Software Archive
Read-only legacy content
17060 Discussions
Ios build succeeded but getting error code 0
Ozgur_O_
I built an app for iOS with Cordova 4.2.1 (and then tried 5.1.1 also) ,created certificate and the provisioning files folllowing the instructions below :
http://www.html5dev-software.intel.com/amdocs/lib/Walkthrough_v1_UploadCSR-ObtainCert.pdf
http://www.html5dev-software.intel.com/amdocs/lib/Walkthrough_v3_CreateDistProvProfile.pdf
It failed but when i checked the error log (the file is attached) i got 'Build Succeeded' message with error code 0.
Do you have any idea regarding this issue?
John_H_Intel2
There is currently a bug with Cordova that if the app name and project name are identical, it will fail to build.Try changing your App Name and see if that allows it to build. We should have a patch for this in the near future.
John_H_Intel2
Ozgur_O_
Yes It works!
Thanks for your help John.
