Software Archive
Read-only legacy content
17060 Discussions
Error: A build error occurred. Check the build log. Not sure how to fix? Construct 2?
zhang__hugo
I exported my Construct 2 game through Cordova and was trying to build it with Intel but I always get this error and I don't know how to fix it. Any ideas?
The build failed.
An error occurred while building the application. Verify your build assets are correct and try again.
You can view the detailed log of the iOS build here
Build Log:
  • Building a Cordova 5.1.1 application.
  • The application name is "FlappyBirdsReturnTest3"
  • The package name is "not.yet.specified"
  • Will use the provisioning profile for "adhoc"
  • Plugin "cordova-plugin-device" (1.1.0) installed.
  • Plugin "cordova-plugin-splashscreen" (2.1.0) installed.
  • Plugin "cc.fovea.plugins.inapppurchase" (3.4.1) installed.
  • Plugin "com.mcm.plugins.androidinappbilling" (3.0.6) installed.
  • Plugin "com.rjfun.cordova.plugin.iad" (0.1.8) installed.
  • Plugin "uk.co.ilee.gamecenter" (0.3.3) installed.
  • Targeting iOS version 6.
  • Error: A build error occurred. Check the build log.
Swati_S_Intel1
The iOS build issue for armv7s architecture has been fixed. You should be able to build now with the plugins not having the armv7s architecture.
Swati_S_Intel1
Can you attach the build log? (Click on the "here" link on the build page)
Swati_S_Intel1
Our current iOS build system requires armv7s architecture and one of the plugins in your project includes a static library without armv7s support. We are in the process of removing this requirement from our build system. This will be fixed soon. I'll update you when it's fixed.
zhang__hugo
Okay, thank you very much. Also, when I debug my game with the Intel app preview, the sound files become distorted. It is happening to many Construct 2 users so I was wondering if there is a workaround.
PaulF_IntelCorp
@Hugo -- one other Construct2 user mentioned problems with distorted sound files and it was due to some beta update at Scirra, not the XDK. You might want to check and see if the Construct2 files in your project need to be updated.
Swati_S_Intel1
