Software Archive
Read-only legacy content
License for Evaluation Copy of Composer XE 2015
Jason_C_3
I am attempting to compile the LAPACK library locally on my machine and I receive the following error output.
Compiling the Fortran compiler identification source file "CMakeFortranCompilerId.F" failed.
Compiler: C:/Program Files (x86)/Intel/Composer XE/bin/intel64/ifort.exe
Build flags:
Id flags:
The output was:
1
Microsoft (R) Visual Studio Version 10.0.40219.1.
Copyright (C) Microsoft Corp. All rights reserved.
Package 'Intel.Fortran.IFLangService.IFLangServicePackage, IFLangService, Version=15.0.0.0, Culture=neutral, PublicKeyToken=null' failed to load.
1>------ Build started: Project: CompilerIdFortran, Configuration: Debug Win32 ------
1>Compiling with Intel(R) Visual Fortran Compiler XE 15.0.0.108 [IA-32]...
1>CMakeFortranCompilerId.F
1>Intel(R) Visual Fortran Compiler XE for applications running on IA-32, Version 15.0.0.108 Build 20140726
1>Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
1>ifort: NOTE: The evaluation period for this product ends on 24-oct-2014 UTC.
1>rc.exe not found.
1>
1>Build log written to  "file://C:\Users\jconnolly7\Desktop\LAPACK\CMakeFiles\3.0.2\CompilerIdFortran\Debug\BuildLog.htm"
1>CompilerIdFortran - 1 error(s), 0 warning(s)
========== Build: 0 succeeded, 1 failed, 0 up-to-date, 0 skipped ==========
Checking whether the Fortran compiler is Compaq using "-what" did not match "Compaq Visual Fortran":
Error: A license for FCompW is not available (-158,61003,2).
License file(s) used were (in this order):
    1.  Trusted Storage
    2.  C:\Program Files (x86)\Common Files\Intel\Licenses\*.lic
    3.  C:\Program Files\Common Files\Intel\Licenses
    4.  C:\PROGRA~2\Intel\COMPOS~2\bin\intel64\*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
ifort: error #10052: could not checkout FLEXlm license
Checking whether the Fortran compiler is NAG using "-V" did not match "NAG Fortran Compiler":
    1.  Trusted Storage
Determining if the Fortran compiler works failed with the following output:
Change Dir: C:/Users/jconnolly7/Desktop/LAPACK/CMakeFiles/CMakeTmp
Run Build Command:"c:/Program Files (x86)/Microsoft Visual Studio 10.0/Common7/IDE/devenv.com" "CMAKE_TRY_COMPILE.sln" "/build" "Debug" "/project" "cmTryCompileExec2802483610"
1>------ Build started: Project: cmTryCompileExec2802483610, Configuration: Debug Win32 ------
1>testFortranCompiler.f
1>rc.exe not found.
1>
1>Build log written to  "file://C:\Users\jconnolly7\Desktop\LAPACK\CMakeFiles\CMakeTmp\cmTryCompileExec2802483610.dir\Debug\BuildLog.htm"
1>cmTryCompileExec2802483610 - 1 error(s), 0 warning(s)
Is it possible to get license files so I can compile?
Yuan_C_Intel
Hi, Jason
I have resent the license file to your registered account. It should be enclosed in the email attachement.
Please have a check and put it under C:\Program Files (x86)\Common Files\Intel\Licenses
Let me know if you need more assistance.
Thank you.
jpanta
I have a similar problem in a thread that is still not answered:
https://software.intel.com/en-us/forums/topic/531737
Yuan_C_Intel
Hi, jpanta
Have you registered for evaluation? I canot find your registration record.
I have sent you a private message. You can provide more informaion through provate messages.
jpanta
Thank you, problem solved!
Karthik_S_
I am looking for the license to the evaluation copy of Parallel XE 2015. Can you please help me out?
Karthik
