Software Archive
Read-only legacy content
Intel xdk not working on windows 10
Sobhan_A_
I was using intel xdk earlier on windows 7. it was working fine. then  I upgraded my OS to windows 10 and intel xdk stopped working. Please do help
Sobhan_A_
intel xdk not working on windows 10
John_H_Intel2
Can you please provide additional info other than not working.
Does it crash? Screenshot? Log?
Did you try reinstalling?
PaulF_IntelCorp
If you have the XDK installed when you upgrade to Windows 10 it sometimes stops working. Not sure why. The solution is to reinstall the XDK on your Windows 10 machine, that usually fixes it.
Sobhan_A_
logs
xdk:client:[2016-02-22T13:20:08.966Z]: (1456147208966): memlim: 767557632
xdk:client:[2016-02-22T13:20:08.997Z]: (1456147208997): Setting NW crash dump to: C:\Users\manini nini\AppData\Local\XDK
xdk:client:[2016-02-22T13:20:12.330Z]: (1456147212330): Intel XDK: 2893
xdk:client:[2016-02-22T13:20:12.330Z]: (1456147212330): Platform: win32-ia32 (6.1.7600)
xdk:client:[2016-02-22T13:20:12.330Z]: (1456147212330): System Info:  CPU: 2 X Intel(R) Core(TM)2 Duo CPU     T6570  @ 2.10GHz Physical Memory: 3146002432
xdk:client:[2016-02-22T13:20:12.330Z]: (1456147212330): NW: 0.11.7-rc9
xdk:client:[2016-02-22T13:20:12.758Z]: (1456147212758): Created new theme: base
xdk:client:[2016-02-22T13:20:12.759Z]: (1456147212759): Registered new theme: base
xdk:client:[2016-02-22T13:20:12.761Z]: (1456147212761): Current theme is now: base
xdk:client:[2016-02-22T13:20:12.761Z]: (1456147212761): Loading theme from: ../../public/themes/xdk.json
xdk:client:[2016-02-22T13:20:12.763Z]: (1456147212763): Failed to load theme: xdk { [Error: Cannot find module '../../public/themes/xdk.json'] code: 'MODULE_NOT_FOUND' }
xdk:client:[2016-02-22T13:20:14.208Z]: (1456147214208): Starting client process initialization
xdk:client:[2016-02-22T13:20:14.246Z]: (1456147214246): memmrk:    17991380    31255296
xdk:client:[2016-02-22T13:20:14.335Z]: (1456147214335): NW Cache is up-to-date.
xdk:client:[2016-02-22T13:20:19.255Z]: (1456147219255): memmrk:    18798796    32270976
xdk:server:[2016-02-22T13:20:16.265Z]: (1456147216267): memlim: 767557632
xdk:server:[2016-02-22T13:20:16.292Z]: (1456147216292): Setting NW crash dump to: C:\Users\manini nini\AppData\Local\XDK
xdk:server:[2016-02-22T13:20:18.262Z]: (1456147218262): Starting server process initialization
xdk:server:[2016-02-22T13:20:19.745Z]: (1456147219745): Http server started on the standard port 58889
xdk:server:[2016-02-22T13:20:19.783Z]: (1456147219783): NW Cache is up-to-date.
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:assert" starting import
xdk:client:[2016-02-22T13:20:24.276Z]: (1456147224276): memmrk:    19017496    32270976
xdk:client:[2016-02-22T13:20:29.277Z]: (1456147229277): memmrk:    19231576    32270976
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:assert" finished initialization
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:component-error" starting import
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:component-error" finished initialization
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:command-line-options" starting import
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:command-line-options" finished initialization
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:service-error" starting import
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:service-error" finished initialization
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:buffer" starting import
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:buffer" finished initialization
xdk:server:[2016-02-22T13:20:20.518Z]: (1456147220518): Component "core:signaler" starting import
xdk:server:[2016-02-22T13:20:20.565Z]: (1456147220565): Component "core:signaler" finished initialization
xdk:server:[2016-02-22T13:20:20.565Z]: (1456147220565): Component "core:signaler-group" starting import
xdk:server:[2016-02-22T13:20:20.580Z]: (1456147220580): Component "core:signaler-group" finished initialization
xdk:server:[2016-02-22T13:20:20.580Z]: (1456147220580): Component "core:logger" starting import
xdk:server:[2016-02-22T13:20:20.596Z]: (1456147220596): Component "core:logger" finished initialization
xdk:server:[2016-02-22T13:20:20.596Z]: (1456147220596): Component "core:http-request" starting import
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:http-request" finished initialization
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:database" starting import
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:database" finished initialization
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:version" starting import
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:version" finished initialization
xdk:server:[2016-02-22T13:20:20.612Z]: (1456147220612): Component "core:userfs-name-converter" starting import
xdk:server:[2016-02-22T13:20:20.627Z]: (1456147220627): Component "core:userfs-name-converter" finished initialization
xdk:server:[2016-02-22T13:20:20.627Z]: (1456147220627): Component "core:crash-handler" starting import
xdk:server:[2016-02-22T13:20:20.643Z]: (1456147220643): Component "core:crash-handler" finished initialization
xdk:server:[2016-02-22T13:20:20.643Z]: (1456147220643): Component "core:i18n-support" starting import
xdk:server:[2016-02-22T13:20:20.643Z]: (1456147220643): Component "core:i18n-support" finished initialization
xdk:server:[2016-02-22T13:20:20.643Z]: (1456147220643): Component "core:theme" starting import
xdk:server:[2016-02-22T13:20:20.852Z]: (1456147220852): Component "core:theme" finished initialization
xdk:server:[2016-02-22T13:20:20.854Z]: (1456147220854): Component "server:userfs" starting import
xdk:server:[2016-02-22T13:20:20.910Z]: (1456147220910): Component "server:userfs" calling init()
xdk:server:[2016-02-22T13:20:21.305Z]: (1456147221305): Component "server:userfs" finished initialization
xdk:server:[2016-02-22T13:20:21.305Z]: (1456147221305): Component "server:user-profile" starting import
xdk:server:[2016-02-22T13:20:21.336Z]: (1456147221336): Component "server:user-profile" calling init()
xdk:server:[2016-02-22T13:20:21.337Z]: (1456147221337): Component "server:user-profile" finished initialization
xdk:server:[2016-02-22T13:20:21.337Z]: (1456147221337): Component "server:ui-builder" starting import
xdk:server:[2016-02-22T13:20:22.359Z]: (1456147222359): Component "server:ui-builder" calling init()
xdk:server:[2016-02-22T13:20:22.362Z]: (1456147222362): Component "server:ui-builder" finished initialization
xdk:server:[2016-02-22T13:20:22.362Z]: (1456147222362): Component "server:emulator-notification" starting import
xdk:server:[2016-02-22T13:20:22.393Z]: (1456147222393): Component "server:emulator-notification" calling init()
xdk:server:[2016-02-22T13:20:22.394Z]: (1456147222394): Component "server:emulator-notification" finished initialization
xdk:server:[2016-02-22T13:20:22.395Z]: (1456147222395): Component "server:emulator-webserver" starting import
xdk:server:[2016-02-22T13:20:22.408Z]: (1456147222408): Component "server:emulator-webserver" calling init()
xdk:server:[2016-02-22T13:20:22.410Z]: (1456147222411): Component "server:emulator-webserver" finished initialization
xdk:server:[2016-02-22T13:20:22.411Z]: (1456147222411): Component "server:new-project-creator" starting import
xdk:server:[2016-02-22T13:20:22.443Z]: (1456147222443): Component "server:new-project-creator" calling init()
xdk:server:[2016-02-22T13:20:22.443Z]: (1456147222443): Component "server:new-project-creator" finished initialization
xdk:server:[2016-02-22T13:20:22.443Z]: (1456147222443): Component "server:zip-util" starting import
xdk:server:[2016-02-22T13:20:22.466Z]: (1456147222466): Component "server:zip-util" calling init()
xdk:server:[2016-02-22T13:20:22.467Z]: (1456147222467): Component "server:zip-util" finished initialization
xdk:server:[2016-02-22T13:20:22.467Z]: (1456147222467): Component "server:uuid-server" starting import
xdk:server:[2016-02-22T13:20:22.488Z]: (1456147222488): Component "server:uuid-server" calling init()
xdk:server:[2016-02-22T13:20:22.489Z]: (1456147222489): Component "server:uuid-server" finished initialization
xdk:server:[2016-02-22T13:20:22.489Z]: (1456147222489): Component "server:app-starter" starting import
xdk:server:[2016-02-22T13:20:22.555Z]: (1456147222555): Component "server:app-starter" calling init()
xdk:server:[2016-02-22T13:20:22.560Z]: (1456147222560): Component "server:app-starter" finished initialization
xdk:server:[2016-02-22T13:20:22.560Z]: (1456147222560): Component "server:force-download" starting import
xdk:server:[2016-02-22T13:20:22.579Z]: (1456147222579): Component "server:force-download" calling init()
xdk:server:[2016-02-22T13:20:22.579Z]: (1456147222579): Component "server:force-download" finished initialization
xdk:server:[2016-02-22T13:20:22.579Z]: (1456147222579): Component "server:updater" starting import
xdk:server:[2016-02-22T13:20:22.623Z]: (1456147222623): Component "server:updater" calling init()
server:updater:[2016-02-22T13:20:22.624Z]: (1456147222624): config.base-auto
server:updater:[2016-02-22T13:20:22.624Z]: (1456147222624): url=auto
xdk:server:[2016-02-22T13:20:22.636Z]: (1456147222636): Component "server:updater" finished initialization
xdk:server:[2016-02-22T13:20:22.636Z]: (1456147222636): Component "server:editor-node" starting import
xdk:server:[2016-02-22T13:20:23.047Z]: (1456147223047): Component "server:editor-node" calling init()
xdk:server:[2016-02-22T13:20:23.049Z]: (1456147223049): Component "server:editor-node" waiting for delayed initialization
xdk:server:[2016-02-22T13:20:23.049Z]: (1456147223049): Component "server:cordova-lib" starting import
xdk:server:[2016-02-22T13:20:28.014Z]: (1456147228014): Component "server:cordova-lib" calling init()
xdk:server:[2016-02-22T13:20:28.697Z]: (1456147228697): Component "server:cordova-lib" finished initialization
xdk:server:[2016-02-22T13:20:28.697Z]: (1456147228697): Component "server:api-explorer" starting import
xdk:server:[2016-02-22T13:20:28.768Z]: (1456147228768): Component "server:api-explorer" calling init()
xdk:server:[2016-02-22T13:20:29.453Z]: (1456147229453): Component "server:api-explorer" finished initialization
xdk:server:[2016-02-22T13:20:29.453Z]: (1456147229453): Component "server:plugin-listener" starting import
xdk:server:[2016-02-22T13:20:29.490Z]: (1456147229491): Component "server:plugin-listener" calling init()
xdk:server:[2016-02-22T13:20:29.491Z]: (1456147229491): Component "server:plugin-listener" finished initialization
xdk:server:[2016-02-22T13:20:29.491Z]: (1456147229491): Component "server:git-runner" starting import
xdk:server:[2016-02-22T13:20:29.513Z]: (1456147229513): Component "server:git-runner" calling init()
xdk:server:[2016-02-22T13:20:29.513Z]: (1456147229513): Component "server:git-runner" finished initialization
server:editor-node:[2016-02-22T13:20:29.515Z]: (1456147229515): Starting Brackets node process "C:\Users\manini nini\AppData\Local\Intel\XDK\bin\node.exe" "C:\Users\manini nini\AppData\Local\Intel\XDK\bin\node-core"
xdk:server:[2016-02-22T13:20:29.593Z]: (1456147229593): memmrk:    26855000    43419136
server:editor-node:[2016-02-22T13:20:30.610Z]: (1456147230610): Brackets node is running on port 31028
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:editor-node" finished delayed initialization
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:ui-builder" calling start()
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:ui-builder" finished start()
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:emulator-webserver" calling start()
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:emulator-webserver" finished start()
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:editor-node" calling start()
xdk:server:[2016-02-22T13:20:30.610Z]: (1456147230610): Component "server:editor-node" finished start()
xdk:server:[2016-02-22T13:20:30.625Z]: (1456147230625): Intel XDK is initialized now
xdk:server:[2016-02-22T13:20:30.625Z]: (1456147230625): Writing to the server data file
xdk:server:[2016-02-22T13:20:30.625Z]: (1456147230625): Wrote server data to "C:\Users\manini nini\AppData\Local\XDK\server-data.txt"
xdk:client:[2016-02-22T13:20:30.672Z]: (1456147230672): Successfully read server data file
xdk:client:[2016-02-22T13:20:31.289Z]: (1456147231289): Component "core:assert" starting import
xdk:client:[2016-02-22T13:20:31.290Z]: (1456147231290): Component "core:assert" finished initialization
xdk:client:[2016-02-22T13:20:31.290Z]: (1456147231290): Component "core:component-error" starting import
xdk:client:[2016-02-22T13:20:31.292Z]: (1456147231292): Component "core:component-error" finished initialization
xdk:client:[2016-02-22T13:20:31.292Z]: (1456147231292): Component "core:command-line-options" starting import
xdk:client:[2016-02-22T13:20:31.292Z]: (1456147231292): Component "core:command-line-options" finished initialization
xdk:client:[2016-02-22T13:20:31.292Z]: (1456147231292): Component "core:service-error" starting import
xdk:client:[2016-02-22T13:20:31.293Z]: (1456147231293): Component "core:service-error" finished initialization
xdk:client:[2016-02-22T13:20:31.293Z]: (1456147231293): Component "core:buffer" starting import
xdk:client:[2016-02-22T13:20:31.293Z]: (1456147231293): Component "core:buffer" finished initialization
xdk:client:[2016-02-22T13:20:31.293Z]: (1456147231293): Component "core:signaler" starting import
xdk:client:[2016-02-22T13:20:31.304Z]: (1456147231304): Component "core:signaler" finished initialization
xdk:client:[2016-02-22T13:20:31.304Z]: (1456147231304): Component "core:signaler-group" starting import
xdk:client:[2016-02-22T13:20:31.313Z]: (1456147231313): Component "core:signaler-group" finished initialization
xdk:client:[2016-02-22T13:20:31.313Z]: (1456147231313): Component "core:logger" starting import
xdk:client:[2016-02-22T13:20:31.316Z]: (1456147231316): Component "core:logger" finished initialization
xdk:client:[2016-02-22T13:20:31.316Z]: (1456147231316): Component "core:http-request" starting import
xdk:client:[2016-02-22T13:20:31.318Z]: (1456147231318): Component "core:http-request" finished initialization
xdk:client:[2016-02-22T13:20:31.318Z]: (1456147231318): Component "core:version" starting import
xdk:client:[2016-02-22T13:20:31.319Z]: (1456147231319): Component "core:version" finished initialization
xdk:client:[2016-02-22T13:20:31.319Z]: (1456147231319): Component "core:exit-notifier" starting import
xdk:client:[2016-02-22T13:20:31.319Z]: (1456147231319): Component "core:exit-notifier" finished initialization
xdk:client:[2016-02-22T13:20:31.319Z]: (1456147231319): Component "core:userfs-name-converter" starting import
xdk:client:[2016-02-22T13:20:31.320Z]: (1456147231320): Component "core:userfs-name-converter" finished initialization
xdk:client:[2016-02-22T13:20:31.321Z]: (1456147231321): Component "core:crash-handler" starting import
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:crash-handler" finished initialization
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:analytics" starting import
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:analytics" finished initialization
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:i18n-support" starting import
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:i18n-support" finished initialization
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:theme" starting import
xdk:client:[2016-02-22T13:20:31.323Z]: (1456147231323): Component "core:theme" finished initialization
xdk:client:[2016-02-22T13:20:31.343Z]: (1456147231343): Analytics ID: 5596479b-6958-4eb8-aae4-1a2992dec290
xdk:client:[2016-02-22T13:20:31.347Z]: (1456147231347): onExit listener 0:
    at Object.exports.onExit (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\core-modules\public\exit-notifier.js:17:2339)
    at setupDefaultAnalytics (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:1438)
    at C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\core-modules\public\analytics.js:17:6219
    at C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:1229:26
    at _fulfilled (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:834:54)
    at self.promiseDispatch.done (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:863:30)
    at Promise.promise.promiseDispatch (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:796:13)
    at C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:604:44
    at runSingle (C:\Users\manini nini\AppData\Local\Intel\XDK\xdk\node_modules\q\q.js:137:13)
xdk:client:[2016-02-22T13:20:31.504Z]: (1456147231504): Component "client:app" starting import
xdk:client:[2016-02-22T13:20:31.504Z]: (1456147231504): Component "client:help-helper" starting import
xdk:client:[2016-02-22T13:20:31.504Z]: (1456147231504): Component "client:nativefs" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:document-manager" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:project-manager" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:aa-controller" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:projects-renderers" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:projects-renderers-jsapp" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:projects-renderers-webapp" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:projects-renderers-iotapp" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:active-sync" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:apk-installer" starting import
xdk:client:[2016-02-22T13:20:31.505Z]: (1456147231505): Component "client:appcenter-options" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-manager" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-cocos2d" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-cocos2djs" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-phaser" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-pixi" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-easeljs" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-plain" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-render-frame" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:resource-util" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:bower-package-manager" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:services-tab" starting import
xdk:client:[2016-02-22T13:20:31.506Z]: (1456147231506): Component "client:editor" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:live-preview" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:backend-services" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:backend-feeds" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:merged-feed" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:backend-services-ext" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:backend-service-utils" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:app-starter" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:ui-builder-client" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:project-meta" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:contenttype-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:editor-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:platform-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:projecttype-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:library-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:cordova-registry" starting import
xdk:client:[2016-02-22T13:20:31.507Z]: (1456147231507): Component "client:service-method" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:settings-db" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:adb" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:iosdb" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:device" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:device-discovery" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:dialog-box" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:test-local-server" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:quick-tour" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:hot-keys" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:persistance" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:tabs" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:hash-utils" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:file-watcher" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:tool-tip" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:cordova" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:settings-ui" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:external-links" starting import
xdk:client:[2016-02-22T13:20:31.508Z]: (1456147231508): Component "client:external-editors-runner" starting import
xdk:client:[2016-02-22T13:20:31.509Z]: (1456147231509): Component "client:project-list-load" starting import
xdk:client:[2016-02-22T13:20:31.509Z]: (1456147231509): Component "client:upload-manager" starting import
xdk:client:[2016-02-22T13:20:31.509Z]: (1456147231509): Component "client:git-manager" starting import
xdk:client:[2016-02-22T13:20:31.574Z]: (1456147231574): Component "client:help-helper" finished initialization
xdk:client:[2016-02-22T13:20:31.585Z]: (1456147231585): Component "client:nativefs" finished initialization
xdk:client:[2016-02-22T13:20:31.935Z]: (1456147231935): Component "client:apk-installer" calling init()
xdk:client:[2016-02-22T13:20:31.935Z]: (1456147231935): Component "client:apk-installer" finished initialization
xdk:client:[2016-02-22T13:20:31.938Z]: (1456147231938): Component "client:active-sync" calling init()
xdk:client:[2016-02-22T13:20:31.939Z]: (1456147231939): Component "client:active-sync" finished initialization
xdk:client:[2016-02-22T13:20:31.940Z]: (1456147231940): Component "client:backend-feeds" calling init()
xdk:client:[2016-02-22T13:20:31.941Z]: (1456147231941): Component "client:backend-feeds" finished initialization
xdk:client:[2016-02-22T13:20:31.943Z]: (1456147231943): Component "client:backend-service-utils" finished initialization
xdk:client:[2016-02-22T13:20:31.971Z]: (1456147231971): Component "client:backend-services" calling init()
xdk:client:[2016-02-22T13:20:31.973Z]: (1456147231973): Component "client:backend-services" finished initialization
xdk:client:[2016-02-22T13:20:31.974Z]: (1456147231974): Component "client:backend-services-ext" calling init()
xdk:client:[2016-02-22T13:20:31.979Z]: (1456147231979): Component "client:backend-services-ext" finished initialization
xdk:client:[2016-02-22T13:20:32.032Z]: (1456147232032): Component "client:resource-render-frame" calling init()
xdk:client:[2016-02-22T13:20:32.033Z]: (1456147232033): Component "client:resource-render-frame" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.034Z]: (1456147232034): Component "client:resource-util" calling init()
xdk:client:[2016-02-22T13:20:32.034Z]: (1456147232034): Component "client:resource-util" finished initialization
xdk:client:[2016-02-22T13:20:32.037Z]: (1456147232038): Component "client:merged-feed" finished initialization
xdk:client:[2016-02-22T13:20:32.049Z]: (1456147232049): Component "client:project-meta" calling init()
xdk:client:[2016-02-22T13:20:32.049Z]: (1456147232049): Component "client:project-meta" finished initialization
xdk:client:[2016-02-22T13:20:32.055Z]: (1456147232055): Component "client:resource-render-frame" finished delayed initialization
xdk:client:[2016-02-22T13:20:32.109Z]: (1456147232109): Component "client:service-method" finished initialization
xdk:client:[2016-02-22T13:20:32.117Z]: (1456147232117): Component "client:iosdb" calling init()
xdk:client:[2016-02-22T13:20:32.118Z]: (1456147232118): Component "client:iosdb" finished initialization
xdk:client:[2016-02-22T13:20:32.119Z]: (1456147232119): Component "client:adb" calling init()
xdk:client:[2016-02-22T13:20:32.513Z]: (1456147232513): Component "client:adb" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.525Z]: (1456147232525): Component "client:settings-db" calling init()
xdk:client:[2016-02-22T13:20:32.526Z]: (1456147232526): Component "client:settings-db" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.537Z]: (1456147232537): Component "client:persistance" calling init()
xdk:client:[2016-02-22T13:20:32.537Z]: (1456147232537): Component "client:persistance" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.543Z]: (1456147232543): Component "client:external-editors-runner" calling init()
xdk:client:[2016-02-22T13:20:32.543Z]: (1456147232543): Component "client:external-editors-runner" finished initialization
xdk:client:[2016-02-22T13:20:32.544Z]: (1456147232544): Component "client:external-links" finished initialization
xdk:client:[2016-02-22T13:20:32.549Z]: (1456147232549): Component "client:file-watcher" calling init()
xdk:client:[2016-02-22T13:20:32.549Z]: (1456147232549): Component "client:file-watcher" finished initialization
xdk:client:[2016-02-22T13:20:32.553Z]: (1456147232553): Component "client:project-list-load" calling init()
xdk:client:[2016-02-22T13:20:32.553Z]: (1456147232553): Component "client:project-list-load" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.556Z]: (1456147232556): Component "client:upload-manager" calling init()
xdk:client:[2016-02-22T13:20:32.556Z]: (1456147232556): Component "client:upload-manager" finished initialization
xdk:client:[2016-02-22T13:20:32.565Z]: (1456147232565): Component "client:app-starter" finished initialization
xdk:client:[2016-02-22T13:20:32.567Z]: (1456147232567): Component "client:hot-keys" calling init()
xdk:client:[2016-02-22T13:20:32.567Z]: (1456147232567): Component "client:hot-keys" finished initialization
xdk:client:[2016-02-22T13:20:32.569Z]: (1456147232569): Component "client:git-manager" calling init()
client:git-manager:[2016-02-22T13:20:32.570Z]: (1456147232570): git path =  C:\Users\manini nini\AppData\Local\Intel\XDK\bin\git\bin\git.exe
xdk:client:[2016-02-22T13:20:32.570Z]: (1456147232570): Component "client:git-manager" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:32.582Z]: (1456147232582): Component "client:test-local-server" calling init()
xdk:client:[2016-02-22T13:20:33.108Z]: (1456147233108): Component "client:test-local-server" finished initialization
xdk:client:[2016-02-22T13:20:33.146Z]: (1456147233146): Component "client:aa-controller" calling init()
xdk:client:[2016-02-22T13:20:33.147Z]: (1456147233147): Component "client:aa-controller" finished initialization
xdk:client:[2016-02-22T13:20:33.150Z]: (1456147233150): Component "client:document-manager" calling init()
xdk:client:[2016-02-22T13:20:33.151Z]: (1456147233175): Component "client:document-manager" finished initialization
xdk:client:[2016-02-22T13:20:33.254Z]: (1456147233254): Component "client:appcenter-options" calling init()
xdk:client:[2016-02-22T13:20:33.254Z]: (1456147233254): Component "client:appcenter-options" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:33.484Z]: (1456147233484): Component "client:services-tab" calling init()
xdk:client:[2016-02-22T13:20:33.484Z]: (1456147233484): Component "client:services-tab" finished initialization
xdk:client:[2016-02-22T13:20:33.546Z]: (1456147233546): Component "client:editor-registry" finished initialization
xdk:client:[2016-02-22T13:20:33.546Z]: (1456147233546): Component "client:contenttype-registry" calling init()
xdk:client:[2016-02-22T13:20:33.562Z]: (1456147233562): Component "client:contenttype-registry" finished initialization
xdk:client:[2016-02-22T13:20:33.631Z]: (1456147233631): Component "client:library-registry" calling init()
xdk:client:[2016-02-22T13:20:33.631Z]: (1456147233631): Component "client:library-registry" finished initialization
xdk:client:[2016-02-22T13:20:33.657Z]: (1456147233657): Component "client:ui-builder-client" calling init()
xdk:client:[2016-02-22T13:20:33.658Z]: (1456147233658): Component "client:ui-builder-client" finished initialization
xdk:client:[2016-02-22T13:20:33.704Z]: (1456147233704): Component "client:tabs" finished initialization
xdk:client:[2016-02-22T13:20:33.747Z]: (1456147233747): Component "client:hash-utils" finished initialization
xdk:client:[2016-02-22T13:20:33.759Z]: (1456147233759): Component "client:tool-tip" finished initialization
xdk:client:[2016-02-22T13:20:33.768Z]: (1456147233768): Component "client:app" calling init()
xdk:client:[2016-02-22T13:20:33.787Z]: (1456147233787): Component "client:app" finished initialization
xdk:client:[2016-02-22T13:20:33.789Z]: (1456147233789): Component "client:settings-ui" finished initialization
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:navbar" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:tweets" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:projects-tab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:test-tab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:profilingTab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:emulator" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:remote-tab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:build-tab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:bower-client" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:editor-tab" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:account" starting import
xdk:client:[2016-02-22T13:20:33.790Z]: (1456147233790): Component "client:project-selector" starting import
xdk:client:[2016-02-22T13:20:33.799Z]: (1456147233799): Component "client:device-discovery" calling init()
xdk:client:[2016-02-22T13:20:33.800Z]: (1456147233800): Component "client:device-discovery" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:33.805Z]: (1456147233805): Component "client:dialog-box" finished initialization
xdk:client:[2016-02-22T13:20:34.566Z]: (1456147234566): Component "client:cordova" calling init()
xdk:client:[2016-02-22T13:20:34.566Z]: (1456147234566): Component "client:cordova" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:34.582Z]: (1456147234582): memmrk:    19387868    38352896
xdk:server:[2016-02-22T13:20:34.594Z]: (1456147234594): memmrk:    28898020    43419136
xdk:client:[2016-02-22T13:20:34.628Z]: (1456147234628): Component "client:settings-db" finished delayed initialization
xdk:client:[2016-02-22T13:20:34.654Z]: (1456147234654): Component "client:git-manager" finished delayed initialization
xdk:client:[2016-02-22T13:20:34.699Z]: (1456147234699): Component "client:cordova" finished delayed initialization
xdk:client:[2016-02-22T13:20:34.740Z]: (1456147234740): Component "client:quick-tour" calling init()
xdk:client:[2016-02-22T13:20:34.741Z]: (1456147234741): Component "client:quick-tour" finished initialization
xdk:client:[2016-02-22T13:20:34.766Z]: (1456147234766): Component "client:projects-renderers-iotapp" calling init()
xdk:client:[2016-02-22T13:20:34.771Z]: (1456147234771): Component "client:projects-renderers-iotapp" finished initialization
xdk:client:[2016-02-22T13:20:34.772Z]: (1456147234772): Component "client:projects-renderers" calling init()
xdk:client:[2016-02-22T13:20:34.772Z]: (1456147234772): Component "client:projects-renderers" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:34.959Z]: (1456147234959): Component "client:resource-cocos2d" calling init()
xdk:client:[2016-02-22T13:20:34.959Z]: (1456147234959): Component "client:resource-cocos2d" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:34.961Z]: (1456147234961): Component "client:resource-cocos2d" finished delayed initialization
xdk:client:[2016-02-22T13:20:34.967Z]: (1456147234967): Component "client:resource-pixi" calling init()
xdk:client:[2016-02-22T13:20:34.967Z]: (1456147234967): Component "client:resource-pixi" finished initialization
xdk:client:[2016-02-22T13:20:35.009Z]: (1456147235009): Component "client:resource-easeljs" calling init()
xdk:client:[2016-02-22T13:20:35.009Z]: (1456147235010): Component "client:resource-easeljs" finished initialization
xdk:client:[2016-02-22T13:20:35.017Z]: (1456147235017): Component "client:resource-cocos2djs" calling init()
xdk:client:[2016-02-22T13:20:35.017Z]: (1456147235017): Component "client:resource-cocos2djs" finished initialization
xdk:client:[2016-02-22T13:20:35.030Z]: (1456147235030): Component "client:resource-phaser" calling init()
xdk:client:[2016-02-22T13:20:35.030Z]: (1456147235030): Component "client:resource-phaser" finished initialization
xdk:client:[2016-02-22T13:20:35.071Z]: (1456147235071): Component "client:project-manager" calling init()
xdk:client:[2016-02-22T13:20:35.072Z]: (1456147235072): Component "client:project-manager" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:35.117Z]: (1456147235117): Component "client:resource-manager" calling init()
xdk:client:[2016-02-22T13:20:35.118Z]: (1456147235118): Component "client:resource-manager" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:35.164Z]: (1456147235164): Component "client:resource-plain" calling init()
xdk:client:[2016-02-22T13:20:35.165Z]: (1456147235165): Component "client:resource-plain" finished initialization
xdk:client:[2016-02-22T13:20:35.178Z]: (1456147235178): Component "client:device" calling init()
xdk:client:[2016-02-22T13:20:35.887Z]: (1456147235887): Component "client:device" threw exception during initialization
client:adb:[2016-02-22T13:20:35.911Z]: (1456147235911): Can't find adb process.
client:adb:[2016-02-22T13:20:35.912Z]: (1456147235912): Using default adb executable at "C:\Users\manini nini\AppData\Local\Intel\XDK\bin\adb\adb"
xdk:client:[2016-02-22T13:20:35.940Z]: (1456147235940): Component "client:cordova-registry" calling init()
xdk:client:[2016-02-22T13:20:35.941Z]: (1456147235941): Component "client:cordova-registry" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:36.033Z]: (1456147236033): Component "client:projecttype-registry" calling init()
xdk:client:[2016-02-22T13:20:36.034Z]: (1456147236034): Component "client:projecttype-registry" finished initialization
xdk:client:[2016-02-22T13:20:36.094Z]: (1456147236094): Component "client:platform-registry" calling init()
xdk:client:[2016-02-22T13:20:36.096Z]: (1456147236096): Component "client:platform-registry" finished initialization
xdk:client:[2016-02-22T13:20:36.132Z]: (1456147236132): Component "client:projects-renderers-webapp" calling init()
xdk:client:[2016-02-22T13:20:36.133Z]: (1456147236133): Component "client:projects-renderers-webapp" finished initialization
xdk:client:[2016-02-22T13:20:36.149Z]: (1456147236149): Component "client:projects-renderers-jsapp" calling init()
xdk:client:[2016-02-22T13:20:36.150Z]: (1456147236150): Component "client:projects-renderers-jsapp" finished initialization
xdk:client:[2016-02-22T13:20:36.157Z]: (1456147236157): Component "client:projects-renderers" finished delayed initialization
xdk:client:[2016-02-22T13:20:36.170Z]: (1456147236170): Component "client:projects-tab" getting UI region for "project"
xdk:client:[2016-02-22T13:20:36.170Z]: (1456147236170): Component "client:projects-tab" calling init()
xdk:client:[2016-02-22T13:20:36.172Z]: (1456147236172): Component "client:projects-tab" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:36.586Z]: (1456147236586): Component "client:test-tab" getting UI region for "test"
xdk:client:[2016-02-22T13:20:36.586Z]: (1456147236586): Component "client:test-tab" calling init()
xdk:client:[2016-02-22T13:20:36.586Z]: (1456147236586): Component "client:test-tab" waiting for delayed initialization
xdk:client:[2016-02-22T13:20:36.586Z]: (1456147236586): Component "client:tweets" finished initialization
xdk:client:[2016-02-22T13:20:36.864Z]: (1456147236864): Component "client:account" getting UI region for "account"
xdk:client:[2016-02-22T13:20:36.865Z]: (1456147236865): Component "client:account" calling init()
xdk:client:[2016-02-22T13:20:36.931Z]: (1456147236931): Component "client:account" finished initialization
xdk:client:[2016-02-22T13:20:36.939Z]: (1456147236939): Component "client:build-tab" getting UI region for "build"
xdk:client:[2016-02-22T13:20:36.939Z]: (1456147236939): Component "client:build-tab" calling init()
xdk:client:[2016-02-22T13:20:36.950Z]: (1456147236950): Component "client:build-tab" finished initialization
xdk:client:[2016-02-22T13:20:36.981Z]: (1456147236981): Component "client:emulator" getting UI region for "emulate"
xdk:client:[2016-02-22T13:20:36.981Z]: (1456147236981): Component "client:emulator" calling init()
xdk:client:[2016-02-22T13:20:36.986Z]: (1456147236986): Component "client:emulator" finished initialization
xdk:client:[2016-02-22T13:20:36.989Z]: (1456147236989): Component "client:project-selector" getting UI region for "project-selector"
xdk:client:[2016-02-22T13:20:36.990Z]: (1456147236990): Component "client:project-selector" calling init()
xdk:client:[2016-02-22T13:20:36.990Z]: (1456147236990): Component "client:project-selector" finished initialization
xdk:client:[2016-02-22T13:20:37.027Z]: (1456147237027): Component "client:bower-package-manager" calling init()
xdk:client:[2016-02-22T13:20:37.027Z]: (1456147237027): Component "client:bower-package-manager" finished initialization
xdk:client:[2016-02-22T13:20:37.060Z]: (1456147237060): Component "client:navbar" getting UI region for "navbar-common"
xdk:client:[2016-02-22T13:20:37.061Z]: (1456147237061): Component "client:navbar" calling init()
client:navbar:[2016-02-22T13:20:37.062Z]: (1456147237062): navbar options: {"common":{"servicesVersion":"release-2015-ww51"},"updatePollingInterval":1800,"forceUpdate":false}
xdk:client:[2016-02-22T13:20:37.063Z]: (1456147237063): Component "client:navbar" finished initialization
xdk:client:[2016-02-22T13:20:37.113Z]: (1456147237113): Uncaught top-level browser exception at file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:69: Uncaught TypeError: Cannot read property 'iosDebugImpl' of undefined
Stack trace from browser: TypeError: Cannot read property 'iosDebugImpl' of undefined
    at file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/components/client/remote-tab/remote-tab.js:19:22644
    at Object.context.execCb (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1615:33)
    at Object.Module.check (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:851:51)
    at Object.<anonymous> (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1092:34)
    at file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:129:23
    at file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1135:21
    at each (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:57:31)
    at Object.Module.emit (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1134:17)
    at Object.Module.check (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:905:30)
    at Object.Module.enable (file:///C:/Users/manini%20nini/AppData/Local/Intel/XDK/xdk/public/external/js/require-jquery.js:1122:22)
[Log closed from xdk:client]
xdk:server:[2016-02-22T13:20:39.607Z]: (1456147239607): memmrk:    29216904    43419136
xdk:server:[2016-02-22T13:20:44.612Z]: (1456147244612): memmrk:    20375112    43419136
xdk:server:[2016-02-22T13:20:49.624Z]: (1456147249624): memmrk:    18951224    26674816
xdk:server:[2016-02-22T13:20:54.636Z]: (1456147254636): memmrk:    18978976    26674816
xdk:server:[2016-02-22T13:20:59.637Z]: (1456147259637): memmrk:    18669268    24667776
xdk:server:[2016-02-22T13:21:04.637Z]: (1456147264637): memmrk:    16935360    23664256
xdk:server:[2016-02-22T13:21:09.638Z]: (1456147269639): memmrk:    17445188    23664256
xdk:server:[2016-02-22T13:21:14.639Z]: (1456147274639): memmrk:    16874824    22648576
xdk:server:[2016-02-22T13:21:19.639Z]: (1456147279639): memmrk:    16884284    23697152
xdk:server:[2016-02-22T13:21:24.639Z]: (1456147284639): memmrk:    16283820    23697152
xdk:server:[2016-02-22T13:21:29.640Z]: (1456147289640): memmrk:    16293260    23697152
xdk:server:[2016-02-22T13:21:34.644Z]: (1456147294644): memmrk:    16302564    23697152
xdk:server:[2016-02-22T13:21:39.644Z]: (1456147299644): memmrk:    16313152    23697152
xdk:server:[2016-02-22T13:21:44.645Z]: (1456147304645): memmrk:    16320484    23697152
xdk:server:[2016-02-22T13:21:49.645Z]: (1456147309645): memmrk:    16328484    23697152
xdk:server:[2016-02-22T13:21:54.646Z]: (1456147314646): memmrk:    16335816    23697152
xdk:server:[2016-02-22T13:21:59.646Z]: (1456147319646): memmrk:    16343148    23697152
xdk:server:[2016-02-22T13:22:04.646Z]: (1456147324646): memmrk:    16355112    23697152
xdk:server:[2016-02-22T13:22:09.647Z]: (1456147329647): memmrk:    16362444    23697152
xdk:server:[2016-02-22T13:22:14.648Z]: (1456147334648): memmrk:    16369788    23697152
xdk:server:[2016-02-22T13:22:19.649Z]: (1456147339649): memmrk:    16377136    23697152
xdk:server:[2016-02-22T13:22:24.657Z]: (1456147344657): memmrk:    16384484    23697152
xdk:server:[2016-02-22T13:22:29.662Z]: (1456147349662): memmrk:    16396024    23697152
xdk:server:[2016-02-22T13:22:34.672Z]: (1456147354672): memmrk:    16408004    23697152
xdk:server:[2016-02-22T13:22:39.688Z]: (1456147359688): memmrk:    16421920    23697152
xdk:server:[2016-02-22T13:22:44.703Z]: (1456147364703): memmrk:    16430188    23697152
xdk:server:[2016-02-22T13:22:49.703Z]: (1456147369703): memmrk:    16438920    23697152
xdk:server:[2016-02-22T13:22:54.703Z]: (1456147374703): memmrk:    16449084    23697152
xdk:server:[2016-02-22T13:22:59.707Z]: (1456147379707): memmrk:    16458164    23697152
xdk:server:[2016-02-22T13:23:04.723Z]: (1456147384723): memmrk:    16465192    23697152
xdk:server:[2016-02-22T13:23:09.732Z]: (1456147389732): memmrk:    16472252    23697152
xdk:server:[2016-02-22T13:23:14.733Z]: (1456147394733): memmrk:    16479296    23697152
xdk:server:[2016-02-22T13:23:19.733Z]: (1456147399733): memmrk:    16495668    23697152
xdk:server:[2016-02-22T13:23:24.749Z]: (1456147404749): memmrk:    16512488    23697152
xdk:server:[2016-02-22T13:23:29.755Z]: (1456147409755): memmrk:    16519500    23697152
xdk:server:[2016-02-22T13:23:34.761Z]: (1456147414761): memmrk:    16526512    23697152
xdk:server:[2016-02-22T13:23:39.777Z]: (1456147419777): memmrk:    16533524    23697152
xdk:server:[2016-02-22T13:23:44.777Z]: (1456147424777): memmrk:    16540536    23697152
xdk:server:[2016-02-22T13:23:49.778Z]: (1456147429778): memmrk:    16550136    23697152
xdk:server:[2016-02-22T13:23:54.780Z]: (1456147434780): memmrk:    16557148    23697152
xdk:server:[2016-02-22T13:23:59.795Z]: (1456147439795): memmrk:    16564160    23697152
xdk:server:[2016-02-22T13:24:04.796Z]: (1456147444796): memmrk:    16571172    23697152
xdk:server:[2016-02-22T13:24:09.800Z]: (1456147449800): memmrk:    16578200    23697152
xdk:server:[2016-02-22T13:24:14.810Z]: (1456147454810): memmrk:    16585228    23697152
xdk:server:[2016-02-22T13:24:19.810Z]: (1456147459810): memmrk:    16592240    23697152
xdk:server:[2016-02-22T13:24:24.825Z]: (1456147464825): memmrk:    16599768    23697152
xdk:server:[2016-02-22T13:24:29.825Z]: (1456147469825): memmrk:    16606780    23697152
xdk:server:[2016-02-22T13:24:34.825Z]: (1456147474825): memmrk:    16613776    23697152
xdk:server:[2016-02-22T13:24:39.832Z]: (1456147479832): memmrk:    16620772    23697152
xdk:server:[2016-02-22T13:24:44.838Z]: (1456147484838): memmrk:    16627784    23697152
xdk:server:[2016-02-22T13:24:49.853Z]: (1456147489853): memmrk:    16635760    23697152
xdk:server:[2016-02-22T13:24:54.866Z]: (1456147494866): memmrk:    16642772    23697152
xdk:server:[2016-02-22T13:24:59.882Z]: (1456147499882): memmrk:    16649784    23697152
xdk:server:[2016-02-22T13:25:04.890Z]: (1456147504890): memmrk:    16656796    23697152
xdk:server:[2016-02-22T13:25:09.896Z]: (1456147509896): memmrk:    16663840    23697152
xdk:server:[2016-02-22T13:25:14.900Z]: (1456147514900): memmrk:    16669944    23697152
xdk:server:[2016-02-22T13:25:19.912Z]: (1456147519912): memmrk:    16676956    23697152
xdk:server:[2016-02-22T13:25:24.913Z]: (1456147524913): memmrk:    16683968    23697152
xdk:server:[2016-02-22T13:25:29.925Z]: (1456147529925): memmrk:    16690980    23697152
xdk:server:[2016-02-22T13:25:34.927Z]: (1456147534927): memmrk:    16697992    23697152
xdk:server:[2016-02-22T13:25:39.927Z]: (1456147539927): memmrk:    16705004    23697152
xdk:server:[2016-02-22T13:25:44.936Z]: (1456147544936): memmrk:    16712000    23697152
xdk:server:[2016-02-22T13:25:49.942Z]: (1456147549942): memmrk:    16719012    23697152
xdk:server:[2016-02-22T13:25:54.944Z]: (1456147554944): memmrk:    16753540    23697152
xdk:server:[2016-02-22T13:25:59.958Z]: (1456147559958): memmrk:    16760512    23697152
xdk:server:[2016-02-22T13:26:04.963Z]: (1456147564963): memmrk:    16808288    23697152
xdk:server:[2016-02-22T13:26:09.975Z]: (1456147569975): memmrk:    16817292    23697152
xdk:server:[2016-02-22T13:26:14.990Z]: (1456147574990): memmrk:    16824340    23697152
xdk:server:[2016-02-22T13:26:19.997Z]: (1456147579997): memmrk:    16857012    23697152
xdk:server:[2016-02-22T13:26:24.998Z]: (1456147584998): memmrk:    16864044    23697152
xdk:server:[2016-02-22T13:26:30.000Z]: (1456147590000): memmrk:    16871076    23697152
xdk:server:[2016-02-22T13:26:35.016Z]: (1456147595016): memmrk:    16878248    23697152
xdk:server:[2016-02-22T13:26:40.031Z]: (1456147600031): memmrk:    16888384    23697152
xdk:server:[2016-02-22T13:26:45.038Z]: (1456147605038): memmrk:    16895420    23697152
xdk:server:[2016-02-22T13:26:50.039Z]: (1456147610039): memmrk:    16904228    23697152
xdk:server:[2016-02-22T13:26:55.047Z]: (1456147615047): memmrk:    16918948    23697152
xdk:server:[2016-02-22T13:27:00.050Z]: (1456147620050): memmrk:    16928680    23697152
xdk:server:[2016-02-22T13:27:05.057Z]: (1456147625057): memmrk:    16935716    23697152
xdk:server:[2016-02-22T13:27:10.062Z]: (1456147630062): memmrk:    16966288    23697152
xdk:server:[2016-02-22T13:27:15.070Z]: (1456147635070): memmrk:    16973148    23697152
xdk:server:[2016-02-22T13:27:20.070Z]: (1456147640070): memmrk:    16980008    23697152
xdk:server:[2016-02-22T13:27:25.078Z]: (1456147645078): memmrk:    16986868    23697152
xdk:server:[2016-02-22T13:27:30.094Z]: (1456147650094): memmrk:    16993712    23697152
xdk:server:[2016-02-22T13:27:35.101Z]: (1456147655101): memmrk:    17000556    23697152
xdk:server:[2016-02-22T13:27:40.112Z]: (1456147660112): memmrk:    17007372    23697152
xdk:server:[2016-02-22T13:27:45.119Z]: (1456147665119): memmrk:    17014188    23697152
xdk:server:[2016-02-22T13:27:50.133Z]: (1456147670133): memmrk:    17021004    23697152
xdk:server:[2016-02-22T13:27:55.142Z]: (1456147675142): memmrk:    17027820    23697152
xdk:server:[2016-02-22T13:28:00.146Z]: (1456147680146): memmrk:    17034636    23697152
xdk:server:[2016-02-22T13:28:05.157Z]: (1456147685157): memmrk:    17041500    23697152
xdk:server:[2016-02-22T13:28:10.164Z]: (1456147690164): memmrk:    17048332    23697152
xdk:server:[2016-02-22T13:28:15.176Z]: (1456147695176): memmrk:    17057584    23697152
xdk:server:[2016-02-22T13:28:20.177Z]: (1456147700177): memmrk:    17064400    23697152
xdk:server:[2016-02-22T13:28:25.192Z]: (1456147705192): memmrk:    17071216    23697152
xdk:server:[2016-02-22T13:28:30.202Z]: (1456147710202): memmrk:    17078032    23697152
xdk:server:[2016-02-22T13:28:35.209Z]: (1456147715209): memmrk:    17084848    23697152
xdk:server:[2016-02-22T13:28:40.214Z]: (1456147720214): memmrk:    17091664    23697152
xdk:server:[2016-02-22T13:28:45.220Z]: (1456147725220): memmrk:    17099456    23697152
xdk:server:[2016-02-22T13:28:50.227Z]: (1456147730227): memmrk:    17106272    23697152
xdk:server:[2016-02-22T13:28:55.227Z]: (1456147735227): memmrk:    17113088    23697152
xdk:server:[2016-02-22T13:29:00.238Z]: (1456147740238): memmrk:    17119904    23697152
xdk:server:[2016-02-22T13:29:05.240Z]: (1456147745240): memmrk:    17126736    23697152
xdk:server:[2016-02-22T13:29:10.255Z]: (1456147750255): memmrk:    17133568    23697152
xdk:server:[2016-02-22T13:29:15.256Z]: (1456147755256): memmrk:    17140384    23697152
xdk:server:[2016-02-22T13:29:20.258Z]: (1456147760258): memmrk:    17147200    23697152
xdk:server:[2016-02-22T13:29:25.273Z]: (1456147765273): memmrk:    17154016    23697152
xdk:server:[2016-02-22T13:29:30.274Z]: (1456147770274): memmrk:    17160832    23697152
xdk:server:[2016-02-22T13:29:35.279Z]: (1456147775279): memmrk:    17167648    23697152
xdk:server:[2016-02-22T13:29:40.289Z]: (1456147780289): memmrk:    17174464    23697152
xdk:server:[2016-02-22T13:29:45.298Z]: (1456147785298): memmrk:    17181280    23697152
xdk:server:[2016-02-22T13:29:50.298Z]: (1456147790298): memmrk:    17188096    23697152
xdk:server:[2016-02-22T13:29:55.300Z]: (1456147795300): memmrk:    17194912    23697152
xdk:server:[2016-02-22T13:30:00.315Z]: (1456147800315): memmrk:    17201728    23697152
xdk:server:[2016-02-22T13:30:05.315Z]: (1456147805315): memmrk:    17208560    23697152
xdk:server:[2016-02-22T13:30:10.315Z]: (1456147810315): memmrk:    17215392    23697152
xdk:server:[2016-02-22T13:30:15.315Z]: (1456147815315): memmrk:    17222208    23697152
xdk:server:[2016-02-22T13:30:20.321Z]: (1456147820321): memmrk:    17230348    23697152
xdk:server:[2016-02-22T13:30:25.322Z]: (1456147825322): memmrk:    17241520    23697152
xdk:server:[2016-02-22T13:30:30.323Z]: (1456147830323): memmrk:    17248336    23697152
xdk:server:[2016-02-22T13:30:35.324Z]: (1456147835324): memmrk:    17255152    23697152
xdk:server:[2016-02-22T13:30:40.324Z]: (1456147840324): memmrk:    17261968    23697152
xdk:server:[2016-02-22T13:30:45.325Z]: (1456147845325): memmrk:    17289780    23697152
xdk:server:[2016-02-22T13:30:50.325Z]: (1456147850325): memmrk:    17296596    23697152
xdk:server:[2016-02-22T13:30:55.325Z]: (1456147855325): memmrk:    17303412    23697152
xdk:server:[2016-02-22T13:31:00.325Z]: (1456147860325): memmrk:    17310228    23697152
xdk:server:[2016-02-22T13:31:05.325Z]: (1456147865325): memmrk:    17317060    23697152
xdk:server:[2016-02-22T13:31:10.325Z]: (1456147870325): memmrk:    17323892    23697152
xdk:server:[2016-02-22T13:31:15.327Z]: (1456147875327): memmrk:    17342344    23697152
xdk:server:[2016-02-22T13:31:20.328Z]: (1456147880328): memmrk:    17349080    23697152
xdk:server:[2016-02-22T13:31:25.331Z]: (1456147885331): memmrk:    17355880    23697152
xdk:server:[2016-02-22T13:31:30.331Z]: (1456147890331): memmrk:    17362680    23697152
xdk:server:[2016-02-22T13:31:35.331Z]: (1456147895331): memmrk:    17369480    23697152
xdk:server:[2016-02-22T13:31:40.331Z]: (1456147900331): memmrk:    17376296    23697152
xdk:server:[2016-02-22T13:31:45.332Z]: (1456147905332): memmrk:    17383096    23697152
xdk:server:[2016-02-22T13:31:50.332Z]: (1456147910332): memmrk:    17389912    23697152
xdk:server:[2016-02-22T13:31:55.332Z]: (1456147915332): memmrk:    17396728    23697152
xdk:server:[2016-02-22T13:32:00.333Z]: (1456147920333): memmrk:    17403528    23697152
xdk:server:[2016-02-22T13:32:05.333Z]: (1456147925333): memmrk:    17410376    23697152
xdk:server:[2016-02-22T13:32:10.333Z]: (1456147930333): memmrk:    17417400    23697152
xdk:server:[2016-02-22T13:32:15.335Z]: (1456147935335): memmrk:    17423328    23697152
xdk:server:[2016-02-22T13:32:20.335Z]: (1456147940335): memmrk:    17430112    23697152
xdk:server:[2016-02-22T13:32:25.335Z]: (1456147945335): memmrk:    17436928    23697152
xdk:server:[2016-02-22T13:32:30.336Z]: (1456147950336): memmrk:    17443744    23697152
xdk:server:[2016-02-22T13:32:35.336Z]: (1456147955336): memmrk:    17463376    23697152
xdk:server:[2016-02-22T13:32:40.338Z]: (1456147960338): memmrk:    17470176    23697152
xdk:server:[2016-02-22T13:32:45.338Z]: (1456147965338): memmrk:    17476976    23697152
xdk:server:[2016-02-22T13:32:50.348Z]: (1456147970348): memmrk:    17483776    23697152
xdk:server:[2016-02-22T13:32:55.360Z]: (1456147975360): memmrk:    17490592    23697152
xdk:server:[2016-02-22T13:33:00.349Z]: (1456147980349): memmrk:    16528508    23697152
xdk:server:[2016-02-22T13:33:05.349Z]: (1456147985349): memmrk:    16535340    23697152
xdk:server:[2016-02-22T13:33:10.349Z]: (1456147990349): memmrk:    16542156    23697152
xdk:server:[2016-02-22T13:33:15.350Z]: (1456147995350): memmrk:    16548956    23697152
xdk:server:[2016-02-22T13:33:20.350Z]: (1456148000350): memmrk:    16555772    23697152
xdk:server:[2016-02-22T13:33:25.350Z]: (1456148005350): memmrk:    16562588    23697152
xdk:server:[2016-02-22T13:33:30.351Z]: (1456148010351): memmrk:    16569388    23697152
xdk:server:[2016-02-22T13:33:35.351Z]: (1456148015351): memmrk:    16576188    23697152
xdk:server:[2016-02-22T13:33:40.351Z]: (1456148020351): memmrk:    16583004    23697152
xdk:server:[2016-02-22T13:33:45.351Z]: (1456148025351): memmrk:    16589820    23697152
xdk:server:[2016-02-22T13:33:50.351Z]: (1456148030351): memmrk:    16596604    23697152
xdk:server:[2016-02-22T13:33:55.351Z]: (1456148035351): memmrk:    16603404    23697152
xdk:server:[2016-02-22T13:34:00.354Z]: (1456148040354): memmrk:    16610220    23697152
xdk:server:[2016-02-22T13:34:05.353Z]: (1456148045353): memmrk:    16627740    23697152
xdk:server:[2016-02-22T13:34:10.354Z]: (1456148050354): memmrk:    16634556    23697152
xdk:server:[2016-02-22T13:34:15.355Z]: (1456148055355): memmrk:    16641356    23697152
xdk:server:[2016-02-22T13:34:20.356Z]: (1456148060356): memmrk:    16650300    23697152
xdk:server:[2016-02-22T13:34:25.357Z]: (1456148065357): memmrk:    16657084    23697152
xdk:server:[2016-02-22T13:34:30.357Z]: (1456148070357): memmrk:    16663884    23697152
xdk:server:[2016-02-22T13:34:35.357Z]: (1456148075357): memmrk:    16670668    23697152
xdk:server:[2016-02-22T13:34:40.357Z]: (1456148080357): memmrk:    16677468    23697152
xdk:server:[2016-02-22T13:34:45.358Z]: (1456148085358): memmrk:    16684268    23697152
xdk:server:[2016-02-22T13:34:50.358Z]: (1456148090358): memmrk:    16691052    23697152
xdk:server:[2016-02-22T13:34:55.358Z]: (1456148095358): memmrk:    16697852    23697152
xdk:server:[2016-02-22T13:35:00.358Z]: (1456148100358): memmrk:    16704636    23697152
xdk:server:[2016-02-22T13:35:05.359Z]: (1456148105359): memmrk:    16711452    23697152
xdk:server:[2016-02-22T13:35:10.359Z]: (1456148110359): memmrk:    16718268    23697152
xdk:server:[2016-02-22T13:35:15.359Z]: (1456148115359): memmrk:    16725052    23697152
xdk:server:[2016-02-22T13:35:20.361Z]: (1456148120361): memmrk:    16731852    23697152
xdk:server:[2016-02-22T13:35:25.361Z]: (1456148125361): memmrk:    16738636    23697152
xdk:server:[2016-02-22T13:35:30.361Z]: (1456148130361): memmrk:    16745420    23697152
xdk:server:[2016-02-22T13:35:35.361Z]: (1456148135361): memmrk:    16752204    23697152
xdk:server:[2016-02-22T13:35:40.362Z]: (1456148140362): memmrk:    16759004    23697152
xdk:server:[2016-02-22T13:35:45.362Z]: (1456148145362): memmrk:    16765788    23697152
xdk:server:[2016-02-22T13:35:50.363Z]: (1456148150363): memmrk:    16772572    23697152
xdk:server:[2016-02-22T13:35:55.363Z]: (1456148155363): memmrk:    16779372    23697152
xdk:server:[2016-02-22T13:36:00.363Z]: (1456148160363): memmrk:    16786140    23697152
xdk:server:[2016-02-22T13:36:05.363Z]: (1456148165363): memmrk:    16792972    23697152
xdk:server:[2016-02-22T13:36:10.363Z]: (1456148170363): memmrk:    16799772    23697152
xdk:server:[2016-02-22T13:36:15.363Z]: (1456148175363): memmrk:    16806556    23697152
xdk:server:[2016-02-22T13:36:20.363Z]: (1456148180363): memmrk:    16813340    23697152
xdk:server:[2016-02-22T13:36:25.363Z]: (1456148185363): memmrk:    16820140    23697152
xdk:server:[2016-02-22T13:36:30.364Z]: (1456148190364): memmrk:    16826940    23697152
xdk:server:[2016-02-22T13:36:35.365Z]: (1456148195365): memmrk:    16833724    23697152
xdk:server:[2016-02-22T13:36:40.365Z]: (1456148200365): memmrk:    16840508    23697152
xdk:server:[2016-02-22T13:36:45.366Z]: (1456148205366): memmrk:    16847308    23697152
xdk:server:[2016-02-22T13:36:50.366Z]: (1456148210366): memmrk:    16854092    23697152
xdk:server:[2016-02-22T13:36:55.366Z]: (1456148215366): memmrk:    16860892    23697152
xdk:server:[2016-02-22T13:37:00.366Z]: (1456148220366): memmrk:    16867692    23697152
xdk:server:[2016-02-22T13:37:05.366Z]: (1456148225366): memmrk:    16874508    23697152
xdk:server:[2016-02-22T13:37:10.370Z]: (1456148230370): memmrk:    16881308    23697152
xdk:server:[2016-02-22T13:37:15.369Z]: (1456148235369): memmrk:    16888128    23697152
xdk:server:[2016-02-22T13:37:20.370Z]: (1456148240370): memmrk:    16894988    23697152
xdk:server:[2016-02-22T13:37:25.370Z]: (1456148245370): memmrk:    16901848    23697152
xdk:server:[2016-02-22T13:37:30.370Z]: (1456148250370): memmrk:    16908708    23697152
xdk:server:[2016-02-22T13:37:35.370Z]: (1456148255370): memmrk:    16915568    23697152
xdk:server:[2016-02-22T13:37:40.370Z]: (1456148260370): memmrk:    16922428    23697152
xdk:server:[2016-02-22T13:37:45.371Z]: (1456148265371): memmrk:    16929288    23697152
xdk:server:[2016-02-22T13:37:50.371Z]: (1456148270371): memmrk:    16936148    23697152
xdk:server:[2016-02-22T13:37:55.371Z]: (1456148275371): memmrk:    16943008    23697152
xdk:server:[2016-02-22T13:38:00.372Z]: (1456148280372): memmrk:    16949868    23697152
xdk:server:[2016-02-22T13:38:05.372Z]: (1456148285372): memmrk:    16956744    23697152
xdk:server:[2016-02-22T13:38:10.372Z]: (1456148290372): memmrk:    16963620    23697152
xdk:server:[2016-02-22T13:38:15.372Z]: (1456148295372): memmrk:    16970480    23697152
xdk:server:[2016-02-22T13:38:20.372Z]: (1456148300372): memmrk:    16977340    23697152
xdk:server:[2016-02-22T13:38:25.373Z]: (1456148305373): memmrk:    16984200    23697152
xdk:server:[2016-02-22T13:38:30.373Z]: (1456148310373): memmrk:    16991060    23697152
xdk:server:[2016-02-22T13:38:35.373Z]: (1456148315373): memmrk:    16997920    23697152
xdk:server:[2016-02-22T13:38:40.374Z]: (1456148320374): memmrk:    17004780    23697152
xdk:server:[2016-02-22T13:38:45.374Z]: (1456148325374): memmrk:    17011640    23697152
xdk:server:[2016-02-22T13:38:50.374Z]: (1456148330374): memmrk:    17018500    23697152
xdk:server:[2016-02-22T13:38:55.374Z]: (1456148335374): memmrk:    17025360    23697152
xdk:server:[2016-02-22T13:39:00.375Z]: (1456148340375): memmrk:    17032220    23697152
xdk:server:[2016-02-22T13:39:05.375Z]: (1456148345375): memmrk:    17039096    23697152
xdk:server:[2016-02-22T13:39:10.375Z]: (1456148350375): memmrk:    17045972    23697152
xdk:server:[2016-02-22T13:39:15.375Z]: (1456148355375): memmrk:    17052832    23697152
xdk:server:[2016-02-22T13:39:20.377Z]: (1456148360377): memmrk:    17059692    23697152
xdk:server:[2016-02-22T13:39:25.375Z]: (1456148365375): memmrk:    17066552    23697152
xdk:server:[2016-02-22T13:39:30.376Z]: (1456148370376): memmrk:    17073412    23697152
xdk:server:[2016-02-22T13:39:35.377Z]: (1456148375377): memmrk:    17080272    23697152
John_H_Intel2
Did you try uninstalling/reinstalling the XDK?
Sobhan_A_
yes I have reinstalled the software 3 times by now
John_H_Intel2
We have had very minimal issues with Windows 10 and the XDK.
Is this a update to windows 10 or did you format and reinstall?
What antivirus software do you have installed? Can you try disabling it and reinstalling?
Eric_B_3
Also trying to install Intel XDK on windows10 x64, The XDK versions were "iot_web_win_master_3400" and "IntelXDK_Win_2893" downloaded directly from Intel.
The first error message is:
Rolling back failed components
Rollback component 2 of 2: Node-Webkit
The second error message is:
Intel XDK Setup Wizard ended prematurely because of an error(s)
failed_to_extract_archive
A file error occured (Unspecified error)
see attached for jpegs
Any help would be so much appreciated!
PaulF_IntelCorp
The problem might be related to this FAQ > https://software.intel.com/en-us/xdk/faqs/general#install-pkg-sig-failed < Also, do not change the location of the install, use the default location, installing elsewhere can result in permission problems. And try rebooting your machine before the next install, sometimes there are outstanding Windows updates that need to be installed.
Eric_B_3
Thank you for replying so quickly Paul. I have tried installing every release of the Intel XDK in the default location on my Windows 10 x64 machine more than a couple times each and still nothing. I tried the suggestions that were mentioned in that link you sent me also..turning on the Certificate Propagation etc. The software still will not install. I'm stumped. Any other suggestions you can give..please do. Thanks so much, Eric :)
PaulF_IntelCorp
Are you able to install on any other machines? Is this a work machine or a personal machine? Might be some install restrictions if this is a work machine. Otherwise, stumped on this one. :-(
Keith_T_
I have installed on Windows 10 with no problem.
Possibly try cleaning up some of these directories...
%USERPROFILE%\AppData\Local\Temp
%USERPROFILE%\AppData\Local\XDK\xdk-scratchdir
You may want to uninstall, completely delete that XDK directory, and then reinstall.
If you look at the screenshot, you may want to delete that directory show there as well, it's possible you have HD corruption, you may want to run chdksk. Also, make sure you have enough HD space.
