Software Archive
Read-only legacy content
Keystore
Samuel_G_1
I am building my app with a different toolkit.
I requested my keystore...and did get it downloaded with the passwords. However, when I build my app, and use Jarsigner to sign it, then try to upload it to GooglePlay, I get an error about the new and old certificates not matching.
Why?
--Sam
Samuel_G_1
Attached is the output from Jarsigner on both APKs. I built the new one, and signed it with the keystore Intel sent me.... If you look, the CN is different and the dates are different...
So, what's the issue?
Pamela_H_Intel
Did you sign the upgrade with a different key than the key you used for the original version of your app?
Samuel_G_2
I signed the updated with the Key that INTEL sent me...the same key that was used by INTEL for the original version of my app.
Samuel_G_1
Anyone at INTEL have any thoughts on this???
PaulF_IntelCorp
My thought is that you got sent the wrong cert. The first one looks like a cert that could have been generated by the XDK. Did you use an "organization name" of BTST with your old account? If so, that first one is from your old account. The second one has a weird CN name in it, there is a "N/A" which I interpret as "not available" followed by what appears to be either an "SCC" or "SGG" -- it's hard to see, the screen shot you posted is very lo-res.
Do you still have access to your XDK account? If so, when you build an app with that account, what does the CN name look like?
Samuel_G_1
Paul, et al.
The APP ID for this application is : com.nascg.nascg.btstupload
The NASCG(s) are left over from when I originally registered waaaaaay back when this was an AppMobi project. Back then, for some reason the registration setup got things confused...and I never had any desire to change it...it works.
So, the second jarsigner output is the 'REAL' signature information (signed when building with the XDK). The first one is what I get when I sign the app with the signature info Intel provided to me.
If you think I somehow got the wrong certs, then please resend.
--Sam
John_H_Intel2
Sam ~
I am sending you and email.
Samuel_G_1
John,
I just got finished trying a new keystore, which worked for uploading to GooglePlay.
Sam
