): memmrk: 17628076 24724992
xdk:server:[2016-03-16T22:49:21.152Z]: (1458168561152): memmrk: 17193788 23709312
xdk:client:[2016-03-16T22:49:21.153Z]: (1458168561153): memmrk: 17630444 24724992
xdk:server:[2016-03-16T22:49:26.164Z]: (1458168566164): memmrk: 17200660 23709312
xdk:client:[2016-03-16T22:49:26.164Z]: (1458168566164): memmrk: 17632812 24724992
xdk:server:[2016-03-16T22:49:31.163Z]: (1458168571163): memmrk: 17207532 23709312
xdk:client:[2016-03-16T22:49:31.179Z]: (1458168571179): memmrk: 17635180 24724992
xdk:server:[2016-03-16T22:49:36.166Z]: (1458168576166): memmrk: 17214404 23709312
xdk:client:[2016-03-16T22:49:36.181Z]: (1458168576181): memmrk: 17637548 24724992
xdk:server:[2016-03-16T22:49:41.168Z]: (1458168581168): memmrk: 17221276 23709312
xdk:client:[2016-03-16T22:49:41.182Z]: (1458168581182): memmrk: 17639916 24724992
xdk:server:[2016-03-16T22:49:46.169Z]: (1458168586169): memmrk: 17228148 23709312
xdk:client:[2016-03-16T22:49:46.190Z]: (1458168586190): memmrk: 17642284 24724992
xdk:server:[2016-03-16T22:49:51.169Z]: (1458168591169): memmrk: 17235020 23709312
xdk:client:[2016-03-16T22:49:51.199Z]: (1458168591199): memmrk: 17644652 24724992
xdk:server:[2016-03-16T22:49:56.171Z]: (1458168596171): memmrk: 17241892 23709312
xdk:client:[2016-03-16T22:49:56.200Z]: (1458168596200): memmrk: 17647020 24724992
xdk:server:[2016-03-16T22:50:01.174Z]: (1458168601174): memmrk: 17248764 23709312
xdk:client:[2016-03-16T22:50:01.204Z]: (1458168601204): memmrk: 17649388 24724992
xdk:server:[2016-03-16T22:50:06.175Z]: (1458168606175): memmrk: 17255652 23709312
xdk:client:[2016-03-16T22:50:06.209Z]: (1458168606209): memmrk: 17651772 24724992
xdk:server:[2016-03-16T22:50:11.184Z]: (1458168611184): memmrk: 17262540 23709312
xdk:client:[2016-03-16T22:50:11.221Z]: (1458168611221): memmrk: 17654140 24724992
xdk:server:[2016-03-16T22:50:16.188Z]: (1458168616188): memmrk: 17268508 23709312
xdk:client:[2016-03-16T22:50:16.234Z]: (1458168616234): memmrk: 17656508 24724992
xdk:server:[2016-03-16T22:50:21.196Z]: (1458168621196): memmrk: 17275380 23709312
xdk:client:[2016-03-16T22:50:21.241Z]: (1458168621241): memmrk: 17658876 24724992
xdk:server:[2016-03-16T22:50:26.208Z]: (1458168626208): memmrk: 17282252 23709312
xdk:client:[2016-03-16T22:50:26.253Z]: (1458168626253): memmrk: 17661244 24724992
xdk:server:[2016-03-16T22:50:31.218Z]: (1458168631218): memmrk: 17289124 23709312
xdk:client:[2016-03-16T22:50:31.263Z]: (1458168631263): memmrk: 17663596 24724992
xdk:server:[2016-03-16T22:50:36.227Z]: (1458168636227): memmrk: 17295996 23709312
xdk:client:[2016-03-16T22:50:36.264Z]: (1458168636264): memmrk: 17665948 24724992
xdk:server:[2016-03-16T22:50:41.229Z]: (1458168641229): memmrk: 17302868 23709312
xdk:client:[2016-03-16T22:50:41.267Z]: (1458168641267): memmrk: 17668316 24724992
xdk:server:[2016-03-16T22:50:46.238Z]: (1458168646238): memmrk: 17309740 23709312
xdk:client:[2016-03-16T22:50:46.270Z]: (1458168646270): memmrk: 17670684 24724992
xdk:server:[2016-03-16T22:50:51.239Z]: (1458168651239): memmrk: 17316612 23709312
xdk:client:[2016-03-16T22:50:51.271Z]: (1458168651271): memmrk: 17673052 24724992
xdk:server:[2016-03-16T22:50:56.251Z]: (1458168656251): memmrk: 17323484 23709312
xdk:client:[2016-03-16T22:50:56.283Z]: (1458168656283): memmrk: 17675420 24724992
xdk:server:[2016-03-16T22:51:01.257Z]: (1458168661257): memmrk: 17330356 23709312
xdk:client:[2016-03-16T22:51:01.289Z]: (1458168661289): memmrk: 17677788 24724992
xdk:server:[2016-03-16T22:51:06.269Z]: (1458168666269): memmrk: 17337244 23709312
xdk:client:[2016-03-16T22:51:06.300Z]: (1458168666300): memmrk: 17680172 24724992
xdk:server:[2016-03-16T22:51:11.269Z]: (1458168671269): memmrk: 17344132 23709312
xdk:client:[2016-03-16T22:51:11.307Z]: (1458168671307): memmrk: 17682556 24724992
xdk:server:[2016-03-16T22:51:16.273Z]: (1458168676273): memmrk: 17351004 23709312
xdk:client:[2016-03-16T22:51:16.307Z]: (1458168676307): memmrk: 17684924 24724992
xdk:server:[2016-03-16T22:51:21.281Z]: (1458168681281): memmrk: 17357876 23709312
xdk:client:[2016-03-16T22:51:21.313Z]: (1458168681313): memmrk: 17687276 24724992
xdk:server:[2016-03-16T22:51:26.289Z]: (1458168686289): memmrk: 17364748 23709312
xdk:client:[2016-03-16T22:51:26.321Z]: (1458168686321): memmrk: 17689644 24724992
xdk:server:[2016-03-16T22:51:31.301Z]: (1458168691301): memmrk: 17371620 23709312
xdk:client:[2016-03-16T22:51:31.333Z]: (1458168691333): memmrk: 17692012 24724992
xdk:server:[2016-03-16T22:51:36.310Z]: (1458168696310): memmrk: 17378492 23709312
xdk:client:[2016-03-16T22:51:36.341Z]: (1458168696341): memmrk: 17694380 24724992
xdk:server:[2016-03-16T22:51:41.312Z]: (1458168701312): memmrk: 17385364 23709312
xdk:client:[2016-03-16T22:51:41.342Z]: (1458168701342): memmrk: 17696748 24724992
xdk:server:[2016-03-16T22:51:46.323Z]: (1458168706323): memmrk: 17392236 23709312
xdk:client:[2016-03-16T22:51:46.354Z]: (1458168706354): memmrk: 17699116 24724992
xdk:server:[2016-03-16T22:51:51.331Z]: (1458168711331): memmrk: 17399108 23709312
xdk:client:[2016-03-16T22:51:51.368Z]: (1458168711368): memmrk: 17701484 24724992
xdk:server:[2016-03-16T22:51:56.334Z]: (1458168716334): memmrk: 17405980 23709312
xdk:client:[2016-03-16T22:51:56.368Z]: (1458168716368): memmrk: 17703852 24724992
xdk:server:[2016-03-16T22:52:01.346Z]: (1458168721346): memmrk: 17412852 23709312
xdk:client:[2016-03-16T22:52:01.376Z]: (1458168721376): memmrk: 17706204 24724992
xdk:server:[2016-03-16T22:52:06.356Z]: (1458168726356): memmrk: 17419740 23709312
xdk:client:[2016-03-16T22:52:06.387Z]: (1458168726387): memmrk: 17708604 24724992
xdk:server:[2016-03-16T22:52:11.370Z]: (1458168731370): memmrk: 17426628 23709312
xdk:client:[2016-03-16T22:52:11.401Z]: (1458168731401): memmrk: 17710988 24724992
xdk:server:[2016-03-16T22:52:16.381Z]: (1458168736381): memmrk: 17436504 23709312
xdk:client:[2016-03-16T22:52:16.411Z]: (1458168736411): memmrk: 17713356 24724992
xdk:server:[2016-03-16T22:52:21.395Z]: (1458168741395): memmrk: 17443376 23709312
xdk:client:[2016-03-16T22:52:21.425Z]: (1458168741425): memmrk: 17715724 24724992
xdk:server:[2016-03-16T22:52:26.396Z]: (1458168746396): memmrk: 17450248 23709312
xdk:client:[2016-03-16T22:52:26.436Z]: (1458168746436): memmrk: 17718092 24724992
xdk:server:[2016-03-16T22:52:31.401Z]: (1458168751401): memmrk: 17457120 23709312
xdk:client:[2016-03-16T22:52:31.438Z]: (1458168751438): memmrk: 17720460 24724992
xdk:server:[2016-03-16T22:52:36.410Z]: (1458168756410): memmrk: 17463992 23709312
xdk:client:[2016-03-16T22:52:36.448Z]: (1458168756448): memmrk: 17722828 24724992
xdk:server:[2016-03-16T22:52:41.414Z]: (1458168761414): memmrk: 17470864 23709312
xdk:client:[2016-03-16T22:52:41.448Z]: (1458168761448): memmrk: 17725196 24724992
xdk:server:[2016-03-16T22:52:46.425Z]: (1458168766425): memmrk: 16514144 23709312
xdk:client:[2016-03-16T22:52:46.456Z]: (1458168766456): memmrk: 17727548 24724992
xdk:server:[2016-03-16T22:52:51.425Z]: (1458168771425): memmrk: 16521016 23709312
xdk:client:[2016-03-16T22:52:51.455Z]: (1458168771455): memmrk: 17729916 24724992
xdk:server:[2016-03-16T22:52:56.425Z]: (1458168776425): memmrk: 16534400 23709312
xdk:client:[2016-03-16T22:52:56.456Z]: (1458168776456): memmrk: 17732284 24724992
xdk:server:[2016-03-16T22:53:01.427Z]: (1458168781427): memmrk: 16555188 23709312
xdk:client:[2016-03-16T22:53:01.469Z]: (1458168781469): memmrk: 17734636 24724992
xdk:server:[2016-03-16T22:53:06.428Z]: (1458168786428): memmrk: 16561996 23709312
xdk:client:[2016-03-16T22:53:06.474Z]: (1458168786474): memmrk: 17737036 24724992
xdk:server:[2016-03-16T22:53:11.432Z]: (1458168791432): memmrk: 16568804 23709312
xdk:client:[2016-03-16T22:53:11.485Z]: (1458168791485): memmrk: 17739420 24724992
xdk:server:[2016-03-16T22:53:16.438Z]: (1458168796438): memmrk: 16575596 23709312
xdk:client:[2016-03-16T22:53:16.490Z]: (1458168796490): memmrk: 17741788 24724992
xdk:server:[2016-03-16T22:53:21.442Z]: (1458168801442): memmrk: 16583504 23709312
xdk:client:[2016-03-16T22:53:21.495Z]: (1458168801495): memmrk: 17744348 24724992
xdk:server:[2016-03-16T22:53:26.452Z]: (1458168806452): memmrk: 16590296 23709312
xdk:client:[2016-03-16T22:53:26.498Z]: (1458168806498): memmrk: 17746716 24724992
xdk:server:[2016-03-16T22:53:31.464Z]: (1458168811464): memmrk: 16597088 23709312
xdk:client:[2016-03-16T22:53:31.510Z]: (1458168811510): memmrk: 17749084 24724992
xdk:server:[2016-03-16T22:53:36.464Z]: (1458168816464): memmrk: 16603880 23709312
xdk:client:[2016-03-16T22:53:36.515Z]: (1458168816515): memmrk: 17753128 24724992
xdk:server:[2016-03-16T22:53:41.470Z]: (1458168821470): memmrk: 16610672 23709312
xdk:client:[2016-03-16T22:53:41.523Z]: (1458168821523): memmrk: 17755496 24724992
xdk:server:[2016-03-16T22:53:46.477Z]: (1458168826477): memmrk: 16617464 23709312
xdk:client:[2016-03-16T22:53:46.524Z]: (1458168826524): memmrk: 17757864 24724992
xdk:server:[2016-03-16T22:53:51.478Z]: (1458168831478): memmrk: 16624256 23709312
xdk:client:[2016-03-16T22:53:51.532Z]: (1458168831532): memmrk: 17760232 24724992
xdk:server:[2016-03-16T22:53:56.492Z]: (1458168836492): memmrk: 16631080 23709312
xdk:client:[2016-03-16T22:53:56.539Z]: (1458168836539): memmrk: 17762600 24724992
xdk:server:[2016-03-16T22:54:01.496Z]: (1458168841496): memmrk: 16643104 23709312
xdk:client:[2016-03-16T22:54:01.543Z]: (1458168841543): memmrk: 17764968 24724992
xdk:server:[2016-03-16T22:54:06.510Z]: (1458168846510): memmrk: 16649912 23709312
xdk:client:[2016-03-16T22:54:06.548Z]: (1458168846548): memmrk: 17767336 24724992
xdk:server:[2016-03-16T22:54:11.514Z]: (1458168851514): memmrk: 16656720 23709312
xdk:client:[2016-03-16T22:54:11.561Z]: (1458168851561): memmrk: 17769720 24724992
xdk:server:[2016-03-16T22:54:16.515Z]: (1458168856515): memmrk: 16663512 23709312
xdk:client:[2016-03-16T22:54:16.562Z]: (1458168856562): memmrk: 17772088 24724992
xdk:server:[2016-03-16T22:54:21.523Z]: (1458168861523): memmrk: 16670304 23709312
xdk:client:[2016-03-16T22:54:21.577Z]: (1458168861577): memmrk: 17774456 24724992
xdk:server:[2016-03-16T22:54:26.537Z]: (1458168866537): memmrk: 16677096 23709312
xdk:client:[2016-03-16T22:54:26.591Z]: (1458168866591): memmrk: 17776824 24724992
xdk:server:[2016-03-16T22:54:31.538Z]: (1458168871538): memmrk: 16683888 23709312
xdk:client:[2016-03-16T22:54:31.593Z]: (1458168871593): memmrk: 17779192 24724992
xdk:server:[2016-03-16T22:57:56.499Z]: (1458169076499): memmrk: 16687064 23709312
xdk:client:[2016-03-16T22:57:56.499Z]: (1458169076499): memmrk: 17781560 24724992
xdk:server:[2016-03-16T22:58:01.513Z]: (1458169081513): memmrk: 16693856 23709312
xdk:client:[2016-03-16T22:58:01.513Z]: (1458169081513): memmrk: 17783944 24724992
xdk:server:[2016-03-16T22:58:06.516Z]: (1458169086516): memmrk: 16700664 23709312
xdk:client:[2016-03-16T22:58:06.516Z]: (1458169086516): memmrk: 17786344 24724992
xdk:client:[2016-03-16T22:58:11.515Z]: (1458169091515): memmrk: 17788728 24724992
xdk:server:[2016-03-16T22:58:11.532Z]: (1458169091532): memmrk: 16707472 23709312
xdk:client:[2016-03-16T22:58:16.517Z]: (1458169096517): memmrk: 17791080 24724992
xdk:server:[2016-03-16T22:58:16.533Z]: (1458169096533): memmrk: 16714264 23709312
xdk:client:[2016-03-16T22:58:21.519Z]: (1458169101519): memmrk: 17793448 24724992
xdk:server:[2016-03-16T22:58:21.535Z]: (1458169101535): memmrk: 16721056 23709312
xdk:client:[2016-03-16T22:58:26.529Z]: (1458169106529): memmrk: 17795816 24724992
xdk:server:[2016-03-16T22:58:26.535Z]: (1458169106535): memmrk: 16727848 23709312
xdk:client:[2016-03-16T22:58:31.530Z]: (1458169111530): memmrk: 17798184 24724992
xdk:server:[2016-03-16T22:58:31.535Z]: (1458169111535): memmrk: 16734640 23709312
xdk:client:[2016-03-16T22:58:36.535Z]: (1458169116535): memmrk: 17800552 24724992
xdk:server:[2016-03-16T22:58:36.536Z]: (1458169116536): memmrk: 16741432 23709312
xdk:server:[2016-03-16T22:58:41.543Z]: (1458169121543): memmrk: 16751744 23709312
xdk:client:[2016-03-16T22:58:41.542Z]: (1458169121542): memmrk: 17802920 24724992
xdk:server:[2016-03-16T22:58:46.553Z]: (1458169126553): memmrk: 16758536 23709312
xdk:client:[2016-03-16T22:58:46.553Z]: (1458169126553): memmrk: 17805288 24724992
xdk:server:[2016-03-16T22:58:51.562Z]: (1458169131562): memmrk: 16765996 23709312
xdk:client:[2016-03-16T22:58:51.562Z]: (1458169131562): memmrk: 17807656 24724992
xdk:server:[2016-03-16T22:58:56.577Z]: (1458169136577): memmrk: 16772788 23709312
xdk:client:[2016-03-16T22:58:56.577Z]: (1458169136577): memmrk: 17810008 24724992
xdk:server:[2016-03-16T22:59:01.580Z]: (1458169141580): memmrk: 16779580 23709312
xdk:client:[2016-03-16T22:59:01.581Z]: (1458169141581): memmrk: 17812360 24724992
xdk:server:[2016-03-16T22:59:06.593Z]: (1458169146593): memmrk: 16786388 23709312
xdk:client:[2016-03-16T22:59:06.594Z]: (1458169146594): memmrk: 17814760 24724992
xdk:server:[2016-03-16T22:59:11.593Z]: (1458169151593): memmrk: 16793196 23709312
xdk:client:[2016-03-16T22:59:11.594Z]: (1458169151594): memmrk: 17817144 24724992
xdk:server:[2016-03-16T22:59:16.602Z]: (1458169156602): memmrk: 16799988 23709312
xdk:client:[2016-03-16T22:59:16.603Z]: (1458169156603): memmrk: 17819496 24724992
xdk:server:[2016-03-16T22:59:21.604Z]: (1458169161604): memmrk: 16806780 23709312
xdk:client:[2016-03-16T22:59:21.605Z]: (1458169161605): memmrk: 17821864 24724992
xdk:client:[2016-03-16T22:59:26.607Z]: (1458169166607): memmrk: 17824232 24724992
xdk:server:[2016-03-16T22:59:26.607Z]: (1458169166607): memmrk: 16813572 23709312
xdk:server:[2016-03-16T22:59:31.608Z]: (1458169171608): memmrk: 16820364 23709312
xdk:client:[2016-03-16T22:59:31.609Z]: (1458169171609): memmrk: 17826600 24724992
xdk:server:[2016-03-16T22:59:36.613Z]: (1458169176613): memmrk: 16827176 23709312
xdk:client:[2016-03-16T22:59:36.614Z]: (1458169176614): memmrk: 17828968 24724992
xdk:client:[2016-03-16T22:59:41.615Z]: (1458169181615): memmrk: 17831336 24724992
xdk:server:[2016-03-16T22:59:41.614Z]: (1458169181614): memmrk: 16833968 23709312
xdk:server:[2016-03-16T22:59:46.616Z]: (1458169186616): memmrk: 16849892 23709312
xdk:client:[2016-03-16T22:59:46.616Z]: (1458169186616): memmrk: 17833704 24724992
xdk:server:[2016-03-16T22:59:51.622Z]: (1458169191622): memmrk: 16856684 23709312
xdk:client:[2016-03-16T22:59:51.623Z]: (1458169191623): memmrk: 17836072 24724992
xdk:server:[2016-03-16T22:59:56.625Z]: (1458169196625): memmrk: 16863476 23709312
xdk:client:[2016-03-16T22:59:56.625Z]: (1458169196625): memmrk: 17838440 24724992
xdk:server:[2016-03-16T23:00:01.638Z]: (1458169201638): memmrk: 16870268 23709312
xdk:client:[2016-03-16T23:00:01.637Z]: (1458169201637): memmrk: 17840808 24724992
xdk:server:[2016-03-16T23:00:06.650Z]: (1458169206650): memmrk: 16877092 23709312
xdk:client:[2016-03-16T23:00:06.650Z]: (1458169206650): memmrk: 17843208 24724992
xdk:server:[2016-03-16T23:00:11.660Z]: (1458169211660): memmrk: 16883916 23709312
xdk:client:[2016-03-16T23:00:11.660Z]: (1458169211660): memmrk: 17845608 24724992
xdk:server:[2016-03-16T23:00:16.661Z]: (1458169216661): memmrk: 16890724 23709312
xdk:client:[2016-03-16T23:00:16.660Z]: (1458169216661): memmrk: 17847992 24724992
xdk:server:[2016-03-16T23:00:21.674Z]: (1458169221674): memmrk: 16897532 23709312
xdk:client:[2016-03-16T23:00:21.673Z]: (1458169221673): memmrk: 17850360 24724992
xdk:server:[2016-03-16T23:00:26.681Z]: (1458169226681): memmrk: 16904340 23709312
xdk:client:[2016-03-16T23:00:26.680Z]: (1458169226680): memmrk: 17852744 24724992
xdk:server:[2016-03-16T23:00:31.692Z]: (1458169231692): memmrk: 16911148 23709312
xdk:client:[2016-03-16T23:00:31.691Z]: (1458169231691): memmrk: 17855128 24724992
xdk:server:[2016-03-16T23:00:36.694Z]: (1458169236694): memmrk: 16917956 23709312
xdk:client:[2016-03-16T23:00:36.694Z]: (1458169236694): memmrk: 17857512 24724992
xdk:server:[2016-03-16T23:00:41.696Z]: (1458169241696): memmrk: 16924764 23709312
xdk:client:[2016-03-16T23:00:41.696Z]: (1458169241696): memmrk: 17859896 24724992
xdk:server:[2016-03-16T23:00:46.707Z]: (1458169246707): memmrk: 16931572 23709312
xdk:client:[2016-03-16T23:00:46.706Z]: (1458169246706): memmrk: 17862280 24724992
xdk:server:[2016-03-16T23:00:51.710Z]: (1458169251710): memmrk: 16938380 23709312
xdk:client:[2016-03-16T23:00:51.710Z]: (1458169251710): memmrk: 17864664 24724992
xdk:client:[2016-03-16T23:00:56.723Z]: (1458169256723): memmrk: 17867048 24724992
xdk:server:[2016-03-16T23:00:56.723Z]: (1458169256723): memmrk: 16945188 23709312
xdk:client:[2016-03-16T23:01:01.723Z]: (1458169261723): memmrk: 17869432 24724992
xdk:server:[2016-03-16T23:01:01.724Z]: (1458169261724): memmrk: 16951996 23709312
xdk:server:[2016-03-16T23:01:06.729Z]: (1458169266729): memmrk: 16958820 23709312
xdk:client:[2016-03-16T23:01:06.729Z]: (1458169266729): memmrk: 17871816 24724992
xdk:server:[2016-03-16T23:01:11.736Z]: (1458169271736): memmrk: 16965644 23709312
xdk:client:[2016-03-16T23:01:11.735Z]: (1458169271735): memmrk: 17874216 24724992
xdk:server:[2016-03-16T23:01:16.747Z]: (1458169276747): memmrk: 16972452 23709312
xdk:client:[2016-03-16T23:01:16.746Z]: (1458169276746): memmrk: 17876600 24724992
xdk:server:[2016-03-16T23:01:21.756Z]: (1458169281756): memmrk: 16979260 23709312
xdk:client:[2016-03-16T23:01:21.756Z]: (1458169281756): memmrk: 17878984 24724992
xdk:server:[2016-03-16T23:01:26.769Z]: (1458169286769): memmrk: 16986068 23709312
xdk:client:[2016-03-16T23:01:26.768Z]: (1458169286768): memmrk: 17881368 24724992
xdk:server:[2016-03-16T23:01:31.769Z]: (1458169291769): memmrk: 16992876 23709312
xdk:client:[2016-03-16T23:01:31.768Z]: (1458169291768): memmrk: 17883752 24724992
xdk:server:[2016-03-16T23:01:36.769Z]: (1458169296769): memmrk: 16999684 23709312
xdk:client:[2016-03-16T23:01:36.769Z]: (1458169296769): memmrk: 17886120 24724992
xdk:server:[2016-03-16T23:01:41.769Z]: (1458169301769): memmrk: 17006492 23709312
xdk:client:[2016-03-16T23:01:41.769Z]: (1458169301769): memmrk: 17888504 24724992
xdk:server:[2016-03-16T23:01:46.769Z]: (1458169306769): memmrk: 17013300 23709312
xdk:client:[2016-03-16T23:01:46.770Z]: (1458169306770): memmrk: 17890872 24724992
xdk:server:[2016-03-16T23:01:51.770Z]: (1458169311770): memmrk: 17020108 23709312
xdk:client:[2016-03-16T23:01:51.772Z]: (1458169311772): memmrk: 17893256 24724992
xdk:server:[2016-03-16T23:01:56.771Z]: (1458169316771): memmrk: 17026916 23709312
xdk:client:[2016-03-16T23:01:56.772Z]: (1458169316772): memmrk: 17137492 24724992
xdk:server:[2016-03-16T23:02:01.770Z]: (1458169321770): memmrk: 17033724 23709312
xdk:client:[2016-03-16T23:02:01.773Z]: (1458169321773): memmrk: 17140560 24724992
xdk:server:[2016-03-16T23:02:06.771Z]: (1458169326771): memmrk: 17040548 23709312
xdk:client:[2016-03-16T23:02:06.772Z]: (1458169326772): memmrk: 17142976 24724992
xdk:server:[2016-03-16T23:02:11.770Z]: (1458169331770): memmrk: 17047372 23709312
xdk:client:[2016-03-16T23:02:11.773Z]: (1458169331773): memmrk: 17145376 24724992
xdk:server:[2016-03-16T23:02:16.771Z]: (1458169336771): memmrk: 17054180 23709312
xdk:client:[2016-03-16T23:02:16.772Z]: (1458169336772): memmrk: 17147760 24724992
xdk:server:[2016-03-16T23:02:21.771Z]: (1458169341771): memmrk: 17060988 23709312
xdk:client:[2016-03-16T23:02:21.773Z]: (1458169341773): memmrk: 17150144 24724992
xdk:server:[2016-03-16T23:02:26.771Z]: (1458169346771): memmrk: 17067796 23709312
xdk:client:[2016-03-16T23:02:26.773Z]: (1458169346773): memmrk: 17152528 24724992
xdk:server:[2016-03-16T23:02:31.771Z]: (1458169351771): memmrk: 17074604 23709312
xdk:client:[2016-03-16T23:02:31.774Z]: (1458169351774): memmrk: 17154912 24724992
xdk:server:[2016-03-16T23:02:36.772Z]: (1458169356772): memmrk: 17081412 23709312
xdk:client:[2016-03-16T23:02:36.773Z]: (1458169356773): memmrk: 17157312 24724992
xdk:server:[2016-03-16T23:02:41.772Z]: (1458169361772): memmrk: 17088220 23709312
xdk:client:[2016-03-16T23:02:41.774Z]: (1458169361774): memmrk: 17159696 24724992
xdk:server:[2016-03-16T23:02:46.772Z]: (1458169366772): memmrk: 17095028 23709312
xdk:client:[2016-03-16T23:02:46.774Z]: (1458169366774): memmrk: 17162080 24724992
xdk:server:[2016-03-16T23:02:51.772Z]: (1458169371772): memmrk: 17101836 23709312
xdk:client:[2016-03-16T23:02:51.775Z]: (1458169371775): memmrk: 17164464 24724992
xdk:server:[2016-03-16T23:02:56.772Z]: (1458169376772): memmrk: 17108644 23709312
xdk:client:[2016-03-16T23:02:56.774Z]: (1458169376774): memmrk: 17166864 24724992
xdk:server:[2016-03-16T23:03:01.773Z]: (1458169381773): memmrk: 17115452 23709312
xdk:client:[2016-03-16T23:03:01.773Z]: (1458169381773): memmrk: 17169248 24724992
xdk:server:[2016-03-16T23:03:06.773Z]: (1458169386773): memmrk: 17122276 23709312
xdk:client:[2016-03-16T23:03:06.774Z]: (1458169386774): memmrk: 17171648 24724992
xdk:server:[2016-03-16T23:03:11.774Z]: (1458169391774): memmrk: 17129100 23709312
xdk:client:[2016-03-16T23:03:11.774Z]: (1458169391774): memmrk: 17174048 24724992
xdk:server:[2016-03-16T23:03:16.774Z]: (1458169396774): memmrk: 17135908 23709312
xdk:client:[2016-03-16T23:03:16.775Z]: (1458169396775): memmrk: 17176432 24724992
xdk:server:[2016-03-16T23:03:21.774Z]: (1458169401774): memmrk: 17145340 23709312
xdk:client:[2016-03-16T23:03:21.776Z]: (1458169401776): memmrk: 17178816 24724992
xdk:server:[2016-03-16T23:03:26.774Z]: (1458169406774): memmrk: 17152148 23709312
xdk:client:[2016-03-16T23:03:26.776Z]: (1458169406776): memmrk: 17181216 24724992
xdk:server:[2016-03-16T23:03:31.775Z]: (1458169411775): memmrk: 17158956 23709312
xdk:client:[2016-03-16T23:03:31.776Z]: (1458169411776): memmrk: 17183600 24724992
xdk:server:[2016-03-16T23:03:36.774Z]: (1458169416774): memmrk: 17165764 23709312
xdk:client:[2016-03-16T23:03:36.776Z]: (1458169416776): memmrk: 17185984 24724992
xdk:server:[2016-03-16T23:03:41.776Z]: (1458169421776): memmrk: 17172572 23709312
xdk:client:[2016-03-16T23:03:41.776Z]: (1458169421776): memmrk: 17188368 24724992
xdk:server:[2016-03-16T23:03:46.776Z]: (1458169426776): memmrk: 17179380 23709312
xdk:client:[2016-03-16T23:03:46.776Z]: (1458169426776): memmrk: 17190752 24724992
xdk:server:[2016-03-16T23:03:51.776Z]: (1458169431776): memmrk: 17186188 23709312
xdk:client:[2016-03-16T23:03:51.776Z]: (1458169431776): memmrk: 17193136 24724992
xdk:server:[2016-03-16T23:03:56.777Z]: (1458169436777): memmrk: 17192996 23709312
xdk:client:[2016-03-16T23:03:56.778Z]: (1458169436778): memmrk: 17195520 24724992
xdk:server:[2016-03-16T23:04:01.777Z]: (1458169441777): memmrk: 17199804 23709312
xdk:client:[2016-03-16T23:04:01.778Z]: (1458169441778): memmrk: 17197920 24724992
xdk:server:[2016-03-16T23:04:06.777Z]: (1458169446777): memmrk: 17209932 23709312
xdk:client:[2016-03-16T23:04:06.779Z]: (1458169446779): memmrk: 17200320 24724992
xdk:server:[2016-03-16T23:04:11.778Z]: (1458169451778): memmrk: 17216756 23709312
xdk:client:[2016-03-16T23:04:11.779Z]: (1458169451779): memmrk: 17202736 24724992
xdk:server:[2016-03-16T23:04:16.778Z]: (1458169456778): memmrk: 17223564 23709312
xdk:client:[2016-03-16T23:04:16.779Z]: (1458169456779): memmrk: 17205120 24724992
xdk:server:[2016-03-16T23:04:21.780Z]: (1458169461780): memmrk: 17238896 23709312
xdk:client:[2016-03-16T23:04:21.780Z]: (1458169461780): memmrk: 17207504 24724992
xdk:server:[2016-03-16T23:04:26.779Z]: (1458169466779): memmrk: 17245704 23709312
xdk:client:[2016-03-16T23:04:26.780Z]: (1458169466780): memmrk: 17209936 24724992
xdk:server:[2016-03-16T23:04:31.780Z]: (1458169471780): memmrk: 17252884 23709312
xdk:client:[2016-03-16T23:04:31.781Z]: (1458169471781): memmrk: 17212320 24724992
xdk:server:[2016-03-16T23:04:36.780Z]: (1458169476780): memmrk: 17259692 23709312
xdk:client:[2016-03-16T23:04:36.781Z]: (1458169476781): memmrk: 17214720 24724992
xdk:server:[2016-03-16T23:04:41.780Z]: (1458169481780): memmrk: 17266500 23709312
xdk:client:[2016-03-16T23:04:41.782Z]: (1458169481782): memmrk: 17217104 24724992
xdk:server:[2016-03-16T23:04:46.780Z]: (1458169486780): memmrk: 17273308 23709312
xdk:client:[2016-03-16T23:04:46.782Z]: (1458169486782): memmrk: 17219504 24724992
xdk:client:[2016-03-16T23:04:51.782Z]: (1458169491782): memmrk: 17221888 24724992
xdk:server:[2016-03-16T23:04:51.781Z]: (1458169491781): memmrk: 17280116 23709312
xdk:server:[2016-03-16T23:04:56.782Z]: (1458169496782): memmrk: 17299932 24712832
xdk:client:[2016-03-16T23:04:56.782Z]: (1458169496782): memmrk: 17224272 24724992
xdk:server:[2016-03-16T23:05:01.781Z]: (1458169501781): memmrk: 17306792 24712832
xdk:client:[2016-03-16T23:05:01.783Z]: (1458169501783): memmrk: 17226656 24724992
xdk:server:[2016-03-16T23:05:06.782Z]: (1458169506782): memmrk: 17313616 24712832
xdk:client:[2016-03-16T23:05:06.783Z]: (1458169506783): memmrk: 17229056 24724992
xdk:server:[2016-03-16T23:05:11.781Z]: (1458169511781): memmrk: 17320440 24712832
xdk:client:[2016-03-16T23:05:11.784Z]: (1458169511784): memmrk: 17231456 24724992
xdk:server:[2016-03-16T23:05:16.783Z]: (1458169516783): memmrk: 17327248 24712832
xdk:client:[2016-03-16T23:05:16.785Z]: (1458169516785): memmrk: 17233840 24724992
xdk:server:[2016-03-16T23:05:21.784Z]: (1458169521784): memmrk: 17334056 24712832
xdk:client:[2016-03-16T23:05:21.785Z]: (1458169521786): memmrk: 17236240 24724992
xdk:server:[2016-03-16T23:05:26.783Z]: (1458169526783): memmrk: 17340848 24712832
xdk:client:[2016-03-16T23:05:26.786Z]: (1458169526786): memmrk: 17238624 24724992
xdk:server:[2016-03-16T23:05:31.784Z]: (1458169531784): memmrk: 17347656 24712832
xdk:client:[2016-03-16T23:05:31.786Z]: (1458169531786): memmrk: 17241024 24724992
xdk:server:[2016-03-16T23:05:36.785Z]: (1458169536785): memmrk: 17354464 24712832
xdk:client:[2016-03-16T23:05:36.786Z]: (1458169536787): memmrk: 17243408 24724992
xdk:server:[2016-03-16T23:05:41.785Z]: (1458169541785): memmrk: 17361272 24712832
xdk:client:[2016-03-16T23:05:41.787Z]: (1458169541787): memmrk: 17245792 24724992
xdk:server:[2016-03-16T23:05:46.785Z]: (1458169546785): memmrk: 17368080 24712832
xdk:client:[2016-03-16T23:05:46.788Z]: (1458169546788): memmrk: 17248192 24724992
xdk:server:[2016-03-16T23:05:51.786Z]: (1458169551786): memmrk: 17374888 24712832
xdk:client:[2016-03-16T23:05:51.788Z]: (1458169551788): memmrk: 17250592 24724992
xdk:server:[2016-03-16T23:05:56.786Z]: (1458169556786): memmrk: 17381696 24712832
xdk:client:[2016-03-16T23:05:56.788Z]: (1458169556788): memmrk: 17252976 24724992
xdk:server:[2016-03-16T23:06:01.786Z]: (1458169561786): memmrk: 17388504 24712832
xdk:client:[2016-03-16T23:06:01.788Z]: (1458169561788): memmrk: 17255360 24724992
xdk:server:[2016-03-16T23:06:06.787Z]: (1458169566787): memmrk: 17395328 24712832
xdk:client:[2016-03-16T23:06:06.788Z]: (1458169566788): memmrk: 17257760 24724992
xdk:server:[2016-03-16T23:06:11.787Z]: (1458169571787): memmrk: 17402152 24712832
xdk:client:[2016-03-16T23:06:11.789Z]: (1458169571789): memmrk: 17260160 24724992
xdk:server:[2016-03-16T23:06:16.787Z]: (1458169576787): memmrk: 17408960 24712832
xdk:client:[2016-03-16T23:06:16.789Z]: (1458169576789): memmrk: 17262560 24724992
xdk:server:[2016-03-16T23:06:21.788Z]: (1458169581788): memmrk: 17415768 24712832
xdk:client:[2016-03-16T23:06:21.790Z]: (1458169581790): memmrk: 17264944 24724992
xdk:server:[2016-03-16T23:06:26.788Z]: (1458169586788): memmrk: 17422592 24712832
xdk:client:[2016-03-16T23:06:26.791Z]: (1458169586791): memmrk: 17267344 24724992
xdk:server:[2016-03-16T23:06:31.789Z]: (1458169591789): memmrk: 17429400 24712832
xdk:client:[2016-03-16T23:06:31.791Z]: (1458169591791): memmrk: 17269744 24724992
xdk:server:[2016-03-16T23:06:36.789Z]: (1458169596789): memmrk: 17436208 24712832
xdk:client:[2016-03-16T23:06:36.791Z]: (1458169596791): memmrk: 17272128 24724992
xdk:server:[2016-03-16T23:06:41.789Z]: (1458169601789): memmrk: 17443016 24712832
xdk:client:[2016-03-16T23:06:41.792Z]: (1458169601792): memmrk: 17274512 24724992
xdk:server:[2016-03-16T23:06:46.790Z]: (1458169606790): memmrk: 17449824 24712832
xdk:client:[2016-03-16T23:06:46.792Z]: (1458169606792): memmrk: 17276912 24724992
xdk:server:[2016-03-16T23:06:51.790Z]: (1458169611790): memmrk: 17456632 24712832
xdk:client:[2016-03-16T23:06:51.792Z]: (1458169611792): memmrk: 17279296 24724992
xdk:server:[2016-03-16T23:06:56.790Z]: (1458169616790): memmrk: 17463440 24712832
xdk:client:[2016-03-16T23:06:56.792Z]: (1458169616792): memmrk: 17281680 24724992
xdk:server:[2016-03-16T23:07:01.791Z]: (1458169621791): memmrk: 17470248 24712832
xdk:client:[2016-03-16T23:07:01.792Z]: (1458169621792): memmrk: 17284064 24724992
xdk:server:[2016-03-16T23:07:06.791Z]: (1458169626791): memmrk: 17477072 24712832
xdk:client:[2016-03-16T23:07:06.792Z]: (1458169626792): memmrk: 17286464 24724992
xdk:server:[2016-03-16T23:07:11.791Z]: (1458169631791): memmrk: 17483896 24712832
xdk:client:[2016-03-16T23:07:11.792Z]: (1458169631793): memmrk: 17288864 24724992
xdk:server:[2016-03-16T23:07:16.792Z]: (1458169636792): memmrk: 17490704 24712832
xdk:client:[2016-03-16T23:07:16.793Z]: (1458169636793): memmrk: 17291248 24724992
xdk:server:[2016-03-16T23:07:21.792Z]: (1458169641792): memmrk: 17497512 24712832
xdk:client:[2016-03-16T23:07:21.794Z]: (1458169641794): memmrk: 17295408 24724992
xdk:server:[2016-03-16T23:07:26.793Z]: (1458169646793): memmrk: 17504320 24712832
xdk:client:[2016-03-16T23:07:26.794Z]: (1458169646794): memmrk: 17297808 24724992
xdk:server:[2016-03-16T23:07:31.793Z]: (1458169651793): memmrk: 17511128 24712832
xdk:client:[2016-03-16T23:07:31.794Z]: (1458169651794): memmrk: 17300192 24724992
xdk:server:[2016-03-16T23:07:36.793Z]: (1458169656793): memmrk: 17517936 24712832
xdk:client:[2016-03-16T23:07:36.795Z]: (1458169656795): memmrk: 17302576 24724992
xdk:server:[2016-03-16T23:07:41.793Z]: (1458169661793): memmrk: 17524744 24712832
xdk:client:[2016-03-16T23:07:41.795Z]: (1458169661795): memmrk: 17304976 24724992
xdk:server:[2016-03-16T23:07:46.794Z]: (1458169666794): memmrk: 17531552 24712832
xdk:client:[2016-03-16T23:07:46.795Z]: (1458169666795): memmrk: 17307360 24724992
xdk:server:[2016-03-16T23:07:51.794Z]: (1458169671794): memmrk: 17538360 24712832
xdk:client:[2016-03-16T23:07:51.796Z]: (1458169671796): memmrk: 17309744 24724992
xdk:server:[2016-03-16T23:07:56.794Z]: (1458169676794): memmrk: 17545168 24712832
xdk:client:[2016-03-16T23:07:56.796Z]: (1458169676796): memmrk: 17312128 24724992
xdk:server:[2016-03-16T23:08:01.795Z]: (1458169681795): memmrk: 17551072 24712832
xdk:client:[2016-03-16T23:08:01.796Z]: (1458169681797): memmrk: 17314512 24724992
xdk:server:[2016-03-16T23:08:06.795Z]: (1458169686796): memmrk: 17557896 24712832
xdk:client:[2016-03-16T23:08:06.797Z]: (1458169686797): memmrk: 17330384 24724992
xdk:server:[2016-03-16T23:08:11.795Z]: (1458169691795): memmrk: 16589872 24712832
xdk:client:[2016-03-16T23:08:11.797Z]: (1458169691797): memmrk: 17332800 24724992
xdk:server:[2016-03-16T23:08:16.795Z]: (1458169696795): memmrk: 16596680 24712832
xdk:client:[2016-03-16T23:08:16.798Z]: (1458169696798): memmrk: 17335184 24724992
xdk:server:[2016-03-16T23:08:21.796Z]: (1458169701796): memmrk: 16603488 24712832
xdk:client:[2016-03-16T23:08:21.798Z]: (1458169701798): memmrk: 17337584 24724992
xdk:server:[2016-03-16T23:08:26.796Z]: (1458169706796): memmrk: 16610296 24712832
xdk:client:[2016-03-16T23:08:26.798Z]: (1458169706798): memmrk: 17339968 24724992
xdk:server:[2016-03-16T23:08:31.796Z]: (1458169711796): memmrk: 16617104 24712832
xdk:client:[2016-03-16T23:08:31.799Z]: (1458169711799): memmrk: 17342352 24724992
xdk:server:[2016-03-16T23:08:36.797Z]: (1458169716797): memmrk: 16623912 24712832
xdk:client:[2016-03-16T23:08:36.799Z]: (1458169716799): memmrk: 17344752 24724992
xdk:server:[2016-03-16T23:08:41.797Z]: (1458169721797): memmrk: 16630720 24712832
xdk:client:[2016-03-16T23:08:41.799Z]: (1458169721800): memmrk: 17347136 24724992
xdk:server:[2016-03-16T23:08:46.797Z]: (1458169726797): memmrk: 16637528 24712832
xdk:client:[2016-03-16T23:08:46.800Z]: (1458169726800): memmrk: 17349520 24724992
xdk:server:[2016-03-16T23:08:51.798Z]: (1458169731798): memmrk: 16644336 24712832
xdk:client:[2016-03-16T23:08:51.800Z]: (1458169731800): memmrk: 17351920 24724992
xdk:server:[2016-03-16T23:08:56.798Z]: (1458169736798): memmrk: 16651144 24712832
xdk:client:[2016-03-16T23:08:56.801Z]: (1458169736801): memmrk: 17354304 24724992
xdk:server:[2016-03-16T23:09:01.798Z]: (1458169741798): memmrk: 16657952 24712832
xdk:client:[2016-03-16T23:09:01.801Z]: (1458169741801): memmrk: 17356704 24724992
xdk:server:[2016-03-16T23:09:06.799Z]: (1458169746799): memmrk: 16664776 24712832
xdk:client:[2016-03-16T23:09:06.802Z]: (1458169746802): memmrk: 17359104 24724992
xdk:server:[2016-03-16T23:09:11.799Z]: (1458169751799): memmrk: 16671600 24712832
xdk:client:[2016-03-16T23:09:11.802Z]: (1458169751802): memmrk: 17361520 24724992
xdk:server:[2016-03-16T23:09:16.799Z]: (1458169756799): memmrk: 16678408 24712832
xdk:client:[2016-03-16T23:09:16.802Z]: (1458169756802): memmrk: 17363904 24724992
xdk:server:[2016-03-16T23:09:21.799Z]: (1458169761799): memmrk: 16685216 24712832
xdk:client:[2016-03-16T23:09:21.802Z]: (1458169761802): memmrk: 17366288 24724992
xdk:server:[2016-03-16T23:09:26.800Z]: (1458169766800): memmrk: 16692024 24712832
xdk:client:[2016-03-16T23:09:26.803Z]: (1458169766803): memmrk: 17368672 24724992
xdk:server:[2016-03-16T23:09:31.800Z]: (1458169771800): memmrk: 16698832 24712832
xdk:client:[2016-03-16T23:09:31.803Z]: (1458169771803): memmrk: 17371072 24724992
xdk:server:[2016-03-16T23:09:36.800Z]: (1458169776800): memmrk: 16705640 24712832
xdk:client:[2016-03-16T23:09:36.804Z]: (1458169776804): memmrk: 17373456 24724992
xdk:server:[2016-03-16T23:09:41.801Z]: (1458169781801): memmrk: 16712448 24712832
xdk:client:[2016-03-16T23:09:41.804Z]: (1458169781804): memmrk: 17375856 24724992
xdk:server:[2016-03-16T23:09:46.801Z]: (1458169786801): memmrk: 16719256 24712832
xdk:client:[2016-03-16T23:09:46.804Z]: (1458169786804): memmrk: 17378240 24724992
xdk:server:[2016-03-16T23:09:51.801Z]: (1458169791801): memmrk: 16726064 24712832
xdk:client:[2016-03-16T23:09:51.805Z]: (1458169791805): memmrk: 17380624 24724992
xdk:server:[2016-03-16T23:09:56.802Z]: (1458169796802): memmrk: 16732872 24712832
xdk:client:[2016-03-16T23:09:56.806Z]: (1458169796806): memmrk: 17383008 24724992
xdk:server:[2016-03-16T23:10:01.802Z]: (1458169801802): memmrk: 16739680 24712832
xdk:client:[2016-03-16T23:10:01.807Z]: (1458169801807): memmrk: 17385408 24724992
xdk:server:[2016-03-16T23:10:06.803Z]: (1458169806803): memmrk: 16746488 24712832
xdk:client:[2016-03-16T23:10:06.807Z]: (1458169806807): memmrk: 17387808 24724992
xdk:server:[2016-03-16T23:10:11.803Z]: (1458169811803): memmrk: 16753296 24712832
xdk:client:[2016-03-16T23:10:11.807Z]: (1458169811807): memmrk: 17390192 24724992
xdk:server:[2016-03-16T23:10:16.803Z]: (1458169816803): memmrk: 16760088 24712832
xdk:client:[2016-03-16T23:10:16.808Z]: (1458169816808): memmrk: 17392560 24724992
xdk:server:[2016-03-16T23:10:21.803Z]: (1458169821803): memmrk: 16766880 24712832
xdk:client:[2016-03-16T23:10:21.808Z]: (1458169821808): memmrk: 17394944 24724992
xdk:server:[2016-03-16T23:10:26.803Z]: (1458169826803): memmrk: 16773672 24712832
xdk:client:[2016-03-16T23:10:26.808Z]: (1458169826808): memmrk: 17397312 24724992
xdk:server:[2016-03-16T23:10:31.804Z]: (1458169831804): memmrk: 16780464 24712832
xdk:client:[2016-03-16T23:10:31.809Z]: (1458169831809): memmrk: 17399680 24724992
xdk:server:[2016-03-16T23:10:36.804Z]: (1458169836804): memmrk: 16787256 24712832
xdk:client:[2016-03-16T23:10:36.809Z]: (1458169836809): memmrk: 17402048 24724992
xdk:server:[2016-03-16T23:10:41.805Z]: (1458169841805): memmrk: 16794048 24712832
xdk:client:[2016-03-16T23:10:41.809Z]: (1458169841809): memmrk: 17404416 24724992
xdk:server:[2016-03-16T23:10:46.804Z]: (1458169846805): memmrk: 16800840 24712832
xdk:client:[2016-03-16T23:10:46.810Z]: (1458169846810): memmrk: 17406784 24724992
xdk:server:[2016-03-16T23:10:51.805Z]: (1458169851805): memmrk: 16807632 24712832
xdk:client:[2016-03-16T23:10:51.810Z]: (1458169851810): memmrk: 17409168 24724992
xdk:server:[2016-03-16T23:10:56.805Z]: (1458169856805): memmrk: 16814424 24712832
xdk:client:[2016-03-16T23:10:56.810Z]: (1458169856810): memmrk: 17411536 24724992
xdk:server:[2016-03-16T23:11:01.806Z]: (1458169861806): memmrk: 16821216 24712832
xdk:client:[2016-03-16T23:11:01.810Z]: (1458169861810): memmrk: 17413904 24724992
xdk:server:[2016-03-16T23:11:06.806Z]: (1458169866806): memmrk: 16828024 24712832
xdk:client:[2016-03-16T23:11:06.810Z]: (1458169866810): memmrk: 17416288 24724992
xdk:server:[2016-03-16T23:11:11.806Z]: (1458169871806): memmrk: 16834832 24712832
xdk:client:[2016-03-16T23:11:11.811Z]: (1458169871811): memmrk: 17418672 24724992
xdk:server:[2016-03-16T23:11:16.806Z]: (1458169876806): memmrk: 16841624 24712832
xdk:client:[2016-03-16T23:11:16.811Z]: (1458169876811): memmrk: 17421056 24724992
xdk:server:[2016-03-16T23:11:21.806Z]: (1458169881807): memmrk: 16848416 24712832
xdk:client:[2016-03-16T23:11:21.811Z]: (1458169881811): memmrk: 17423424 24724992
xdk:server:[2016-03-16T23:11:26.807Z]: (1458169886807): memmrk: 16855208 24712832
xdk:client:[2016-03-16T23:11:26.812Z]: (1458169886812): memmrk: 17425792 24724992
xdk:server:[2016-03-16T23:11:31.807Z]: (1458169891807): memmrk: 16862000 24712832
xdk:client:[2016-03-16T23:11:31.812Z]: (1458169891812): memmrk: 17428160 24724992
xdk:server:[2016-03-16T23:11:36.807Z]: (1458169896807): memmrk: 16868792 24712832
xdk:client:[2016-03-16T23:11:36.812Z]: (1458169896812): memmrk: 17430528 24724992
xdk:server:[2016-03-16T23:11:41.808Z]: (1458169901808): memmrk: 16875584 24712832
xdk:client:[2016-03-16T23:11:41.813Z]: (1458169901813): memmrk: 17432896 24724992
xdk:server:[2016-03-16T23:11:46.808Z]: (1458169906808): memmrk: 16882392 24712832
xdk:client:[2016-03-16T23:11:46.813Z]: (1458169906813): memmrk: 17435280 24724992
xdk:server:[2016-03-16T23:11:51.809Z]: (1458169911809): memmrk: 16889184 24712832
xdk:client:[2016-03-16T23:11:51.814Z]: (1458169911814): memmrk: 17437648 24724992
xdk:server:[2016-03-16T23:11:56.809Z]: (1458169916809): memmrk: 16895976 24712832
xdk:client:[2016-03-16T23:11:56.814Z]: (1458169916814): memmrk: 17440032 24724992
xdk:server:[2016-03-16T23:12:01.809Z]: (1458169921809): memmrk: 16902768 24712832
xdk:client:[2016-03-16T23:12:01.814Z]: (1458169921814): memmrk: 17442400 24724992
xdk:server:[2016-03-16T23:12:06.809Z]: (1458169926809): memmrk: 16909576 24712832
xdk:client:[2016-03-16T23:12:06.814Z]: (1458169926814): memmrk: 17444800 24724992
xdk:server:[2016-03-16T23:12:11.809Z]: (1458169931809): memmrk: 16916384 24712832
xdk:client:[2016-03-16T23:12:11.814Z]: (1458169931815): memmrk: 17447216 24724992
xdk:server:[2016-03-16T23:12:16.810Z]: (1458169936810): memmrk: 16923176 24712832
xdk:client:[2016-03-16T23:12:16.815Z]: (1458169936815): memmrk: 17449584 24724992
xdk:server:[2016-03-16T23:12:21.811Z]: (1458169941811): memmrk: 16929968 24712832
xdk:client:[2016-03-16T23:12:21.816Z]: (1458169941816): memmrk: 17451952 24724992
xdk:server:[2016-03-16T23:12:26.811Z]: (1458169946811): memmrk: 16936760 24712832
xdk:client:[2016-03-16T23:12:26.817Z]: (1458169946817): memmrk: 17462540 24724992
xdk:server:[2016-03-16T23:12:31.811Z]: (1458169951811): memmrk: 16943552 24712832
xdk:client:[2016-03-16T23:12:31.817Z]: (1458169951818): memmrk: 17464924 24724992
xdk:server:[2016-03-16T23:12:36.811Z]: (1458169956811): memmrk: 16950344 24712832
xdk:client:[2016-03-16T23:12:36.819Z]: (1458169956820): memmrk: 17473892 24724992
xdk:server:[2016-03-16T23:12:41.812Z]: (1458169961812): memmrk: 16957136 24712832
xdk:client:[2016-03-16T23:12:41.820Z]: (1458169961820): memmrk: 17519128 24724992
xdk:server:[2016-03-16T23:12:46.812Z]: (1458169966812): memmrk: 16963960 24712832
xdk:client:[2016-03-16T23:12:46.820Z]: (1458169966820): memmrk: 17521432 24724992
xdk:server:[2016-03-16T23:12:51.813Z]: (1458169971813): memmrk: 16970752 24712832
xdk:client:[2016-03-16T23:12:51.820Z]: (1458169971820): memmrk: 17528200 24724992
xdk:server:[2016-03-16T23:12:56.813Z]: (1458169976813): memmrk: 16977544 24712832
xdk:client:[2016-03-16T23:12:56.821Z]: (1458169976821): memmrk: 17530472 24724992
xdk:server:[2016-03-16T23:13:01.813Z]: (1458169981813): memmrk: 16984336 24712832
xdk:client:[2016-03-16T23:13:01.821Z]: (1458169981821): memmrk: 17532760 24724992
xdk:server:[2016-03-16T23:13:06.813Z]: (1458169986813): memmrk: 16991144 24712832
xdk:client:[2016-03-16T23:13:06.822Z]: (1458169986822): memmrk: 17535048 24724992
xdk:server:[2016-03-16T23:13:11.814Z]: (1458169991814): memmrk: 16997952 24712832
xdk:client:[2016-03-16T23:13:11.822Z]: (1458169991822): memmrk: 17537352 24724992
xdk:server:[2016-03-16T23:13:16.814Z]: (1458169996814): memmrk: 17004744 24712832
xdk:client:[2016-03-16T23:13:16.823Z]: (1458169996823): memmrk: 17539624 24724992
xdk:server:[2016-03-16T23:13:21.815Z]: (1458170001815): memmrk: 17011536 24712832
xdk:client:[2016-03-16T23:13:21.823Z]: (1458170001823): memmrk: 17541912 24724992
xdk:server:[2016-03-16T23:13:26.815Z]: (1458170006815): memmrk: 17018328 24712832
xdk:client:[2016-03-16T23:13:26.824Z]: (1458170006824): memmrk: 17544184 24724992
xdk:server:[2016-03-16T23:13:31.815Z]: (1458170011815): memmrk: 17025120 24712832
xdk:client:[2016-03-16T23:13:31.824Z]: (1458170011825): memmrk: 17546472 24724992
xdk:server:[2016-03-16T23:13:36.815Z]: (1458170016816): memmrk: 17031912 24712832
xdk:client:[2016-03-16T23:13:36.825Z]: (1458170016825): memmrk: 17548744 24724992
xdk:server:[2016-03-16T23:13:41.816Z]: (1458170021816): memmrk: 17038704 24712832
xdk:client:[2016-03-16T23:13:41.826Z]: (1458170021826): memmrk: 17553024 24724992
xdk:server:[2016-03-16T23:13:46.816Z]: (1458170026816): memmrk: 17045496 24712832
xdk:client:[2016-03-16T23:13:46.827Z]: (1458170026827): memmrk: 17555296 24724992
xdk:server:[2016-03-16T23:13:51.816Z]: (1458170031816): memmrk: 17052288 24712832
xdk:client:[2016-03-16T23:13:51.827Z]: (1458170031827): memmrk: 17557584 24724992
xdk:server:[2016-03-16T23:13:56.817Z]: (1458170036817): memmrk: 17059080 24712832
xdk:client:[2016-03-16T23:13:56.827Z]: (1458170036827): memmrk: 17559856 24724992
xdk:server:[2016-03-16T23:14:01.817Z]: (1458170041817): memmrk: 17065872 24712832
xdk:client:[2016-03-16T23:14:01.828Z]: (1458170041828): memmrk: 17562128 24724992
xdk:server:[2016-03-16T23:14:06.819Z]: (1458170046819): memmrk: 17088476 24712832
xdk:client:[2016-03-16T23:14:06.828Z]: (1458170046828): memmrk: 17564448 24724992
xdk:server:[2016-03-16T23:14:11.818Z]: (1458170051818): memmrk: 17095196 24712832
xdk:client:[2016-03-16T23:14:11.828Z]: (1458170051829): memmrk: 17566736 24724992
xdk:server:[2016-03-16T23:14:16.818Z]: (1458170056818): memmrk: 17101708 24712832
xdk:client:[2016-03-16T23:14:16.829Z]: (1458170056829): memmrk: 17569008 24724992
xdk:server:[2016-03-16T23:14:21.818Z]: (1458170061818): memmrk: 17108220 24712832
xdk:client:[2016-03-16T23:14:21.830Z]: (1458170061830): memmrk: 17571296 24724992
xdk:server:[2016-03-16T23:14:26.818Z]: (1458170066818): memmrk: 17114732 24712832
xdk:client:[2016-03-16T23:14:26.830Z]: (1458170066830): memmrk: 17573584 24724992
xdk:server:[2016-03-16T23:14:31.819Z]: (1458170071819): memmrk: 17121244 24712832
xdk:client:[2016-03-16T23:14:31.834Z]: (1458170071834): memmrk: 17575856 24724992
xdk:server:[2016-03-16T23:14:36.819Z]: (1458170076819): memmrk: 17127756 24712832
xdk:client:[2016-03-16T23:14:36.835Z]: (1458170076835): memmrk: 17578128 24724992
xdk:server:[2016-03-16T23:14:41.819Z]: (1458170081819): memmrk: 17134268 24712832
xdk:client:[2016-03-16T23:14:41.836Z]: (1458170081836): memmrk: 17580416 24724992
xdk:server:[2016-03-16T23:14:46.820Z]: (1458170086820): memmrk: 17140780 24712832
xdk:client:[2016-03-16T23:14:46.836Z]: (1458170086836): memmrk: 17582704 24724992
xdk:server:[2016-03-16T23:14:51.820Z]: (1458170091820): memmrk: 17147292 24712832
xdk:client:[2016-03-16T23:14:51.836Z]: (1458170091836): memmrk: 17584976 24724992
xdk:server:[2016-03-16T23:14:56.820Z]: (1458170096820): memmrk: 17153804 24712832
xdk:client:[2016-03-16T23:14:56.836Z]: (1458170096836): memmrk: 17587248 24724992
xdk:server:[2016-03-16T23:15:01.821Z]: (1458170101821): memmrk: 17160316 24712832
xdk:client:[2016-03-16T23:15:01.837Z]: (1458170101837): memmrk: 17589520 24724992
xdk:server:[2016-03-16T23:15:06.821Z]: (1458170106821): memmrk: 17166844 24712832
xdk:client:[2016-03-16T23:15:06.837Z]: (1458170106837): memmrk: 17591824 24724992
xdk:server:[2016-03-16T23:15:11.821Z]: (1458170111821): memmrk: 17173372 24712832
xdk:client:[2016-03-16T23:15:11.838Z]: (1458170111838): memmrk: 17594112 24724992
xdk:server:[2016-03-16T23:15:16.821Z]: (1458170116822): memmrk: 17179884 24712832
xdk:client:[2016-03-16T23:15:16.838Z]: (1458170116838): memmrk: 17596400 24724992
xdk:server:[2016-03-16T23:15:21.822Z]: (1458170121822): memmrk: 17186396 24712832
xdk:client:[2016-03-16T23:15:21.838Z]: (1458170121838): memmrk: 17598672 24724992
xdk:server:[2016-03-16T23:15:26.822Z]: (1458170126822): memmrk: 17192908 24712832
xdk:client:[2016-03-16T23:15:26.838Z]: (1458170126838): memmrk: 17600944 24724992
xdk:server:[2016-03-16T23:15:31.823Z]: (1458170131823): memmrk: 17199420 24712832
xdk:client:[2016-03-16T23:15:31.839Z]: (1458170131839): memmrk: 17603216 24724992
xdk:server:[2016-03-16T23:15:36.823Z]: (1458170136823): memmrk: 17205932 24712832
xdk:client:[2016-03-16T23:15:36.839Z]: (1458170136839): memmrk: 17605504 24724992
xdk:server:[2016-03-16T23:15:41.823Z]: (1458170141824): memmrk: 17212444 24712832
xdk:client:[2016-03-16T23:15:41.847Z]: (1458170141847): memmrk: 17607776 24724992
xdk:server:[2016-03-16T23:15:46.824Z]: (1458170146824): memmrk: 17218956 24712832
xdk:client:[2016-03-16T23:15:46.848Z]: (1458170146848): memmrk: 17610064 24724992
xdk:server:[2016-03-16T23:15:51.824Z]: (1458170151824): memmrk: 17225468 24712832
xdk:client:[2016-03-16T23:15:51.848Z]: (1458170151848): memmrk: 17612352 24724992
xdk:server:[2016-03-16T23:15:56.825Z]: (1458170156825): memmrk: 17231980 24712832
xdk:client:[2016-03-16T23:15:56.848Z]: (1458170156848): memmrk: 17614624 24724992
xdk:server:[2016-03-16T23:16:01.825Z]: (1458170161825): memmrk: 17238492 24712832
xdk:client:[2016-03-16T23:16:01.849Z]: (1458170161849): memmrk: 17616896 24724992
xdk:server:[2016-03-16T23:16:06.826Z]: (1458170166826): memmrk: 17245020 24712832
xdk:client:[2016-03-16T23:16:06.849Z]: (1458170166849): memmrk: 17619184 24724992
xdk:server:[2016-03-16T23:16:11.826Z]: (1458170171826): memmrk: 17251548 24712832
xdk:client:[2016-03-16T23:16:11.849Z]: (1458170171849): memmrk: 17621472 24724992
xdk:server:[2016-03-16T23:16:16.826Z]: (1458170176827): memmrk: 17258060 24712832
xdk:client:[2016-03-16T23:16:16.850Z]: (1458170176850): memmrk: 17623744 24724992
xdk:server:[2016-03-16T23:16:21.827Z]: (1458170181827): memmrk: 17264572 24712832
xdk:client:[2016-03-16T23:16:21.851Z]: (1458170181851): memmrk: 17626032 24724992
xdk:server:[2016-03-16T23:16:26.827Z]: (1458170186827): memmrk: 17271084 24712832
xdk:client:[2016-03-16T23:16:26.851Z]: (1458170186851): memmrk: 17628320 24724992
xdk:server:[2016-03-16T23:16:31.828Z]: (1458170191828): memmrk: 17277596 24712832
xdk:client:[2016-03-16T23:16:31.851Z]: (1458170191851): memmrk: 17630592 24724992
xdk:server:[2016-03-16T23:16:36.828Z]: (1458170196828): memmrk: 17284108 24712832
xdk:client:[2016-03-16T23:16:36.851Z]: (1458170196851): memmrk: 17632864 24724992
xdk:server:[2016-03-16T23:16:41.828Z]: (1458170201828): memmrk: 17290620 24712832
xdk:client:[2016-03-16T23:16:41.852Z]: (1458170201852): memmrk: 17635136 24724992
xdk:server:[2016-03-16T23:16:46.828Z]: (1458170206828): memmrk: 17297132 24712832
xdk:client:[2016-03-16T23:16:46.852Z]: (1458170206852): memmrk: 17637424 24724992
xdk:server:[2016-03-16T23:16:51.829Z]: (1458170211829): memmrk: 17303644 24712832
xdk:client:[2016-03-16T23:16:51.853Z]: (1458170211853): memmrk: 17639696 24724992
xdk:server:[2016-03-16T23:16:56.829Z]: (1458170216829): memmrk: 17310156 24712832
xdk:client:[2016-03-16T23:16:56.853Z]: (1458170216853): memmrk: 17641984 24724992
xdk:server:[2016-03-16T23:17:01.829Z]: (1458170221829): memmrk: 17316668 24712832
xdk:client:[2016-03-16T23:17:01.853Z]: (1458170221854): memmrk: 17644256 24724992
xdk:server:[2016-03-16T23:17:06.830Z]: (1458170226830): memmrk: 17323196 24712832
xdk:client:[2016-03-16T23:17:06.854Z]: (1458170226855): memmrk: 17646544 24724992
xdk:server:[2016-03-16T23:17:11.830Z]: (1458170231830): memmrk: 17329724 24712832
xdk:client:[2016-03-16T23:17:11.855Z]: (1458170231855): memmrk: 17648848 24724992
xdk:server:[2016-03-16T23:17:16.830Z]: (1458170236830): memmrk: 17336236 24712832
xdk:client:[2016-03-16T23:17:16.856Z]: (1458170236856): memmrk: 17651136 24724992
xdk:server:[2016-03-16T23:17:21.830Z]: (1458170241830): memmrk: 17342748 24712832
xdk:client:[2016-03-16T23:17:21.856Z]: (1458170241857): memmrk: 17653424 24724992
xdk:server:[2016-03-16T23:17:26.831Z]: (1458170246831): memmrk: 17349260 24712832
xdk:client:[2016-03-16T23:17:26.857Z]: (1458170246857): memmrk: 17655696 24724992
xdk:server:[2016-03-16T23:17:31.831Z]: (1458170251831): memmrk: 17355772 24712832
xdk:client:[2016-03-16T23:17:31.859Z]: (1458170251859): memmrk: 17666508 24724992
xdk:server:[2016-03-16T23:17:36.832Z]: (1458170256832): memmrk: 17362284 24712832
xdk:client:[2016-03-16T23:17:36.858Z]: (1458170256858): memmrk: 17668796 24724992
xdk:server:[2016-03-16T23:17:41.832Z]: (1458170261833): memmrk: 17368796 24712832
xdk:client:[2016-03-16T23:17:41.858Z]: (1458170261858): memmrk: 17671084 24724992
xdk:server:[2016-03-16T23:17:46.832Z]: (1458170266832): memmrk: 17375308 24712832
xdk:client:[2016-03-16T23:17:46.859Z]: (1458170266859): memmrk: 17673356 24724992
xdk:server:[2016-03-16T23:17:51.833Z]: (1458170271833): memmrk: 17381820 24712832
xdk:client:[2016-03-16T23:17:51.859Z]: (1458170271859): memmrk: 17675628 24724992
xdk:server:[2016-03-16T23:17:56.833Z]: (1458170276833): memmrk: 17388332 24712832
xdk:client:[2016-03-16T23:17:56.859Z]: (1458170276859): memmrk: 17677900 24724992
xdk:server:[2016-03-16T23:18:01.833Z]: (1458170281833): memmrk: 17394844 24712832
xdk:client:[2016-03-16T23:18:01.859Z]: (1458170281859): memmrk: 17680172 24724992
xdk:server:[2016-03-16T23:18:06.834Z]: (1458170286834): memmrk: 17401372 24712832
xdk:client:[2016-03-16T23:18:06.859Z]: (1458170286859): memmrk: 17682440 24724992
xdk:server:[2016-03-16T23:18:11.834Z]: (1458170291834): memmrk: 17407900 24712832
xdk:client:[2016-03-16T23:18:11.859Z]: (1458170291859): memmrk: 17684728 24724992
xdk:server:[2016-03-16T23:18:16.834Z]: (1458170296834): memmrk: 17414412 24712832
xdk:client:[2016-03-16T23:18:16.861Z]: (1458170296861): memmrk: 17687000 24724992
xdk:server:[2016-03-16T23:18:21.835Z]: (1458170301835): memmrk: 17420924 24712832
xdk:client:[2016-03-16T23:18:21.861Z]: (1458170301861): memmrk: 17689288 24724992
xdk:server:[2016-03-16T23:18:26.835Z]: (1458170306835): memmrk: 17427436 24712832
xdk:client:[2016-03-16T23:18:26.862Z]: (1458170306862): memmrk: 17691560 24724992
xdk:server:[2016-03-16T23:18:31.835Z]: (1458170311835): memmrk: 17433948 24712832
xdk:client:[2016-03-16T23:18:31.862Z]: (1458170311862): memmrk: 17693848 24724992
xdk:server:[2016-03-16T23:18:36.835Z]: (1458170316835): memmrk: 17440460 24712832
xdk:client:[2016-03-16T23:18:36.862Z]: (1458170316862): memmrk: 17696120 24724992
xdk:server:[2016-03-16T23:18:41.836Z]: (1458170321836): memmrk: 17446972 24712832
xdk:client:[2016-03-16T23:18:41.863Z]: (1458170321864): memmrk: 17698392 24724992
xdk:server:[2016-03-16T23:18:46.836Z]: (1458170326836): memmrk: 17453484 24712832
xdk:client:[2016-03-16T23:18:46.864Z]: (1458170326864): memmrk: 17700664 24724992
xdk:server:[2016-03-16T23:18:51.837Z]: (1458170331837): memmrk: 17459996 24712832
xdk:client:[2016-03-16T23:18:51.865Z]: (1458170331865): memmrk: 17702952 24724992
xdk:server:[2016-03-16T23:18:56.837Z]: (1458170336837): memmrk: 17466508 24712832
xdk:client:[2016-03-16T23:18:56.866Z]: (1458170336866): memmrk: 17705240 24724992
xdk:server:[2016-03-16T23:19:01.837Z]: (1458170341837): memmrk: 17473020 24712832
xdk:client:[2016-03-16T23:19:01.867Z]: (1458170341867): memmrk: 17707528 24724992
xdk:server:[2016-03-16T23:19:06.838Z]: (1458170346838): memmrk: 17479548 24712832
xdk:client:[2016-03-16T23:19:06.867Z]: (1458170346867): memmrk: 17709848 24724992
xdk:server:[2016-03-16T23:19:11.838Z]: (1458170351838): memmrk: 17486076 24712832
xdk:client:[2016-03-16T23:19:11.867Z]: (1458170351867): memmrk: 17712136 24724992
xdk:server:[2016-03-16T23:19:16.838Z]: (1458170356838): memmrk: 17492588 24712832
xdk:client:[2016-03-16T23:19:16.868Z]: (1458170356868): memmrk: 17714408 24724992
xdk:server:[2016-03-16T23:19:21.839Z]: (1458170361839): memmrk: 17499100 24712832
xdk:client:[2016-03-16T23:19:21.868Z]: (1458170361868): memmrk: 17716696 24724992
xdk:server:[2016-03-16T23:19:26.839Z]: (1458170366839): memmrk: 17505612 24712832
xdk:client:[2016-03-16T23:19:26.869Z]: (1458170366869): memmrk: 17718968 24724992
xdk:server:[2016-03-16T23:19:31.840Z]: (1458170371840): memmrk: 17512124 24712832
xdk:client:[2016-03-16T23:19:31.869Z]: (1458170371869): memmrk: 17721256 24724992
xdk:server:[2016-03-16T23:19:36.840Z]: (1458170376840): memmrk: 17518636 24712832
xdk:client:[2016-03-16T23:19:36.870Z]: (1458170376870): memmrk: 17723528 24724992
xdk:server:[2016-03-16T23:19:41.840Z]: (1458170381840): memmrk: 17525148 24712832
xdk:client:[2016-03-16T23:19:41.870Z]: (1458170381870): memmrk: 17725816 24724992
xdk:server:[2016-03-16T23:19:46.840Z]: (1458170386840): memmrk: 17531660 24712832
xdk:client:[2016-03-16T23:19:46.871Z]: (1458170386871): memmrk: 17728088 24724992
xdk:server:[2016-03-16T23:19:51.840Z]: (1458170391840): memmrk: 17538172 24712832
xdk:client:[2016-03-16T23:19:51.871Z]: (1458170391871): memmrk: 17730376 24724992
xdk:server:[2016-03-16T23:19:56.841Z]: (1458170396841): memmrk: 17544684 24712832
xdk:client:[2016-03-16T23:19:56.871Z]: (1458170396871): memmrk: 17732680 24724992
xdk:server:[2016-03-16T23:20:01.842Z]: (1458170401842): memmrk: 17551196 24712832
xdk:client:[2016-03-16T23:20:01.872Z]: (1458170401872): memmrk: 17734952 24724992
xdk:server:[2016-03-16T23:20:06.842Z]: (1458170406842): memmrk: 17557724 24712832
xdk:client:[2016-03-16T23:20:06.873Z]: (1458170406873): memmrk: 17737256 24724992
xdk:server:[2016-03-16T23:20:11.842Z]: (1458170411842): memmrk: 17564252 24712832
xdk:client:[2016-03-16T23:20:11.873Z]: (1458170411873): memmrk: 17739560 24724992
xdk:server:[2016-03-16T23:20:16.842Z]: (1458170416842): memmrk: 17570764 24712832
xdk:client:[2016-03-16T23:20:16.873Z]: (1458170416873): memmrk: 17741832 24724992
xdk:server:[2016-03-16T23:20:21.843Z]: (1458170421843): memmrk: 17577276 24712832
xdk:client:[2016-03-16T23:20:21.873Z]: (1458170421874): memmrk: 17744104 24724992
xdk:server:[2016-03-16T23:20:26.843Z]: (1458170426843): memmrk: 17583788 24712832
xdk:client:[2016-03-16T23:20:26.874Z]: (1458170426874): memmrk: 17746376 24724992
xdk:server:[2016-03-16T23:20:31.844Z]: (1458170431844): memmrk: 16616592 24712832
xdk:client:[2016-03-16T23:20:31.875Z]: (1458170431875): memmrk: 17748664 24724992
xdk:server:[2016-03-16T23:20:36.844Z]: (1458170436844): memmrk: 16623104 24712832
xdk:client:[2016-03-16T23:20:36.875Z]: (1458170436875): memmrk: 17750952 24724992
xdk:server:[2016-03-16T23:20:41.844Z]: (1458170441844): memmrk: 16629616 24712832
xdk:client:[2016-03-16T23:20:41.876Z]: (1458170441876): memmrk: 17753224 24724992
xdk:server:[2016-03-16T23:20:46.844Z]: (1458170446844): memmrk: 16636128 24712832
xdk:client:[2016-03-16T23:20:46.876Z]: (1458170446876): memmrk: 17755512 24724992
xdk:server:[2016-03-16T23:20:51.845Z]: (1458170451845): memmrk: 16642640 24712832
xdk:client:[2016-03-16T23:20:51.876Z]: (1458170451876): memmrk: 17757784 24724992
xdk:server:[2016-03-16T23:20:56.845Z]: (1458170456845): memmrk: 16649152 24712832
xdk:client:[2016-03-16T23:20:56.876Z]: (1458170456876): memmrk: 17760056 24724992
xdk:server:[2016-03-16T23:21:01.845Z]: (1458170461845): memmrk: 16655664 24712832
xdk:client:[2016-03-16T23:21:01.877Z]: (1458170461877): memmrk: 17762328 24724992
xdk:server:[2016-03-16T23:21:06.846Z]: (1458170466846): memmrk: 16662192 24712832
xdk:client:[2016-03-16T23:21:06.877Z]: (1458170466877): memmrk: 17764632 24724992
xdk:server:[2016-03-16T23:21:11.846Z]: (1458170471846): memmrk: 16668720 24712832
xdk:client:[2016-03-16T23:21:11.878Z]: (1458170471878): memmrk: 17766920 24724992
xdk:server:[2016-03-16T23:21:16.847Z]: (1458170476847): memmrk: 16675232 24712832
xdk:client:[2016-03-16T23:21:16.878Z]: (1458170476878): memmrk: 17769192 24724992
xdk:server:[2016-03-16T23:21:21.847Z]: (1458170481847): memmrk: 16681744 24712832
xdk:client:[2016-03-16T23:21:21.879Z]: (1458170481879): memmrk: 17771464 24724992
xdk:server:[2016-03-16T23:21:26.847Z]: (1458170486847): memmrk: 16688256 24712832
xdk:client:[2016-03-16T23:21:26.879Z]: (1458170486879): memmrk: 17773752 24724992
xdk:server:[2016-03-16T23:21:31.847Z]: (1458170491847): memmrk: 16694768 24712832
xdk:client:[2016-03-16T23:21:31.879Z]: (1458170491879): memmrk: 17776024 24724992
xdk:server:[2016-03-16T23:21:36.847Z]: (1458170496847): memmrk: 16701280 24712832
xdk:client:[2016-03-16T23:21:36.880Z]: (1458170496880): memmrk: 17778296 24724992
xdk:server:[2016-03-16T23:21:41.848Z]: (1458170501848): memmrk: 16707792 24712832
xdk:client:[2016-03-16T23:21:41.880Z]: (1458170501880): memmrk: 17780584 24724992
xdk:server:[2016-03-16T23:21:46.848Z]: (1458170506848): memmrk: 16714304 24712832
xdk:client:[2016-03-16T23:21:46.880Z]: (1458170506880): memmrk: 17782856 24724992
xdk:server:[2016-03-16T23:21:51.848Z]: (1458170511848): memmrk: 16720816 24712832
xdk:client:[2016-03-16T23:21:51.881Z]: (1458170511881): memmrk: 17785128 24724992
xdk:server:[2016-03-16T23:21:56.849Z]: (1458170516849): memmrk: 16727328 24712832
xdk:client:[2016-03-16T23:21:56.881Z]: (1458170516881): memmrk: 17787416 24724992
xdk:server:[2016-03-16T23:22:01.849Z]: (1458170521849): memmrk: 16733840 24712832
xdk:client:[2016-03-16T23:22:01.885Z]: (1458170521885): memmrk: 17789688 24724992
xdk:server:[2016-03-16T23:22:06.850Z]: (1458170526850): memmrk: 16740368 24712832
xdk:client:[2016-03-16T23:22:06.885Z]: (1458170526885): memmrk: 17791992 24724992
xdk:server:[2016-03-16T23:22:11.850Z]: (1458170531850): memmrk: 16746896 24712832
xdk:client:[2016-03-16T23:22:11.886Z]: (1458170531886): memmrk: 17794280 24724992
xdk:server:[2016-03-16T23:22:16.850Z]: (1458170536850): memmrk: 16753408 24712832
xdk:client:[2016-03-16T23:22:16.886Z]: (1458170536886): memmrk: 17796568 24724992
xdk:server:[2016-03-16T23:22:21.850Z]: (1458170541850): memmrk: 16759920 24712832
xdk:client:[2016-03-16T23:22:21.887Z]: (1458170541887): memmrk: 17798840 24724992
xdk:server:[2016-03-16T23:22:26.851Z]: (1458170546851): memmrk: 16766432 24712832
xdk:client:[2016-03-16T23:22:26.887Z]: (1458170546887): memmrk: 17801112 24724992
xdk:client:[2016-03-16T23:22:32.007Z]: (1458170552007): memmrk: 17806440 24724992
Node Webkit Error log:
[10028:0316/190733:INFO:CONSOLE(17)] ""xdk:client:[2016-03-16T22:07:33.868Z]: (1458166053868): Failed to load theme: xdk" {"code":"MODULE_NOT_FOUND"}", source: C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10028:0316/192444:INFO:CONSOLE(17)] ""client:appcenter-options:[2016-03-16T22:24:44.805Z]: (1458167084805): could not get options"", source: C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10028:0316/192444:INFO:CONSOLE(17)] ""client:appcenter-options:[2016-03-16T22:24:44.809Z]: (1458167084809): Something went wrong. Could not create appCenterBaseUrl (%s) for appCenterOption key/value pair (%s/%s) in default.json" null "crosswalk" "apk"", source: C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10028:0316/192444:INFO:CONSOLE(17)] ""client:appcenter-options:[2016-03-16T22:24:44.812Z]: (1458167084812): Something went wrong. Could not create appCenterBaseUrl (%s) for appCenterOption key/value pair (%s/%s) in default.json" null "crosswalk" "apk"", source: C:\Users\Franco\AppData\Local\Intel\XDK\xdk\core-modules\private\logger.js (17)
[10028:0316/202230:INFO:dispatcher_host.cc(154)] [NW.JS]RenderProcessWasKilled
XDK exit code & signal: 3221225477, null
Crash minidump not found in XDK data folder. Falling back to TEMP...
Crash Minidump File: C:\Users\Franco\AppData\Local\Temp\d00a317d-3aa8-4325-a25f-0187ccfee900.dmp Wed Mar 16 2016 20:22:32 GMT-0300 (Hora oficial do Brasil)
Size in bytes: 554226
NW Crash Detected.
gaston-hillar
Valued Contributor I
Francogs,
I just had to install the latest version (2893), which is the same one you are using based on your logs on a Windows 10 64-bit with the latest updates and it works OK, any issues so far.
A long time ago, I had some issues with a specific antivirus software that didn't allow me two applications to launch: Visual Studio 2013 and Intel XDK IoT edition. The problem was a bit different than the one you have. However, I solved it changing the antivirus software by another one and the problems were solved.
Amrita_C_Intel
See the instructions on this Intel XDK forum post for doing a complete uninstall, in case you have a partial install that is getting in the way. Do everything up to the "finally" step. Those instructions were written for people that wanted to stay with a previous version of the XDK.
Do not install that older version that is posted in that thread, it will be obsolete very soon.
gaston-hillar
Francogs,
How much RAM do you have in the computer in which you are running Windows 10 and Intel XDK?
Which Windows 10 version are you using? 32-bit or 64-bit?
francogs
My Win10 is 64-bits and 8GB RAM
gaston-hillar
Francogs,
I have been running Intel XDK on three different Windows 10 64-bit computers since Windows 10 was launched. One of my computers has 8 GB RAM and I never had issues like the one you mention. In fact, one of them has the same CPU you have.
Have you installed previous versions of Intel XDK?
Do you have node.js installed in your computer?
I would uninstall any XDK and Node.js and reinstall Intel XDK.
gaston-hillar
Francogs,
