Software Archive
Read-only legacy content
17060 Discussions
Ios9 causes app to shrink on screen
Nick_F_2
New Contributor III
Since installing ios9 a number of my apps only fill about 80% of the screen there is a large black margin at the top and bottom.
Even scrolling does not move the app into these margins.
Amrita_C_Intel
I can check this. Can you tell me which device are you using? iphone 4,5 or 6?
Amrita_C_Intel
Or try building with 5.1.1 Cordova CLI.
Nick_F_2
New Contributor III
iPhone 5s
Nick_F_2
New Contributor III
Where do I set the Cordova version.
Elroy_A_Intel
You can set the Cordova version on the Projects Panel > Cordova Hybrid Mobile App Settings > Build Settings > <desired_mobile_platform> tab.
There should be a Cordova CLI Version field.
Nick_F_2
New Contributor III
Hi
I have now compiled with 5.1.1 Cordova CLI and it has not made any difference.
Applications are still compressed visually to the middle 80% of the screen.
Nick_F_2
New Contributor III
Hi Moritz
Thank you for confirm the other devices are OK. I only have an iPhone 5s /iOS9 to use.
To also confirm this issue occurs under UI Framework JQuery Mobile and App Framework (Apps that I have created).
Nick_F_2
New Contributor III
Another observation is that the iPhone status bar normally at the top of the screen is moved down roughly equivalent to the depth of a header and likewise the bottom is moved up equivalent to the depth of a footer.
I have attached a screen grab for reference. Sorry but blurred the contents for my piece of mind.
PaulF_IntelCorp
It sounds like this might be due to the size of the launch screens, as weird as that sounds. If that is correct, my suspicion is the launch screen is being used to determine the size of the webview window when initialized. Not sure if this is an iOS 9 or a Cordova issue.
See these posts:
Nick_F_2
New Contributor III
Hi Paul
Thanks for the info, but I'm stuck on how to fix this. My splash screens are set as per XDK for all Portrait resolutions. What does make sense is that according to Moritz, this does not occur on the iPhone 6 with iOS9.
How do you change the launch screens if the images are set within XDK
Amrita_C_Intel
Hello Nick,
I would suggest you going through this article- https://software.intel.com/en-us/xdk/articles/android-splash-screens-using-nine-patch-png
which might be helpful
PaulF_IntelCorp
Nick, I've asked some of our iOS experts to take a closer look at this problem, it's not obvious what the solution is at this time.
Nick_F_2
New Contributor III
Any news on this please.
I have a demo of a new app to show a client on Monday and it won't look good in its current state.
PaulF_IntelCorp
No news, we don't understand what is causing this problem at this time.
Nick_F_2
New Contributor III
Well not sure what the issue was, but recompiled both apps suffering the screen shrinkage and the problem is now fixed.
No code changes so assuming it was a Cordova issue.
Ian_Ippolito
I am also running into this problem on iOS with the iPhone 5. It worked perfectly fine before the upgrade, but now has a black empty space on the top and bottom causing the entire screen to be shrunk about 20%.
Paul, have you figured out anything since this was posted last month?
PaulF_IntelCorp
See this forum thread, appears to be some useful info there: https://software.intel.com/en-us/forums/intel-xdk/topic/597945
Ian_Ippolito
that is really helpful. Thanks Paul!
