Software Archive
Read-only legacy content
17061 Discussions
IntelXDK: Path Error for Launch Icons and SplashScreen
igor_m_1
I'm currently using IntelXDK release 3522.
My project is old (is created 1 years ago), and now I changed icon launch and splashscreen.
I see that size of icons are changed, however remove old icons and splashscreen and add new png files.
after that, making a new build, an error occured.
Intel XDK load new files in "package-assets" folder,  but try to load also old files located in "www/src/images".
I cannot remove all old files , because many sizes no longer appear in the tool-box
PROJECT --> CORDOVA  HYBRID MOBILE APP SETTINGS - LAUNCH ICONS AND SPLASHSCREENS
so, for example, in "intelxdk.config.wp81.xml" , is auto-generated, but also include old files that I cannot remove:
<icon platform="windows" src="images/launchIcon_24.png" width="24" height="24"/>
<icon platform="windows" src="images/launchIcon_434x210.png" width="434" height="210"/>
<icon platform="windows" src="images/launchIcon_744x360.png" width="744" height="360"/>
<icon platform="windows" src="package-assets/ic_launch_50.png" width="50" height="50"/>
<icon platform="windows" src="package-assets/ic_launch_150.png" width="150" height="150"/>
<icon platform="windows" src="package-assets/ic_launch_44.png" width="44" height="44"/>
For a building right, i need leave old file , in old path www/src/images
How can I remove any reference to this files or path?
best regards
Igor Milani
PaulF_IntelCorp
Igor -- use a CODE or TEXT editor (that is, a program editor like Notepad++ or Brackets or Sublime Text or vi) to edit the <project-name>.xdk file in the root of your project folder. Inside of it you'll find entries that look like this:
        "icons_": [
            "relPath": "package-assets/ios/icon-small.png",
            "width": 29,
            "height": 29
            "relPath": "package-assets/ios/icon-small@2x.png",
            "width": 58,
            "height": 58
            "relPath": "package-assets/ios/icon-small@3x.png",
            "width": 87,
            "height": 87
Search for the entries that are pointing to the problem files and remove those problem entries from the <project-name>.xdk file.
Obviously, you need to do this when the XDK is closed and you should make a backup copy of your <project-name>.xdk file before making changes to it, just in case you end up with a missing comma. That file is a JSON file and needs to be a proper JSON file or it will not be read properly by the XDK when you open it.
Then, move the icons to the package-assets folder and reference them from there. See this file for an example of how to add additional icons using the intelxdk.config.additions.xml file > https://github.com/gomobile/sample-cocos2d-html5-spritesheet-animation/blob/master/intelxdk.config.additions.xml <
