Software Archive
Read-only legacy content
17060 Discussions
Linux license server fails with invalid license key (inconsis)
Frank_F_2
I installed a new license server/key on a Linux system. When the license server is started the license log shows an error:
    Invalid license key (Inconsistent authentication code)
When I run lmdiag I see:
  This license cannot be checked out because:
  This platform not authorized by license.
I have 5 floating licenses for Windows but my company prefers license servers by Linux based.
Does Intel support serving Windows licenses from a Linux system?
Kenneth_C_Intel
Yes it does However you need to make sure that you are serving the license correctly. Following this guide should be helpful for you
https://software.intel.com/en-us/articles/intel-software-license-manager-getting-started-tutorial
Let me know if this solves your problem.
Kenneth
Intel Developer Support
Frank_F_2
I tried everything suggested in intel-software-license-manager-getting-started-tutorial and I still have the same problem. Some additional info:
- The errors appearing in the license logfile from the license server. I have not tried running the Intel Parallel tools.
- My Linux system is: Red Hat Enterprise Linux 5.0 (Tikanga)
- The hostid I gave Intel used upper case for the hexadecimal values but "lmutil lmhostid" reports them in lower case format.
