My APP is located into https://play.google.com/store/apps/details?id=com.Conteudo_Animal
I made a list item menu ...
When I click on any link .... a blank header and footer appear and not idea the reason
For example the first link Dicas Veterinárias should show the content on http://www.conteudoanimal.com.br/mobile/dicasveterinarias/dicasveterinarias.asp
Please advice any issue
I want to remove footer and header of 2nd link level
thanks in advance
Marcos
- Tags:
- HTML5
- Intel® XDK
I got the solution!
For your
<div class="upage vertical-col panel" id="mainpage" data-header="af-header-6">
change it to:
<div class="upage vertical-col panel" id="mainpage" data-header="none" data-footer="none">
This will remove the header and footer on the main page, and for all the <a> elements,
set
target="_self"
This way, no headers/footers, and adsense works!
Hi Marco,
Which XDK Version are you using? Are you using app designer or which framework you are using for this app?
For the <a> tag that links you to the page, what did you set the href to?
Also, the <a> element should be inside your <li> list item element, not wrapped around.
Also, I tried recreating your problem, with XDK version 1995, list view template.
Try:
<ul class="list">
<li><a href="http://www.conteudoanimal.com.br/mobile/dicasveterinarias/dicasveterinarias.asp">Item 1</a></li>
<li><a href="#item2">Item 2</a></li>
<li><a href="#item3">Item 3</a></li>
<li><a href="#item4">Item 4</a></li>
<li><a href="#item5">Item 5</a></li>
<li><a href="#item6">Item 6</a></li>
<li><a href="#item7">Item 7</a></li>
<li><a href="#item8">Item 8</a></li>
<li><a href="#item9">Item 9</a></li>
<li><a href="#item10">Item 10</a></li>
<li><a href="#item11">Item 11</a></li>
<li><a href="#item12">Item 12</a></li>
</ul>
Most of the code is default, however I changed the first List Item to the link you provided in the question.
It works in both HTML5 and HTML5+Cordova
Do you want to remove those headers/footers completely, or actually put text in them?
Also, do you care to maintain the theme?
E.g
Android: black bacground etc.
IOS: gray background etc.
Kirten,
Remove completely header and footer
Another issue is with those the adsense code not showing like
I got the solution!
For your
change it to:
set
target="_self"
Kirtan,
Worked 100% .... thanks a lot
Do you have a website or blog or something else ?
Do you work on Intel ?
cheers
Marcos
www.conteudoanimal.com.br ;
Actually, no I don't work for intel, and I don't have a blog/website.
Twitter ? Facebook ? Linkedin ???
Something you want to promote ???
No, I don't have accounts for any of those
Well .... thx a lot again
Helped me a lot !!!
thanks again and again !
no problem
