Software Archive
Read-only legacy content
17060 Discussions
Issue with camera on Windows 10 for Windows Hello
Todd_S_3
On build 101240 of Windows 10 using 1.4 of the drivers and it seems I am having issues with the camera.  Tried this on two MBs, one Z87 and one Z97 - both same issue.   I am using USB 3.0 on both.
Using something like Skye or even some of the tools in the SDK the camera seems to be fine.
Other's I know have no issues.
Any thoughts?
Luis_M_2
I have to keep on testing some more things and scenarios, but since the latest update, the camera has always recognised me!
I'm a happy puppy right now! :)
Todd_S_3
Yep, seems now the camera doesn't work with Windows Hello at all.  I have uninstalled / reinstalled latest drivers and when I go into Settings to setup Windows Hello - the camera works, now with color, but it never tries to recognize me at all.
I have tried multiple 3.0 USB ports, uninstall/reinstall, remove device, everything and still does not work.
I too am not a happy camper with this device.
Mats_F_
I also have huge issues with windows hello and my f200 camera.
Os is windows 10 pro X64 cleanly installed from iso. And only drivers installed for all the hardware in the computer.
Issue is when i go to windows hello config i get the camera to work for like 3 seconds but only in black and white. After 3 seconds the image frezzes and nothing else happens so it never completes the configuration. And the
red and green lights on the camera goes out. If you try again you get the same result or a completly blank windows instead of the black and white one.
All other apps works fine with the camera. Like skype,lync taking pictures with the windows camera app playing warrior wave and using the sdk apps works fine as well.
driver used is 1.4.27.41944 with sdk 6.0.21.6598
in the device manager under imaging devices its listed 3 times
F200 Depth
F200 RGB
Camera virtual driver
and under Universal Serial Bus devices its listed as Intel realsense 3d camera front f200
Anyone haveing any ideas on what to do. Since i really want to get this to work. Any tips are apriciated. I actually bought this camera to be using the windows hello function. So far it has been a wery expensive webcam......
Luis_M_2
Guys, just wanted to let you know that you can expect some nice improvements on Windows Hello once Windows 10 TH2 is released.
For example, the Windows Hello setup speed has been improved and now it shows a full colour image while doing so.
I'm currently testing it on Windows 10 build 10568 with newer drivers downloaded directly through Windows Update.
Cheers!
Luis_M_2
Sorry for the double post, but I've just grabbed new drivers and DCM version through Windows Update on Windows 10, build 10568. Now the Depth driver is up to v1.4.27.52404 and so is DCM. Compilation date is October 15th.
I'll test it out and let you know if anything new comes up.
Cheers!
PS: If you fetch them through Windows Update, you can find the files at "C:\Windows\System32\DriverStore\FileRepository". Just look for the most recent folder with name "realsensef200depth.inf_amd64_4c38452619e410e7"
Joe_S_
Realsense SR300 Depth Camera Gigabyte 797x-ud5h-bk i7-4790 4.00ghz 32.0 GB Ram
the camera works with the windows default camera but once I try using the windows hello login system the Camera turns off and on. no image even comes up any thoughts?
I have tried this on different systems and it works fine I have even gown out and purchased a PCI-E USB 3.1 card and its still doing the same thing
Paul_A_1
Load BIOS defaults (make sure BIOS update is performed). Do an update on your CHIPSET(RS1) and IMEI(RS1) DRIVER and install SDR300 v3.3 driver.
Worked like a charm.
