Software Archive
Read-only legacy content
License not available
Rawlins__David
Error: A license for Comp-CM is not available (-5,357).
Make sure that a license file is being used that contains a license
for the requested feature.  If your license requires a license server,
make sure that the server is using the right license file (usually,
this would be the same license file that is being used by this
application), and make sure that you have not changed the license
file since starting the server.
License file(s) used were (in this order):
    1.  Trusted Storage
**  2.  /usr/bin/icc-16.0.083-base/bin/intel64/../../Licenses
**  3.  /Users/demo/Licenses
**  4.  /opt/intel/licenses
**  5.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_85V_LG7R-xxxxxxxxx.lic
**  6.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_GLK_LG7R-xxxxxxx.lic
**  7.  /Users/Shared/Library/Application Support/Intel/Licenses/license_ism2_W4F_LG7R-xxxxxxxx.lic
**  8.  /Users/Shared/Library/Application Support/Intel/Licenses/m_xxxxxx.lic
**  9.  /usr/bin/icc-16.0.083-base/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icc-16_0_083: error #10052: could not checkout FLEXlm license
Command /usr/bin/icc-16.0.083 failed with exit code 1
Rawlins__David
I should mention that I'm still able to click on the "Register and Download" button in the emails for Windows (purchased 3/25/2015) and Linux (purchased 8/14/2015).
Devorah_H_Intel
Please send me the SN of the license you are using privately via "Send Author a Message" link.
