Software Archive
Read-only legacy content
17060 Discussions
Issue with APP ID on Windows build x Windows Store
Hamilton_Tenório_da_
Valued Contributor I
I am trying to publish an APP to Windows Store. The name of APP is ConfirmAkiPRO.
When I use only this name on building settings, the Windows Store does not accept my package. The error is:
Validation error:   All packages for this app must use the package identity name: 9HTSInformtica.ConfirmAkiPRO
If I change the ID name to this, the build starts OK:
Build Log:
  • Building a Cordova 4.1.2 application.
  • The application name is ConfirmAki PRO
  • The package name is 9HTSInformtica.ConfirmAkiPRO
but does not finish. In the log appears this line:
...\ConfirmAkiPRO\platforms\windows\build\windows80\Release\AnyCPU\AppxManifest.xml(24,18): error APPX1404: File content does not conform to specified schema. The 'Id' attribute is invalid - The value '9HTSInformtica.ConfirmAkiPRO' is invalid according to its datatype
I´m lost.... It is my first APP in Windows Store. Maybe I´m doing somehing wrong.
Eric_H_Intel
Cordova 4.1.2 for Windows updates two fields in the appxmanifest file with the package name.   Unfortunately the fields have different specifications.   The one that is causing the error in your build does not allow the period "." character.
I have put a short term fix in place.   Try your build again and it should get past that problem.
Eric
Bhavya_A_
i am also having the same problem
here is the build log:
The 'Id' attribute is invalid - The value '5BA24DDE.Cordova008' is invalid according to its datatype 'http://schemas.microsoft.com/appx/2010/manifest:ST_ApplicationId' - The Pattern constraint failed. [...\test\platforms\windows\CordovaApp.Phone.jsproj]
ERROR: Error code 1 for command: ...\MSBuild\12.0\bin\msbuild with args: ...\test\platforms\windows\CordovaApp.Phone.jsproj,/clp:NoSummary;NoItemAndPropertyList;Verbosity=minimal,/nologo,/p:Configuration=release,/p:Platform=anycpu,/p:BuildFromCordovaTooling=true
Command finished with error code 2: ...\test\platforms\windows\cordova\build.bat --release,--verbose,--phone
Error: ...\test\platforms\windows\cordova\build.bat: Command failed with exit code 2
    at ChildProcess.whenDone (D:\Developer\cordova\4.1.2\node_modules\cordova\node_modules\cordova-lib\src\cordova\superspawn.js:135:23)
    at ChildProcess.emit (events.js:98:17)
    at maybeClose (child_process.js:756:16)
    at Process.ChildProcess._handle.onexit (child_process.js:823:5)
For more details please see the attached build log
Please help me out with this error.
Bhavya_A_
I am also having the same issue.
Please do see the attached build log with this comment.
Bhavya_A_
Hi ,
Please help to resolve the issue .
In that time, Intel applied a workaround in the system build and I could build normally. For a long time I don´t build for Windows. I don´t know how is it today.
PaulF_IntelCorp
Bhavya -- please see this updated note to see if this is being caused by an incorrect publisher ID.
Bhavya_A_
Hi Paul,
I have changed my Publisher id from windows publisher id to window phone publisher id but yet not able to build my app.
Please help to resolve this issue as soon as possible.
Bhavya
PaulF_IntelCorp
This is being worked on. Please try using CLI 4.1.2 as a workaround.
Bhavya_A_
Paul
I have used both CLI :4.1.2 and CLI : 5.1.1 getting the same error.
Bhavya
Pamela_H_Intel
Bhavya,
It looks like you are discussing this issue in two threads. Please post in a single thread.
I have checked on the status of the invalid app id build issue. The engineer in charge is working on it. I will post in this thread when we have a fix in the build system.
Pamela
Fernando_O_
Please,
Help me! I got same error to publish Intel XDK App to Windows.
The problem consist at package name. A composted name is waited in this field, like (xxxxxxxx.xxxxxxxxx).
When I try to put correct package name at Intel XDK Build settings I got fail built saying that I cant use "." in this filed.
Could you help me?
Thank you,
Fernando Oliveira
Pamela_H_Intel
Fernando,
This question is not related to this thread. Please post in a new thread. When you do, please copy the exact error message. I'm not sure what name you changed in XDK - the Publisher ID has dashes, not dots. The App ID has dots. It looks like Windows expects a string for the package name. I think you are referring to the App Name in XDK?
Again, please clarify in a new thread.
Pamela
Pamela_H_Intel
This question is being answered in thread: https://software.intel.com/en-us/forums/intel-xdk/topic/611641
