Hi. I have a question about connecting my laptop to my external lcd (1920x1080p). When the laptop is connected to the display, I get an image on the lcd whenI boot upbut the image disappears shortly after the windows log-in screen appears. After that, I cannot get any images on my external lcdbut I do get an image on the laptop screen. I suspect it may be an issue wih the Intel GMA 950 so want to post here. I did the mon.info thing but don't know how to get the EDID as well as how to make changes to the inf file. Can someone please let me know the EDID and give me a detailed descriptioin of what to doin theinf fileas well as which inf file I have to change. I've been struggling with this for weeks so any help would bevery much appreciated. Many thanks in advance! Below is my info.
Windows 7
Sony Vaio TZ 390
Intel Graphics GMA 950 with 945GM
Samsung SyncMaster 2333HD (1920x1080p)
Monitor
Model name............... SyncMaster
Manufacturer............. Samsung
Plug and Play ID......... SAM0484
Serial number............ HVGQA03092
Manufacture date......... 2008, ISO week 41
EDID revision............ 1.3
Input signal type........ Analog 0.700,0.300 (1.0V p-p)
Sync input support....... Separate, Composite, Sync-on-green
Display type............. RGB color
Screen size.............. 520 x 320 mm (24.0 in)
Power management......... Active off/sleep
Extension blocs.......... None
DDC/CI................... Supported
MCCS revison............. 2.0
Display technology....... TFT
Controller............... Mstar 0x1400
Firmware revision........ 0.1
Firmware flags........... 0x00000001
Active power on time..... Not supported
Power consumption........ Not supported
Current frequency........ 65.54kHz, 0.00Hz
Color characteristics
Default color space...... Non-sRGB
Display gamma............ 2.20
Red chromaticity......... Rx 0.640 - Ry 0.330
Green chromaticity....... Gx 0.300 - Gy 0.600
Blue chromaticity........ Bx 0.150 - By 0.060
White point (default).... Wx 0.313 - Wy 0.329
Additional descriptors... None
Timing characteristics
Horizontal scan range.... 30-81kHz
Vertical scan range...... 56-75Hz
Video bandwidth.......... 170MHz
CVT standard............. Not supported
GTF standard............. Not supported
Preferred timing......... Yes
Native/preferred timing.. 1920x1080p at 60Hz
Modeline............... "1920x1080" 138.500 1920 1968 2000 2080 1080 1083 1088 1111 +hsync -vsync
Standard timings supported
720 x 400p at 70Hz - IBM VGA
640 x 480p at 60Hz - IBM VGA
640 x 480p at 67Hz - Apple Mac II
640 x 480p at 72Hz - VESA
640 x 480p at 75Hz - VESA
800 x 600p at 56Hz - VESA
800 x 600p at 60Hz - VESA
800 x 600p at 72Hz - VESA
800 x 600p at 75Hz - VESA
832 x 624p at 75Hz - Apple Mac II
1024 x 768p at 60Hz - VESA
1024 x 768p at 70Hz - VESA
1024 x 768p at 75Hz - VESA
1280 x 1024p at 75Hz - VESA
1152 x 870p at 75Hz - Apple Mac II
1152 x 864p at 75Hz - VESA STD
1280 x 800p at 60Hz - VESA STD
1280 x 960p at 60Hz - VESA STD
1280 x 1024p at 60Hz - VESA STD
1440 x 900p at 60Hz - VESA STD
1600 x 1200p at 60Hz - VESA STD
1680 x 1050p at 60Hz - VESA STD
Report information
Date generated........... 11/23/2009
Software revision........ 2.42.0.820
Operating system......... 6.1.7600.2
Raw data
00,FF,FF,FF,FF,FF,FF,00,4C,2D,84,04,33,32,46,43,29,12,01,03,0E,34,20,78,2A,EE,91,A3,54,4C,99,26,
0F,50,54,BF,EF,80,71,4F,81,00,81,40,81,80,95,00,A9,40,B3,00,01,01,1A,36,80,A0,70,38,1F,40,30,20,
35,00,06,20,20,00,00,1A,00,00,00,FD,00,38,4B,1E,51,11,00,0A,20,20,20,20,20,20,00,00,00,FC,00,53,
79,6E,63,4D,61,73,74,65,72,0A,20,20,00,00,00,FF,00,48,56,47,51,41,30,33,30,39,32,0A,20,20,00,09
Windows 7
Sony Vaio TZ 390
Monitor
Report information
Raw data
