Software Archive
Read-only legacy content
공지
17060 토론
Issue with Enabling Hand and Face together
sagar_d_1
초급자
1,545 조회수
I'm trying to enable both hand and face tracking in a application. The application works fine on Windows 8.1 PC but the application crashes when launched on a Windows 10 PC. After checking found that the application fails when it tries to "EnableHand()".
Application is developed on WPF C# with Intel R6 and F200 camera.
0 포인트
7 응답
samontab
소중한 기여자 II
1,545 조회수
Do you have all the correct libraries and runtimes installed? I don't see a reason why it would work fine in 8.1 but not on 10 other than you missed some files, or there are different versions of the modules/libraries, etc.
0 포인트
sagar_d_1
초급자
1,545 조회수
Thank you for your response.
I have installed Intel Realsense SDK R6 v 8.0.24.6528 with DCM for F200 v 1.4.27.52404.
Tried reinstalling the SDK but no luck. I have created another application which has just Hand tracking and that too seems to be crashing in win 10. But works perfectly on win 8.1 !!!
0 포인트
samontab
소중한 기여자 II
1,545 조회수
Check that you have all the dependencies with this tool:
http://www.dependencywalker.com/
Run it in both machines and see if there's any difference.
Also, do the samples work fine?
0 포인트
sagar_d_1
초급자
1,545 조회수
Checked for sample applications and apart from Hand Tracking applications all other seem to work fine. Just the Hand related application crashes.
0 포인트
sagar_d_1
초급자
1,545 조회수
I just tried running the dependency tool and found differences when the application was run on both machines.
I need your help in understanding the errors that came through.
If you could share your email ID i can just share a excel spreadsheet with findings from both machines.
0 포인트
samontab
소중한 기여자 II
1,545 조회수
Just put everything here, more people will be able to help you, and people having the same issue in the future will benefit as well.
0 포인트
sagar_d_1
초급자
1,545 조회수
Sure.
I have attached the error log file.
0 포인트
응답
