Software Archive
Read-only legacy content
17060 Discussions
Is there any way to rename a picture taken from the camera ?
Rodrigo_M_1
New Contributor II
Hi there,
I'm looking for a way to rename a picture taken from the camera. If any one could help me, I'll appreciate that!
// Camera 3rd party plugin website: https://github.com/01org/cordova-plugin-intel-xdk-camera
document.addEventListener("intel.xdk.camera.picture.add",onSuccess);
document.addEventListener("intel.xdk.camera.picture.busy",onSuccess);
document.addEventListener("intel.xdk.camera.picture.cancel",onSuccess);
function capturePhoto() {
  intel.xdk.camera.takePicture(50,false,"jpg");
function onSuccess(evt) {
  if (evt.success === true)
    // create image
    var image = document.createElement('img');
    image.src=intel.xdk.camera.getPictureURL(evt.filename);
    image.id=evt.filename;
    //document.body.appendChild(image);
    getPictureList();
  else
    if (evt.message !== undefined)
        alert(evt.message);
    else
        alert("error capturing picture");
Thanks!
Dale_S_Intel
When you send the file to a webservice, how do you specify the name?  Is it possible to rename there?
Dale
Chris_P_Intel
If I'm not mistaken, you'll need the Cordova File Plugin to do that.
https://github.com/apache/cordova-plugin-file
http://www.html5rocks.com/en/tutorials/file/filesystem/
Hope this helps,
Chris
Rodrigo_M_1
New Contributor II
Hi CHRIS Thanks for the tip, but I have tried and no success!
I have imported the plugin with success, but the code givemes a 'NOT_FOUND_ERR' .. Any idea?
Here is the code:
function rename(cwd, src, newName) {
  cwd.getFile(src, {}, function(fileEntry) {
    fileEntry.moveTo(cwd, newName);
  }, errorHandler);
window.requestFileSystem(window.TEMPORARY, 1024*1024, function(fs) {
  rename(fs.root, '/images/Arrow.png', 'you.png');
}, errorHandler);
function errorHandler(e) {
  var msg = '';
  switch (e.code) {
    case FileError.QUOTA_EXCEEDED_ERR:
      msg = 'QUOTA_EXCEEDED_ERR';
      break;
    case FileError.NOT_FOUND_ERR:
      msg = 'NOT_FOUND_ERR';
      break;
    case FileError.SECURITY_ERR:
      msg = 'SECURITY_ERR';
      break;
    case FileError.INVALID_MODIFICATION_ERR:
      msg = 'INVALID_MODIFICATION_ERR';
      break;
    case FileError.INVALID_STATE_ERR:
      msg = 'INVALID_STATE_ERR';
      break;
    default:
      msg = 'Unknown Error';
      break;
  alert('Error: ' + msg);
Thanks!
PaulF_IntelCorp
The filesystem on a mobile device is not like that on your PC or Mac, you cannot manipulate and rename files except where your app has specific permission and access. Where those places are is very limited and OS dependent. If you are trying to rename files that reside within your app's install location that will not work.
Rodrigo_M_1
New Contributor II
Hi Paul , I appreciate your reply!
Do you know another way to rename the file ?
The point is: I'll send these file to a webservice, but if we have a multiple phones, they are going to send the same name of the file... and I would like to rename it, and add some thing like the device id for example!
Thanks!
Dale_S_Intel
Dale
Gary_H_2
If you are using the FileTransfer plugin then specifying the file name the server will use is one of the options.
Rodrigo_M_1
New Contributor II
Hi Dale  / Gary,
I just did this (before read the answers in here) and it works!
I'm using the File Transfer plugin, and I just rename in the transfer process.
So, I'll take this option for now until I figure out how to rename a local file (I'll need this feature later!)
Thank you guys!
